How to remove the front timing cover?
Results 1 to 7 of 7
Thread: How to remove the front timing cover?
    '69 FJ55 Land Cruiser dieselcruiserhead's Avatar
    Jan 2007
    Park City, Utah
    1,660
    Default How to remove the front timing cover?
    I was thinking of pulling the front timing cover off to get some of the old paint etc off.. What's the technique for getting the gears off the cam shaft and crank? Is it a bitch/requires puller? I figured it would be in the manual but alas their down at the shop...
    thanks,
    andre
    1991 Toyota Pickup, Mercedes 300D OM617 diesel
    1969 Land Cruiser project in progress with 4BT
    1989 Land Cruiser project in progress with 4BT
    2010 KTM 450
    Successfully installed 4BT, Isuzu 4BD1T, and Mercedes 300D engines into different vehicles.
    Vendor CrewCab59's Avatar
    Jan 2007
    Knoxville,TN
    4,087
    Here is what's needed to pull the timing housing.
    1. Oil pump.
    2. Injection pump and gear.
    3. Cam ,lock down plate and cam,the gear is pressed on.
    Just pull the came out and you'll want to reseal the lifter valley pan and ways .The I/P will need a puller.The housing will just unbolt and clean and install the gasket.
    Scott
    Registered User ambulancechser's Avatar
    May 2008
    edmonton,alberta
    1,253
    3
    unfortunately,the only 4b camshaft that came with a bolted cam gear is (i think) about a 91/92 (??),with an inline pump...all others are pressed on,with the gear being heated.you'll have to pull your cam.
    as for the crank gear,i believe it's also a heated press fit.i don't recall exactly,but i believe you can't even get a puller on it with the gear housing in place.don't know about your skills,but heating and precise press fits of gears are out of range for most home mechanics...it certainly is for me.
    it all seems like a ton of work for paint...
    currently modding an 86' m-1010 cucv ambulance,with factory 14-bolt/detroit in back and an open 60 in front.lifted 6 inches,running 37's on 17 x 8's.now swappimg in a mild 6bt,and an nvg-4500/np205 combo.hope to have it running by fall.
    link to engine build... http://www.4btswaps.com/forum/showth...n-engine-build...
  5. #4
    Jan 2007
    Knoxville,TN
    4,087
    The timing housing has a large open section ,so the crank gear has no problems with the housing and the crank can stay.
    Scott
  6. #5
    Jan 2007
    Sioux Falls, South Dakota
    1,068
    To pull the IP gear I use a cheap ass Advanced Auto parts steering wheel puller and two of the intake horn bolts...
    1989 D250 CTD, 727HD, D70/3.07, BHAF, DIY Cold air, Tuned VE, 4" exhaust
  7. #6
    Jan 2007
    Park City, Utah
    1,660
    I got the IP and the power steering, oil pump etc all out. The engine is a '89 so yes its press fit in as I imagined. Don't want to particularly pull the cam (but might while I'm in there doing the bearings)
    So such is life a lot of work for paint indeed...
    2010 KTM 450
  8. #7
    May 2009
    Santa Cruz, CA
    13
    Are you talkin about pulling the cover or timing case? The cover is easy, the case requires removing the gears.
