Please mention 4BTswaps.com when calling // Site Info & Advertise with Us
Results 1 to 8 of 8
Thread: Isuzu 4H Series Introduction
    Apr 2009
    NEPA
    248
    Default Isuzu 4H Series Introduction
    Since there isn't a specific area for the newer engines, I posted this here. I'll cite reference where I can. Most of the following information was pulled from the following thread:
    http://forum.ih8mud.com/diesel-tech-...4he1-swap.html
    Manual with specs here:
    http://lilaw.info/images/Manuals/LG4H-WE-9691.pdf
    Also some pictures and info here (I revisited this and you need to register to view the post):
    http://www.aulro.com/afvb/isuzu-land...onversion.html
    Thanks to member astr for digging the info up. Please let me know if there should be corrections or if you have additions.
    4HE1-TC Basic specifications:
    Cylinders: 4
    Injection: direct
    Injection pump: Bosch inline type with automatic timer
    Displacement: 4.75L (289.75 cu in)
    Bore: 110mm (4.33 in)
    Stroke: 125mm (4.92)
    Valves: 2 per cylinder
    Inlet manifold ?
    Exhaust: RHS (drivers perspective).
    Weight: Approx. 365Kg (803lbs)
    Dimensions: 833.3H X 699.8W X 1181L (the length may be incorrect. Member astr has measured 30" from fan mount on water pump to tail which is nearly identical to the 4BDx series)
    32.8"H x 27.6"W x 46.5"L
    Bellhousings: ?
    Starting aids: ?
    Electrical: 12v in US market
    Turbochargers: Garret GT226?
    Alternator: 12v (US market)
    AC Compressor: ?
    Power output:
    Automatic -175 hp (130.6 KW) @ 2700 rpm
    Manual - 142 hp (106 KW) @ 2800 rpm
    Torque output:
    Automatic - 347 ft-lb (470.5 nm) @ 2000 rpm
    Manual - 275 ft-lb (372.0 nm) @1300 rpm
    Boost: ?
  2. #2
    Jan 2007
    New Zealand
    2,695
    I've split this 4HE1 introduction to a new thread for information on these and other Isuzu 4H series engines.
    Isuzu 4BD1T Junkie.
  3. #3
    Jan 2007
    Michigan
    391
    Default 4H Series Idiosyncrasies
    Unlike the 4B series, the 4H is turned around – the gear train that drives the cam, IP, oil pump and PS pump is located between the 4th cylinder and the flywheel.. As a result, there is no access to the flywheel from the front of the engine, so Isuzu chose to use a rear mounted starter that mounts on the left side of the engine above the transmission. This has some significant implications when trying to swap this engine into a conventional truck – the starter is going to conflict with the body sheet metal.
    Unlike the 4BD Series, the 4H have gear-driven overhead cams. The 4HE1 has two valves per cylinder; the 4HK1 has four valves per cylinder. The 4HE1 has an in-line injection pump similar to the 4BD Series while the 4HK1 has an electronically-controlled fuel rail injection system. The truck version of the 4HE1 with automatic was rated at 175 hp while the 4HK1 was rated at 195 and latter 205 hp. (Automatic versions). For some reason, Isuzu always derates their engines when fitted with manual transmissions. The 4HE1 came primarily fitted with Aisin AW450-43LE 4-speed automatic transmissions (4th was O.D.) The early 195 hp versions of the 4HK1 also were fitted with the AW450 transmissions while the latter 205 hp versions came with the Aisin A465 6-speed automatics. The A465 is the same transmission as the AS68RC used in the newer 3500 and larger series Dodge trucks.
    The bottom end on the 4H Series consists of a single casting sort of resembling a ladder so there is no way to pull an individual crankshaft bearing cap; the whole bottom end must be removed as an assembly. Isuzu claims that this design results in a much more rigid bottom end.
    There is NO interchangeability between the truck 4BD and the truck 4H Series with respect to transmissions. The 4H series were and still are available in marine and industrial versions so SAE-type bell housings are available.
    Andy
    Stock FJ62
    SOA Samurai Tintop
    Ford E-350 4x4 Diesel
    M-29 Weasel
    Misc. NPRs and diesel engines(4BD1T, 6BD1, 4BD2T, 4HE1TC,4HK1TC, 7.3 PSD, 6.4 PSD)
  4. #4
    Jan 2007
    New Zealand
    2,695
    Apparently there are industrial 4H series engines with front mounted starters. If anyone has information on these, please post it up.
    Isuzu 4BD1T Junkie.
  5. #5
    Jan 2007
    Michigan
    391
    Quote Originally Posted by Dougal View Post
    There is a discussion on industrial versions of these engine here along with some pictures: http://www.4btswaps.com/forum/showthread.php?t=9184
    Andy
    Stock FJ62
    SOA Samurai Tintop
    M-29 Weasel
  6. #6
    May 2009
    USA
    1,410
    I've never heard of a japanese manufacturer derating the engine on a standard shift. Why do you think. How do they do it - cam changes?
    "From each according to his ability to each according to his needs." Karl Marx
    Are you supporting the proper number of people who can't/won't work?
    2009 VW TDI 6 speed DSG: Yanmar 2210
    1972 Ford 3/4 Ton Camper Special - getting F4L 912 and Fiat Fivespeed
    1984 1/2 ton F150 gettin Deutz F5L 912 and Fiat 5 Speed
    1996 Honda Accord EX 5spd. Getting Prelude H22 JDM engine
  7. #7
    Jan 2007
    New Zealand
    2,695
    Quote Originally Posted by DieselSchlepper View Post
    Derating is really easy, they just dial back the maximum fuel delivery a little. It's quite common on diesel cars now to see the torque curve has been chopped to give a flat maximum torque to prolong drivetrain life.
    Isuzu 4BD1T Junkie.
  8. #8
    Jan 2009
    Ne
    68
    Does anyone offer a "tuning box" or any other performance increase for the 4hk? Driving an NPR, it feels like they 'derate' the engine in 1st and 2nd gear. It could be my imagination but a few of my friends thought the same thing. Being a 5.2l 16 valve engine, there has to be more potential.
    91 Toy Ext-Cab SAS on 37's Undergoing Heart transplant! Cashhole!
    87 Breadvan NOW just a storage unit. Heart Donor
    81 Nut Van 4bt plus next month's beer cans
    03 Jetta Wagon TDI
    81 MB 240D (Beirut Taxi) Should I put a 4b Here?
    88.5 Samurai 240D DI powered
  • You may not post new threads
  • You may not post replies
