chevy colorado swap?
Results 1 to 8 of 8
Thread: chevy colorado swap?
    New Registered User
    Dec 2009
    Canada
    2
    Default chevy colorado swap?
    Anyone have any info on converting an 05 chevy colorado to diesel?
    I'm wondering if trying to gather all the parts (if available) from an isuzu dmax would work, or would a cummins 4bt be a better options.
    Any suggestions?
    Nov 2008
    Stony Plain Alberta
    2,936
    1
    put a duramax with an allison in it. That would be sweet.
    Registered User sailed2japan's Avatar
    Apr 2008
    Austin, Texas
    422
    Good luck getting that combination to fit. I know that they offer a version of the colorado overseas with a diesel. I'd look into the motor they put in the Holden Colorado and try to source one states side.
    Jonny 1983 C-20, 2wd, 6bt, Getrag (sold); 1966, C30 Flat Bed, Cummins in Progress; 1992 Honda Accord
    "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
    -AEC Hundley USNR
  5. Remove Advertisements
  6. #4
    Aug 2009
    5,463
    an isuzu engine seems to be the easiest option... in latin america the dmax is offered with some 2.5 and 3.0 diesel engines... maybe a b3.3 can be enough if you prefer a cummins... so, will you use an automatic gearbox?
  7. #5
    May 2009
    USA
    2,588
    Most think the manual is more fun.
  8. #6
    Aug 2009
    5,463
    Quote Originally Posted by DieselSchlepper View Post
    i just don't like to use the clutch pedal, specially starting uphill driving... but manual usually allows better fuel economy...
  9. #7
    New Registered User
    Dec 2009
    Canada
    2
    Sounds as though going with a manual tranny could eliminate some computer communication problems...?
    I've been trying to find a way to purchase a salvaged or parts from one of the dmax's or holden's, but no success so far.
    Thought the cummins route might be better since I don't mind ending up with a potentially simpler truck (only need a speedometer and gas gauge).
    Just not sure where to start in regards to parts.
  10. #8
    Aug 2009
    5,463
    Quote Originally Posted by greenhome View Post
    it's easier, but an automatic isn't impossible to fit... i saw some diesel silverados in brazil using the 4l80e with modified torque converter and reprogrammed module...
