quietning the 4bt
Results 1 to 13 of 13
Thread: quietning the 4bt
    Registered User dieseldakota's Avatar
    Mar 2009
    Fort Saskatchewan Alberta canada
    598
    Default quietning the 4bt
    obviously most of us know the 4bt is quite a loud engine.
    i want to hear my exaust less so i just thought i would bring up the topic and see what ideas came out.
    looking at the stuff from second skin[previously brought up in another thread] i think i'm going to put some dampening materials around the engine compartment.
    last week my dad was thinking if you could spray foam the sides of the block to quiet it down
    any thoughts everyone
    Stepped away from my diesel projects, currently playing with a small racecar. I intend to come back once I find the perfect mid 50's pickup for my project.
    Sep 2009
    Woodbury, nj
    42
    Default Quiet 4bt?
    You could try making a cover to go over the valve cover and injector area out of fiberglass, l'm sure covering those 2 areas with a sound deadening material would help alot. Perhaps a cover made of nomex or something non combustible, obviously cut to fit and avoid moving parts.
    Nov 2008
    Stony Plain Alberta
    2,934
    1
    you could also use something like dynamat in the interior. Do the floor, the roof, the doors, everything you can. Makes a big difference. I've used a material similar to dynamat and it works real good. Don't remember what it's called but I get it from the local sterio shop.
    Stephen
  5. Remove Advertisements
  6. #4
    Supporting Member
    Mar 2009
    Southeast
    1,761
    161
    Don't spay the engine itself,not such a good idea..I used a soundstop foam in the cab of my trucks,and it works REAL WELL,it is originally for the bulkheads,and engine house covers on yachts.I got mine from ebay .It wasn't cheap,but it does work.
  7. #5
    Supporting Member scout4bta's Avatar
    Jan 2007
    Mesa, AZ
    2,180
    40
    By sound deadening on the engine your reducing the noise at the source.
    The first place you want to start sound deadening on the engine is any sheetmetal item, especially the oil pan, the side cover where the tappets are, front of the timing cover and the valve covers. Use Second Skin Sprectrum, apply a 2 millmeter coating for maximum sound deadeading. Next you want to coat the entire surface of the engine compartment with sound absorbing material, including underneath the hood. The nice thing about using the spray on material is not having to cut patterns of material, just a little masking and your on your way.
    I've applied the coating to my oilpan and did notice a slight decrease in noise, need to finish the job.
    NRA Life Endowment member
    1980 Scout II:92 Dodge CAC, NV4500, 3.73 gears, Atlas 4.33,33/10.50 BFG KM2, HE221W 6cm2, 3200 GSK. Cold air intake. Mileage:low 20s to high 20s. The swap
    91.5 Dodge W250 CTD
  8. #6
    Dec 2007
    East Tennessee
    299
    On top of the second skin and products like it, I'm planning on installing a valve cover and oil pan blanked from this place.
    I need to get them some measurements for the 4bt. It would be great if others would want a set also. More units means less cost per unit. I would also get the turbo and exhaust blanket, but I think that is conversion specific.
    Take a look. I don't work for or sell this product....
    If you call up the company ask for Roberto Loya. He is who I have been talking to.
    http://www.atpwrap.com/html/dodge67cummins2009.html
    Fiddleback
    1979 Ford F-150 4x4 "The Beast"
    4BTA (CPL#986), T-18, NP205, Dana 60 rear (3.73), Dana 44 front (3.52), 315/85R16 BFG A/T (35in)
    http://www.4btswaps.com/forum/showthread.php?t=4380
    Reminder Blue Star renewal 6/2010
  9. #7
    Aug 2008
    allen, tx
    119
    what about lining the inside of the valve covers with something like a sort of matting or a spray on somthing, make it quieter and still pleasing to the eye on the outside, or is there to much worry of stuff breaking down and getting into the oil
  10. #8
    Registered User ambulancechser's Avatar
    May 2008
    edmonton,alberta
    1,253
    3
    Quote Originally Posted by Strange View Post
    exactly what would happen...hot oil dissolves lots of stuff.contamination would be a guarantee.
    i found that vehicles can be toned down a lot with an engine cover.there on new oem cars for a reason...not just looks.a hood pad goes a long way too.
    currently modding an 86' m-1010 cucv ambulance,with factory 14-bolt/detroit in back and an open 60 in front.lifted 6 inches,running 37's on 17 x 8's.now swappimg in a mild 6bt,and an nvg-4500/np205 combo.hope to have it running by fall.
    link to engine build... http://www.4btswaps.com/forum/showth...n-engine-build...
  11. #9
    Jan 2007
    Sioux Falls, South Dakota
    1,068
    Here's the most economical way to sound deaden the Cummins... The 1st step would be ear plugs, the 2nd step would be ear muffs, combined these two simple steps are very effective. And this technology can be used in many different situations, irritating inlaws for example
    1989 D250 CTD, 727HD, D70/3.07, BHAF, DIY Cold air, Tuned VE, 4" exhaust
  12. #10
    Supporting Member
    Mar 2009
    Southeast
    1,761
    161
    But......... it's supposed to be noisey.........it was that way when I got here......The best way is to sound insulate the cab,and besides,what would a Harley be if it was real quiet???
  13. #11
    Aug 2008
    allen, tx
    119
    Quote Originally Posted by 2Dodges View Post
    slightly less useless
    3 out of 5 Harley's are still on the road today.....the other two made it home
  14. #12
    Mar 2008
    Green Bay, WI
    2,081
    16
    This is how I quiet my 4BT.........
    .............. Turn it off
    Otherwise its just noisey.....
    1967 Kaiser Jeep 5/4 ton M-715 4x4
    12 Valve/ ZF 5 / NP205 Twin Stick
    Dana 60 Kingpin / Sterling 10.25
    **OLD**1947 Ford 1.5 Ton DRW
    Cummins 6BT P7100 - HE341 Turbo
    Eaton Fuller RT-6610 10 speed - 4 Link Rear / IFS
  15. #13
    Mar 2009
    598
    i don't mind hearing my exaust roaring when i stand on it i love the truck being load i would just rather have less "engine" noise i can barely even hear my exaust
