Toyota transmission behind a 4bt (donor Truck?)
Results 1 to 5 of 5
Thread: Toyota transmission behind a 4bt (donor Truck?)
    Nov 2009
    pennsylvania
    196
    1
    Default Toyota transmission behind a 4bt (donor Truck?)
    I have two questions. First What is the easiest way to bolt a toyota r150f or w56 to a cummins 4bt. I know everyone is going to say that the toyota wont hold up. Regardless of that, does anyone know the best way to do it? Also what would be the best donor truck to get a 4bt? Where can I find one? Thanks
    Apr 2009
    Vancouver, WA
    65
    Quote Originally Posted by MILLENNIUM FALCON View Post
    toyota r150f or w56 + cummins 4bt = custom adapter plate
    bread truck = 4bt
    2012 Subaru Forester 2.5x Premium
    1999 Jeep TJ 4.0L, Manual, 1" lift, 33" tires (DOA due to a stupid driver)
    1991 Chevy Suburban V2500, 1991 Cummins 4bt CPL 858, Dodge HD NV4500, NP241c, Dana 60 Front, Detroit locked 14 Bolt FF Rear, 4.10 gears, 4" lift, 35" tires. 19-20mpg city, 23mpg hwy (Sold)
    Jul 2009
    British Columbia
    113
    I can never remember the Toyota designation for it, but Jeep uses a Toyota tranny that Jeep designates the AX/15. If either of those trannys is the same internals as the AX/15 by swapping a few of the Jeep version parts into the Toyota tranny you could do the same thing as in this thread http://www.4btswaps.com/forum/showthread.php?t=1209
    You would have to swap the input shaft, the input bearing retainer, bellhousing and related Jeep clutch parts.
    Some of the Toyota guys are already using some of the Jeep tranny parts to do a Dana 300 transfercase swap into their trucks, so I know there is parts interchangeabillity but like I mentioned I can never remember which Toyota tranny is the Jeep AX/15.
  5. #4
    Jun 2007
    portland, or
    1,462
    W56= 22RE toyota or AX5 4 cyl jeep
    R150= 3.0V6 toyota or AX15 6 jeep
    These trannies are all built by Aisin. They aren't a bad design, but they are made for lightweight low torque handling.
    I'm sure by your post you've been told this, but you will snap one of these up inside with 4BT torque. They are not made for much power at all.
    5th gear is the weakest gear in the R150/151/AX15. I've seen many new 3.4 V6 R151 5 speeds shear the countershaft off clean right at 5th gear. IMO the 3.4 has a big lack of torque and it is braking toyotas beefiest mini truck tranny.
    If I had to do it I would buy a SBF-toyota conversion bellhousing for an R150 and use the cummins-ford adapter. You can use the GM setup too, but you'll have to deal with an 8 degree tilt (not going to go well in a small truck).
  6. #5
    May 2008
    Mesa, AZ
    1,251
    22
    My question is why you want to retain the Toyota trans? The ONLY reason I can see is if you have a bunch of money invested in a Marlin Crawler. If so, Advance Adapters makes adapters to go from various Ford and GM standard transmissions to various Toyota transfer cases in either 21 or 23 spline versions. I don't know for a fact if they will allow a Marlin Crawler to bolt up to them, but it is worth investigating, if that is your reason for wanting to keep the Toyota trans.
    1991 V1500 Blazer (Silverado), 5.9L 12V P-pumped Cummins (5x .012 sac injectors, #6 fuel plate, WH1C with external 38mm wastegate running 30psi), NV4500 with 1-⅜" input shaft, SBC Con-O clutch, NP205, HAD, 4.10 D61/14BFF spinning 35" Mall Terrains
