some half-tracked jeeps were tested in the wwII
but just one remained
its drivetrain without the tracks - look how weird it is
with the tracks
with the tracks
With rubber tracks mebbe. Kind of overkill for street. Waste of money. On off road use or military. Tracks actually decrease fuel consumption on soft terrain.
"From each according to his ability to each according to his needs." Karl Marx
Are you supporting the proper number of people who can't/won't work?
2009 VW TDI 6 speed DSG: Yanmar 2210
1972 Ford 3/4 Ton Camper Special - getting F4L 912 and Fiat Fivespeed
1984 1/2 ton F150 gettin Deutz F5L 912 and Fiat 5 Speed
1996 Honda Accord EX 5spd. Getting Prelude H22 JDM engine
I guess if you have a lot of crumbling roads.... Maybe in 2012.
I have one of the bulldozer which I do add rubber pads on the tracks and have no issue to drive on road but sure it will be pretty noisy but work the best in wintertime.
To put the rubber pad on it will take couple hours if you are good on that little over 400 pads on both tracks.
Merci.
Marc
Pas de problème,il marche n'est-ce pas?"(No problem, it works doesn't it?)
Could you imagine those rubber tracks at 70 mph?
http://formspring.me/kamikazeondrugz
http://cripplerooster.blogspot.com/ - if you can't read in portuguese (or even spanish that is closely simillar) use the google translate
