This truck is finished, and is has been my daily driver for awhile now, but I figured I'd post it up here incase anyone had questions, or needs pictures.
The truck is a 2001 F-350 4x4
The engine is a 2005 commonrail cummins - 325HP. 13,250 miles on the engine.
The drivetrain is completely ford, ZF6 6 speed manual, and stock transfercase.
Ford-cummins.com adapter was used to mate the engine/trans. After seeing both adapters, I would have used the destroked.com adapter instead though. The Ford-cummins.com adapter required quite a bit of material to be removed from inside the transmisssion bellhousing. The destroked adapter does not require this.
All factory gauges work perfectly, and the signal wires to the OBDII port have been connected, so the scan port works. The dodge engine harness was used, and spliced into the ford harness. I still need to figure out the battery temp sensors, as I don't have them hooked up, and they throw a code.
Since the engine is an 05, there is no APPS on the engine, its on the pedal, so a bracket was fabricated to use the dodge gas pedal in the ford truck.
Ive only got a couple of issues left to figure out, the cruise and A/C. I took the truck by the local Air conditioning place, and they told me if I drop it off, they can make me custom lines for $250 or so, but I'll have to hook the electronics up myself. No big deal. But the cruise is a bigger issue, I don't think the ford cruise buttons will work with the dodge software, so I'll have to figure something out with that.
I've installed a Bullydog PMT, and the extra power is great along with the added gauges.
Other than that, its been great, I've driven the truck from colorado springs to detroit and back twice since its been finished.
If anyone is thinking about doing this swap, and needs pictures or info let me know!
