4BT MPG Challenge
Results 1 to 29 of 29
Thread: 4BT MPG Challenge
    Registered User Joxxxi's Avatar
    May 2007
    Greensburg, IN
    229
    Default 4BT MPG Challenge
    When I originally started my 4BT project, I read where everyone was getting 28+ MPG out of Jeep Wranglers with 33" tires. So, I bought a Jeep Wrangler and started my build. Later, I realized it seemed nobody had any hard evidence supporting their claims. The posts always read something like 'I was on this one trip, it lasted for this many miles and I used about this much fuel.' Or there's a post where someone posts their average and you're expected to believe it. The point still is there's no real data to support the claim.
    So, here's the chance to put up or shut up about your mileage guys. Starting today, I'm offering a challenge to you to see what your 'real' numbers are. All you you need to do is make ONE post. Put in it - your vehicle specs, the area you drive, and most important your fuel record.
    Once you've done that, all you need to do is edit that one post with new information build your record with actual starting ending mileages and purchases. We're talking raw data. Not just the total average number. I'll start with mine on the next post so you can see what I'm looking for. Your welcome to use it as a template.
    May 2007
    Greensburg, IN
    229
    Default 1994 Jeep Wrangler
    Area of Operation:
    United States, South Eastern Indiana
    Current Configuration:
    Engine: Cummins 4BT Stock Turbo
    Transmission: General Motors TH-400 3-Speed Auto
    Transfer Case: New Process 231
    Rear Unit: Ford 8.8 (2.73)
    Front unit: Jeep Dana 44 (2.73)
    Tires: Mickey Thompson Baja Claw (33x15.5x15)
    Fuel Record:
    2007
    P. Date - Odometer - Qty - Price - MPG
    10/20/07 - 000,000 - 17.00 - 0.NA - 19.5
    11/15/07 - 000,331 - 10.00 - 3.50 - 17.2
    11/19/07 - 000,503 - 05.70 - 3.50 - 16.3
    11/20/07 - 000,596 - 14.29 - 3.50 - 18.2
    11/26/07 - 000,856 - 18.30 - 3.54 - 18.1
    12/12/07 - 001,187 - 19.70 - 3.30 - 15.0
    12/24/07 - 001,483 - 18.10 - 3.33 - 16.4
    Annual MPG - 17.24
    2008
    01/16/08 - 001,779 - 18.52 - 3.35 - 16.4
    01/29/08 - 002,083 - 19.10 - 3.30 - 14.2
    02/20/08 - 002,355 - 16.77 - 3.58 - 17.8
    03/05/08 - 002,653 - 07.90 - 3.78 - 20.2
    03/21/08 - 002,813 - 19.50 - 4.16 - 14.8
    04/03/08 - 003,101 - 19.47 - 4.06 - 16.0
    05/24/08 - 003,690 - 18.90 - 4.83 - 18.6
    06/25/08 - 004,041 - 19.35 - 4.86 - 19.3
    07/07/08 - 004,414 - 19.55 - 4.86 - 18.6
    07/28/08 - 004,778 - 20.22 - 4.70 - 19.5
    08/20/08 - 005,172 - 19.55 - 4.59 - 18.8
    09/17/08 - 005,547 - 19.96 - 4.16 - 17.7
    Estimate - 005,925 - 20.50 - 4.05 - 18.6
    11/01/08 - 006,307 - 19.75 - 3.09 - 17.6
    11/25/08 - 006,655 - 20.80 - 2.69 - 14.9
    Annual MPG = 17.53
    2009
    Estimate - 006,965 - 20.50 - 2.16 - 15.0
    02/24/09 - 007,272 - 19.46 - 2.16 - 17.8
    03/16/09 - 007,619 - 20.01 - 2.00 - 17.2
    03/24/09 - 007,963 - 19.19 - 2.19 - 17.7
    04/06/09 - 008,303 - 20.00 - 2.20 - 18.5
    04/19/09 - 008,672 - 20.01 - 2.26 - 17.2
    05/22/09 - 009,017 - 19.33 - 2.33 - 17.1
    06/22/09 - 009,347 - 20.75 - 2.70 - 17.2
    07/12/09 - 009,703 - 20.31 - 2.66 - 17.4
    08/16/09 - 010,057 - 20.01 - 2.70 - 17.9
    09/09/09 - 010,416 - 20.01 - 2.70 - 18.0
    09/30/09 - 010,776 - 20.92 - 2.60 - Soon
    Annual MPG = 17.36
    Overall MPG: 17.38
    Feb 2009
    Illinois
    222
    I don't have my 4BT in a donor yet, but I have a 3/4 4x4 Dodge Cummins with a p-pumped 12V and I get 2 more mpg by adding a quart of two stroke oil and half a bottle of Power Service to each fill up. I do this to help lubricate the injection pump (I don't truct USLD). The extra MPG is a bonus. I'm averaging 19 mpgs with 4:10 gears.
  5. Remove Advertisements
  6. #4
    Supporting Member scout4bta's Avatar
    Jan 2007
    Mesa, AZ
    2,239
    43
    Default Controlled mileage test
    NRA Life Endowment member
    1980 Scout II:92 Dodge CAC, NV4500, 3.73 gears, Atlas 4.33,33/10.50 BFG KM2, HE221W 6cm2, 3200 GSK. Cold air intake & snorkel. Mileage:low 20s to high 20s. The swap
    91.5 Dodge W250 CTD
  7. #5
    Jan 2007
    New Haven, CT
    1,298
    8
    I once got 25MPG in my J300 (4BT/NV4500/NP200/3.08), but I typically get 23MPG. Not spectacular, but considering that it doubled the MPG from the gas engine...
    1963 Jeep J300, 4BT/NV4500/NP200/D61/D71
    1969 Jeep M715 6x6 project, 6BTA/NV4500/NP205/D60/D70/D70
  8. #6
    Feb 2007
    142
    I can attain 27 mpg fairly regularly in mine. Stock engine and turbo with pump turned up some. Running an intercooler. Traveling 65-70 in somewhat hilly terrain. I was tracking my speed an distance with a handheld GPS and just topped one of my tanks up to the brim. I have beat this number one time and made it into the 30 mark. This was with a 50 mph tailwind and an elevation drop of about 3000 feet over the course of 135 miles. 25 mpg is always possible around town.
    This is in my K10 short box with 33x12.50x16.5 BFG all-terrains. 3.73 gears. NV4500. I have no idea what it weighs. Some sheetmetal bobbed to remove rust but also running 14 bolt semi floater rear end.
    I am now tuning in a new turbo set-up. I hope it doesn't go down, but it seems doubtful that it will go up.
  9. #7
    Jun 2007
    Charleston, SC
    157
    Default 1977 Ford Bronco 4bt
    I will play the game as soon as I get the rear driveshaft back in.....I plan to drive several hundred miles this weekend.
    Area of Operation:
    United States, South Carolina
    Engine: Cummins 4BT Turbo
    Engine changes: K&N Air Filter, Fuel Pump Timing Advanced 2+ degrees, H1C turbo w/16cm turbine housing
    Truck: 1977 Ford Bronco with dual Tanks
    Transmission: Ford C4 3-Speed Auto, Art Carr Manual Reverse Shift Valve Body, additional capacity sump
    Transfer Case: Dana 20
    Rear Unit: Ford 9" (3.5)
    Front unit: Dana 44 (3.5)
    Tires: BFG KM2 (35x12.5x17)
    Current hard acceleration measurements from 45mph to 70mph
    Max boost = 16psi
    Max EGT = 900 Deg F
    RPM at 70mph = 2,350
    Fuel: ULSD
    Fuel Record:
    2009
    P. Date - Odometer(Miles) - Qty(gal) - Price($) - MPG
    08/22/09 000,079 Filled up $2.49 N/Available
    08/22/09 000,180 5.12 $2.49 19.73 Mostly 70mph
    09/05/09 000,419 12.18 $2.49 19.62 City driving
    09/07/09 000,743 14.81 $2.49 21.88 Mostly 55-60 mph
    11/6/09 001,090 18.09 $2.65 19.18 Mostly to & from work 7 miles each way
    Total Average = 20.14 mpg
    Last edited by High Pressure; 11-09-2009 at 01:36 PM. Reason: Updated fuel mileage
    '77 Bronco, 4bt, C4 w/Art Carr Rev Valve Body, 2.5 SL, 2" BL, 35" BFG KM2s
  10. #8
    Jul 2009
    Colorado
    729
    1
    Default 63 Chevy extended cab
    AREA OF OPERATION
    Colorado,Utah,New Mexico
    4000 - 10000ft elavation
    Cummins 4Bt CPL 0593, 1.85mm plunger depth, 6BT H1C turbo
    Transmission: SM420 with Ranger overdrive (27%)
    Tcase: Rockwell T221
    Front axle Corp. 10 bolt
    Rear axle Corp. 14 bolt (4.10 gear)
    Tires: Uniroyal Liberators 285/75/16, 50psi
    Weight: 6085 lbs
    FUEL RECORD
    3.42 Gears
    1/25/06 28202.4
    2/15/06 28717.1 22gal 23.4mpg
    3/7/06 28978.8 10gal 23.87mpg
    3/19/06 29380.0 18.1gal 22.17
    29706.7 15.67gal 20.85mpg
    4/17/06 29955.3 9.8gal 25.4mpg
    4/18/06 30305.7 9.06gal 19.5mpg
    4/19/06 30513.8 9.05gal 22.97mpg
    4/19/06 30720.7 9.5gal 21.78mpg
    4/19/06 31117.0 18.4gal 21.5mpg
    4/20/06 31477.9 19.3gal 18.69mpg
    4/20/06 31783.5 17.4gal 17.56mpg
    4/20/06 31932.0 9.13gal 16.27mpg
    4/20/06 32098.0 8.40gal 19.76mpg
    4/21/06 32625.7 23.6gal 22.4mpg
    5/14/06 32939.3 12.07gal 25.98mpg
    5/25/06 33243.8 11.45gal 26.59mpg
    6/07/06 33418.9 8.27gal 21.17mpg
    6/29/06 33998.2 22.7gal 25.5mpg
    7/20/06 34257.2 11.7gal 22.13mpg
    8/06/06 34600.0 15.66gal 21.9mpg
    8/19/06 34846.0 10.86gal 22.7mpg
    9/27/06 35291.6 20gal 22.3mpg
    35359.9 3.9gal 17.5mpg
    4.10 GEARS
    10/21/06 35665.3 13.2gal 23.7mpg
    11/11/06 36029.0 17.0gal 21.4mpg
    01/11/07 36610.1 27.7gal 21 mpg
    01/25/07 36776.7 7.8gal 21.3mpg
    01/26/07 36988.8 14 gal 15.2mpg
    03/06/07 37327.6 16 gal 21.2mpg
    04/01/07 37729.3 16.2gal 24.9mpg
    05/01/07 38136.2 15.97 25.5
    05/22/07 38454.0 13.44 23.7
    05/30/07 38897.9 16.6 26.7
    06/17/07 39474.4 24.2 23.8
    06/26/07 39746.4 9.64gal 28.2mpg
    07/10/07 40182.6 19.2 22.7
    07/25/07 40459.7 11.7 23.7
    08/02/07 40657.1 8.3 23.78
    08/13/07 41239.2 22.2gal 26.22mpg
    08/16/07 41548.1 10.3 30 mpg
    09/04/07 41905.2 14.8gal 24.2mpg
    10/03/07 42294.0 15.97 24.35
    10/30/07 42816.6 21 24.88
    11/21/07 43140.0 13.6gal 23.74mpg
    11/30/07 43553.7 17.4 23.78
    12/07/07 43890.4 14.5 23.19
    12/16/07 44273.0 16.5 23.19
    02/24/08 44669.9 18.9gal 21 mpg
    03/15/08 44759.1 16.04
    07/01/08 45941.5
    07/15/08 46364.2 15.5gal 27.2mpg
    07/23/08 46701.6 13.18gal 25.59mpg
    07/27/08 47043.3 12.8 26.7mpg
    09/15/08 47426.0 11.0gal 23.9
    11/07/08 47958.5 22.7 23.5mpg
    12/15/08 48396.9 18.06 24.3
    01/25/09 48835.5 22.5gal 19.5mpg
    02/12/09 49219.3 15.5 24.76
    02/20/09 49495.3 10.95 25.2
    02/25/09 49952.4 19.7gal 23.2mpg
    05/04/09 50472.3 20 gal 25.98mpg
    07/17/09 50762.1 12.2 23.8
    07/24/09 51184.2 15.9gal 26.5mpg
    Average 23.1
    1963 Chevy extended cab K20 4x4 p/s p/b 4BT HX30w 1.8mm timing Ranger over drive sm420 4.10 gears PTO winch exaust brake
    1983 Ford Bronco 4BT H1C 16cm 1.5mm ZF5speed 3.55 gears first Gen intercooler fuel screw turned 3/8
    1942 WC26 Dodge Carryall 4BT NV4500 NP205 Dana 60&70 hydroboost brakes (project with Daughter)
  11. #9
    Jan 2007
    New Haven, CT
    1,298
    8
    What gearing did you have for the first data set?
    Quote Originally Posted by dieseldude View Post
    AREA OF OPERATION
    Weight: 6085 lbs
    FUEL RECORD
    1/25/06 28202.4
    4.10 GEARS
    07/01/08 45941.5
  12. #10
    Jul 2009
    Colorado
    729
    1
    I had 3.42 gears in it, worked good on the highway but sucked around town and in the moutains.
  13. #11
    Registered User LReiff's Avatar
    Jun 2009
    South Central PA.
    176
    I got a chance to meet VortecZ last friday afternoon. He is claiming 32 mpg in his '05 1500 chevy.
    Lee
    http://www.reiffdiesel.com
    Official tuner of the 496HP 4BT Cummins
  14. #12
    Jan 2007
    Mesa, AZ
    2,239
    43
    Here's this years list.
    3.73 gears/NV4500/BFG 33/10.50/15 MUD's
    In town driving except where noted.
    Jan 12, 09/ 24 mpg
    Feb 9, 09/ 21.6 mpg
    Feb 20, 09/25.94 mpg
    Feb 26, 09/ 21.11 mph Snow run, trip to Crown King and back to Mesa.
    Mar 13, 09/ 22.12 mpg
    Mar 23, 09/ 21.65 mpg
    April 4, 09/ 23.62 mpg
    April 24, 09/22.6 mpg
    june 15, 09/ 24.14 mpg
    June 18, 09/ 19.93 mpg
    June 6, 09/ 21.66 mpg
    July 14, 09/ 18.91 mpg
    July 29, 09/21.94 mpg
    Aug 12, 09/20.04 mpg
    91.5 Dodge W250 CTD
  15. #13
    Dec 2007
    East Tennessee
    299
    There is a sticky in the tech section for just this reason.....
    http://www.4btswaps.com/forum/showthread.php?t=6254
    I have not updated my post, but I have gotten 20mpg's for the last two tanks in mixed driving...
    Fiddleback
    1979 Ford F-150 4x4 "The Beast"
    4BTA (CPL#986), T-18, NP205, Dana 60 rear (3.73), Dana 44 front (3.52), 315/85R16 BFG A/T (35in)
    http://www.4btswaps.com/forum/showthread.php?t=4380
    Reminder Blue Star renewal 6/2010
  16. #14
    Jun 2007
    Charleston, SC
    157
    Default Updated mileage log
    TTT updated mileage log from this past weekend drive of 324 miles for 21.8 mpg
  17. #15
    '69 FJ55 Land Cruiser dieselcruiserhead's Avatar
    Jan 2007
    Park City, Utah
    1,660
    This is a great thread...
    In my 1971 Toyota Land Cruiser:
    1991 120hp 4BTA, mildly turned up.
    WH1C 12cm2 housing Turbo, stock otherwise
    NV4500 Dodge Standard Duty (5.6 1st, .27 OD)
    NP241
    4.10 axle gearing
    35" tires
    spring over axle lift of approx 5"
    aerodynamics of a brick
    25mpg regularly attainable highway with all terrain tires.
    With Mud terrains and cruising speed of about 2200 rpms, about 22-23 on average.
    1991 Toyota Pickup, Mercedes 300D OM617 diesel
    1969 Land Cruiser project in progress with 4BT
    1989 Land Cruiser project in progress with 4BT
    2010 KTM 450
    Successfully installed 4BT, Isuzu 4BD1T, and Mercedes 300D engines into different vehicles.
  18. The Following User Says Thank You to dieselcruiserhead For This Useful Post:
    BigRed15 (11-11-2015)
  19. #16
    Registered User dieseldakota's Avatar
    Mar 2009
    Fort Saskatchewan Alberta canada
    598
    Thumbs down
    its been hard to get mpg lately because my oddometer keeps reseting itself not sure why. i took a trip this last weekend
    truck setup
    dodge dakota 2003 quad cab 4x4 with front dif temperarily removed
    engine: stock 4bt with free pump mods
    3.52 stock dif
    30 inch bf bfg all terrains
    last tank all highway
    719.4km- 447miles
    58.075L-15.342us gallons
    .979$/Liter 57$ for the tank[bc prices are high compared to here at home]
    12.387kmperL_ or 29.136 miles per gallon
    this is through mountains cruising at 110km/h or 68 miles per hour
    on average around town i get around 26-27
    and less in winter because of excess slipping[lol] and winter fuel
    ps[i accidently put the thumbs down in there ignore that]
    Stepped away from my diesel projects, currently playing with a small racecar. I intend to come back once I find the perfect mid 50's pickup for my project.
  20. #17
    Jan 2007
    New Haven, CT
    1,298
    8
    Has anyone experienced any MPG increases doing any power enhancing modifications?
  21. #18
    Aug 2009
    central iowa
    37
    Can this be made a sticky?
  22. #19
    Nov 2008
    Stony Plain Alberta
    2,947
    1
    My last tank of all in town driving. I got 440km's to 59lts at 82cents per litre. I think that equates out to 17 mpg. My in town mileage didn't change much after I did injectors. Haven't gone on a good highway cruise yet with the new injectors. The best tank when the truck was stock was all highway, 550km's to 50lts. I think that's 26mpg?
    Stephen
    1994 Dodge Dakota Ext Cab 4x4. 4BTA 553 and 796ft/lbs torque, 11.83 at 113mph 1/4.
  23. #20
    Nov 2008
    Stony Plain Alberta
    2,947
    1
    Quote Originally Posted by Traveler View Post
    There is a fuel log sticky in the tech section.
  24. #21
    Sep 2007
    Greenville, SC
    70
    I have a 1998 dodge durango 32x10.50 all terrain, 3.55 rear gears. WH1c turbo with 12cm2 housing, 4in exhaust, TH700R4 trans, No intercooler, upgraded fuel pump with torque pin, 3200 gov spring and adjusted starwheel. I drive hard stoplight city to and from work everyday and get 22.2mpg consistantly. The last trip was through the mountians of NC and Tenn. and averaged 25.3 mpg. This was a 380 mile trip from Greenville, SC to Knoxville, Tn back to Greenville and ran 70 most of the way
  25. #22
    Jan 2007
    MD
    1,203
    I apologize for the formatting ahead of time...I can email the spreadsheet to someone if the want it. just PM me.
    I tried to keep a log for quite a while with my Durango. Below you can see some specifics of the data. I did a mix of driving with the durango including some towing and i tried to seperate it out the best i could. below the main data set i broke it down a bit to look at what the averages were.
    edit: oh yea, specs on the Durango. 4bt/nv4500/31's/3.55's/2wd. and i no longer own it...
    Fuel Spreadsheet
    Date Volume Price Miles MPG Price/mile Note
    12/8/2007 6.251 3.359 172 27.5155975 0.122076215
    1/1/2008 22.3 3.499 519.4 23.29147982 0.150226608
    1/9/2008 22.74 3.499 516 22.69129288 0.154200116
    1/9/2008 22.74 3.499 516 22.68730215 0.15422724
    1/13/2008 9.288 3.359 238.5 25.67829457 0.130810868
    1/21/2008 14.449 3.279 325 22.49290608 0.145779295
    1/25/2008 13.565 3.239 332 24.4747512 0.132340467
    1/25/2008 13.55 3.239 332 24.50184502 0.132194127 estimated see receipt
    2/1/2008 23.342 3.459 531.6 22.77439808 0.151881072
    3/21/2008 17.339 3.99 437.7 25.24367034 0.158059424
    3/23/2008 10.947 4.159 126 11.51000274 0.361337881 towing
    4/11/2008 8.954 4.099 147 16.41724369 0.249676503 Towing
    5/6/2008 14.207 4.799 377.5 26.57140846 0.180607664
    5/9/2008 12.977 4.399 313 24.11959621 0.182382821
    5/13/2008 13.231 4.459 350.9 26.52104905 0.168130604
    5/17/2008 14.451 4.499 408.6 28.27485987 0.159116615
    5/19/2008 10.271 4.599 155 15.09103301 0.30475051 towing
    6/13/2008 9.522 4.899 195.3 20.51039698 0.23885447 towing
    6/20/2008 13.952 4.799 381.9 27.37241972 0.175322461
    7/2/2008 21.457 4.639 466.7 21.7504777 0.213282672
    7/12/2008 19.713 4.699 480.7 24.38492365 0.192701034 some towing
    7/18/2008 17.788 4.799 417.4 23.46525748 0.204515122
    4/6/2009 18.316 2.199 473.5 25.85171435 0.085062057 Intercooler Installed winter '09
    4/11/2009 16.36 2.259 404.5 24.72493888 0.091365241 some towing
    4/16/2009 17.444 2.259 472.9 27.10960789 0.083328391
    4/22/2009 14.79 2.259 403.5 27.28194726 0.082802007
    4/28/2009 18.3 2.259 511 27.92349727 0.080899609
    4/30/2009 7.031 2.259 176.1 25.04622387 0.090193237
    Gallons Price Miles
    Overall 471.316 3.641935484 11264.6
    No Towing 395.549 9756.1
    AVG Including Towing 23.90031317
    AVG No Towing 24.66470652
    AVG No Towing Since Intercooler 27.16060106
    2001 CTD Durango - Sold
    2000 24V Ram QCLB 5speed - Current
  26. #23
    New Registered User
    Oct 2013
    East Tennessee USA
    4
    I hear what you are saying! I built a 2002 Dodge Ram 1500 Crew Cab, I put a Ford ZF5 5speed in the truck. My gear front and rear are 355., I put 35 Kumo M/T or 315 x 12 I added a air to air and advance the timing. I turned the Star ring all the way down ( Not sure of the name but under the smoke screw that I did not mess with) I turned the fuel pin so the slop was facing to the front.I turned the fuel screw in 3 full turns. Once I have my drive line in I will be happy to give you some info on the fuel MPG. Before I made the changes to the timing I drive it over 100 mile and used 1/8 of a tank of fuel. But I went the next day to dodge and they calibrated the speed odometer for the size of tires I have on it. I topped the truck off and hooked it to my 20ft x 8ft jon boat with 36 gal fuel tank and 115 hp johnson. I pulled it up and down hills both ways and I used not even 1/4 of fuel on 120 miles I will be able to give you the fuel milage once I top it off. I am going to say around 18 or 19 mpg pulling a heavy ass boat. I am like you I need to see the proof before I belive it. It is doing about the same as my 2500 Ram with 6bt 24V . Will update soon
  27. #24
    Registered User eggman918's Avatar
    Feb 2010
    Paulden, AZ.
    1,636
    163
    We just returned from a trip from Bakersfield CA. to Flagstaff AZ. and back a trip of ~1000 miles towing our trailer so a total weight of 12,000 lbs the truck ran flawlessly other that coolant temps of 210* pulling some of the long grades in the heat of the day,but it cooled down quickly when the road leveled out. We got 14 mpg with an average speed for the whole trip 63 mph and on the way there from Needles CA. @ 500' to Flagstaff @ 7000' ~200 miles the 4BT was running wide open the whole way making 26psi boost with 1200* EGT's this thing likes to work hard Does 14mpg sound like reasonable mileage running that hard? This is the first cross country trip we have taken since the swap and I'm happy with how it went just wondering if that was a good mileage number I "think" it is for as hard as we were pushing it........but I have nothing to compare with.
    Steve E.
    The "Filthy Beast" 1968 F-250 4x4 crew cab 131" wheelbase 3.55 Dana 44HD/Dana60..4BT HE 221W 6cm exhaust ,VE pump advanced,power screw turned up 2 turns, F-800 inter cooler 3" plumbing ,ZF-5. NP-203/205 http://s1042.photobucket.com/albums/b429/eggman918/
    The key to knowledge is first to understand what you don't know,then you can start to learn the things you don't know....?
  28. #25
    Nov 2009
    flatland
    2,103
    4
    Did you run out of in Needles? We run about 400 miles and drive ours like we stole it. Same weight around 12 k but tad better on mpg's. If we keep it under 70 it has done about 18. It has a consistent 18 mpg lately used to vary 16-21 but think it has found its sweet spot. Yes poor thing gets flogged but it loves it.l
    Quote Originally Posted by eggman918 View Post
  29. #26
    May 2009
    Michigan
    705
    1
    17.7
    Highway or around town, it doesn't care.
    37" tires 4.10 gears
    1450rpm @55 mph
    1850rpm @ 70mph
    1995 f-150 3.9 VE 4bt, hx30 over HE341, 5 x .012 bosch tips, Colt stage 2 cam grind, 4" mandrel exhaust all the way back, 3" mandrel IC piping with 06 RAM IC
    Truck build http://www.4btswaps.com/forum/showth...ighlight=f-x50
    Engine Build http://www.4btswaps.com/forum/showth...ighlight=200hp
  30. #27
    Supporting Member GLTHFJ60's Avatar
    Jun 2010
    Durham, NC
    1,644
    228
    With 37" tires, 3.73 gears and a NV4500, I was getting 20-22 unloaded.
    With 35" tires and the above setup I'm getting about 18mpg.
    Johnny C - KK4HAN - TLCA# 17825
    Olde North State Cruisers
    1987 4BTJMashup - MoonShine - 4BT/NV4500/D300/D60/14B and a bunch of other modifications. - DD
    Land Cruiser adventures, documented through YouTube
    Quote Originally Posted by Dougal
    I'm an engineer, I find solutions that work and really hate marketing dribble.
  31. #28
    Jun 2013
    Rhode Island
    65
    22
    92 Ford f150 4x4,m5od with 3.08 rear and front. Stock (235/75 15) tires. Engine is stock except for fuel pin turned 90 degrees and Dodge CAC. Its been a daily driver for 2 1/2 years & 25k+ miles. I calculate MPG every top off as I use the trip meter for a fuel gauge. I have never got less than 22 nor better than 25 mpg no matter how I drive. 65 mph = 1950 rpm per tiny tach.
  32. #29
    Apr 2008
    Cent Ca
    336
    1
    I drive an IH Scout with 6BT,
    Ranger overdrive,
    SM420,
    Dana300,
    2.72 gears
    31 inch tires.
    Area of operation Central Cal.
    Years of milage records. Average 24 MPG mixed driving with speeds on the highway around 70MPH.
    Best MPG 30 driving from Seattle to central CA at exactly 55 mph with only a couple of stops.
