Deutz cold starting manifold heaters.
Results 1 to 15 of 15
Thread: Deutz cold starting manifold heaters.
    May 2009
    USA
    2,588
    Default Deutz cold starting manifold heaters.
    How do the flame heaters work? Is the fuel supplied from the return line? Can any grid heater be made to work. I'm trying to get a mental pic of these systems. I bought the parts manual but it's not super clear.
    Nov 2008
    UK
    34
    On the two deutz motors we have here, there is a small tank high up filled by the return line on its way back to the tank, with a solonoid valve on the outlet below it.
    You preheat the plug, which opens the bi-metallic valve in it, then when you turn to crank the solonoid opens & allows fuel to flow to the plug and whooosh!
    May 2009
    USA
    2,588
    That's how my 2 cylinder Yanmar works I think. Small high tank and a small heater in the intake. Really simple little thing. Makes smoke. Sometimes I spray penetrating oil into the hole and you can smell the difference in the exhaust. Can I adapt a simple thing to a 4 cylinder Deutz?
  5. Remove Advertisements
  6. #4
    Nov 2009
    arnaudville la
    39
    on my F5L912 it comes off the injection pump to a selenod then into the intake
  7. #5
    May 2009
    USA
    2,588
    hello freedeutz: that makes the most sense. I haven't been able to inspect mine yet. My F4L 912 has nothing that I can see.
  8. #6
    Dec 2010
    TX
    32
    I have a F8L413F from an air compressor that had the system intact. There are 3 relays.
    1. You press and hold the pre-heat button and it energizes a bimetal spring as a timer, and the electric heaters on the flame plugs intake manifold.
    2. When the bimetal spring makes contact it energizes the 2nd relay which sends power to the solenoid on the fuel pump, which in turn allows fuel to go the "flame plugs" on the intake. Since the fuel pump is on the injection pump, no fuel will actually flow until you crank the engine. There is also a light connected to this, to indicate the system is ready to start.
    3. You crank the engine while continuing to hold the preheater button. When the engine fires and starts running you let go of the button.
  9. #7
    Aug 2009
    5,463
    i have seen some manifold heaters that have the diesel supplied not by the return line, but by an auxiliary line plugged to the diesel filter...
  10. #8
    Dec 2010
    TX
    32
    This has an electric solenoid right on the injection pump. That way the manifold heater doesn't need its own pump and also you can't flood the engine by accidentally turning on the pump without the engine running. Also the timer spring will prevent you from sending fuel to the heaters before they warmed up enough to actually burn the fuel (instead of just dripping it in the manifold). It's pretty nifty.
  11. #9
    Nov 2009
    arnaudville la
    39
    so..... how did i go about rigging this system up for use in a truck that it wasn't intended for? It appears the fuel line comes off the injection pump, and runs to a selenoid, which i would assume when energized releases the fuel to the little flame thingy in the intake manifold. My question is do i run both the selenoid and flame thingy off the same push button circuit? Push the button, the flame thingy heats up, and the selenoid opens, but since the engines not running no fuel is delivered to the flame thingy. Count to 5 i guess then crank it over, WHOOSH!, right? yes/no? Also what guage wire should i wire this up with, fuse size? I know the grid heater wires on my 99' cummins are quite beefy.
    99' dodge diesel 4X4,
    1970 dodge D-100, getting a F5L912 deutz repower
    53' allis chalmers CA
  12. #10
    Dec 2010
    TX
    32
    you'd send power to the flame plug for some time before sending fuel to it, so it has time to heat up. It doesn't need to be a big wire, the OEM wire on my deutz looks like a 14 gauge or so.
    The cummins grid heater gets all its power from electricity so it needs a big wire. The deutz heater only uses a small glow element to start a flame, and the fuel / flame generates the real heat.
  13. #11
    Mar 2010
    concord, nh
    41
    Tractor Supply has these little plug heaters for less than $30.00 most of the time in stock. They were invented by Lucas in England and have been used by many makers. We had one on a Long (other blue tractor) and it was hooked to the fuel return line without a tank. Tractor would start every time with a good battery. You could also keep the heater on with the engine running at an idle when first started to help it warm up for a minute or so. Just installed one on a Detroit 2-53 (pictures to follow).
  14. #12
    Dec 2010
    TX
    32
    That's way cool, I'll take a look at that. Any diesel without a starting aid has its limits. Of course here in the south the most you'll need is an occasional whiff of ether.
  15. #13
    May 2009
    USA
    2,588
    Quote Originally Posted by castirondude View Post
    How long do you juice it? THe book says two minutes. I've been juicing it till a flame shoots out from residual fuel I guess. My Deutzmen say use 10 guage. Why scrimp? Heavy wire less resistence.
  16. #14
    Dec 2010
    TX
    32
    The gauge of wire you need depends heavily on how far you want to run. In this particular machine it only ran about 2' from the engine, and maybe 3' in the engine. Yea, I agree 10 gauge is a good way to go.
  17. #15
    Aug 2009
    5,463
    i already prefer an all-electric grid heater... btw has anybody here already used those flame-driven heaters with pure vegetable oil?
