cummins 4bt truck with manual trans?
Results 1 to 8 of 8
Thread: cummins 4bt truck with manual trans?
    New Registered User
    Feb 2010
    pennsburg pa
    2
    Default cummins 4bt truck with manual trans?
    Hey guys Im knew here and i got a headache from searching the forum for past couple hours. I been looking for a bread truck with the 4bt to do a swap most i see are automatics. Is there any that come with a manual trans? i wanna put a zf 5 behind it but just wanted to see what im getting into or if they were even made with manual trans Thanks Phil.
    Oct 2009
    miles city/Havre MT/ Around
    734
    22
    yes mine came with a ford t-19 butt theres a lot you can pick from good luck
    Vendor CrewCab59's Avatar
    Jan 2007
    Knoxville,TN
    4,087
    Yes, The ford chassis used T18,T19 and Np435 . They were the 12-14 ft vans that were bread/cup cake vans.
    The Gm chassis used sm465.
    Scott
  5. Remove Advertisements
  6. #4
    New Registered User
    Feb 2010
    pennsburg pa
    2
    Thanks ill be searching even more now, So the ones with the ford manual transmissions are ford bread vans? or are they grummans? Im a powerstroke guy so dont know alot about the cummins yet, But its gonna be going in a 49 f-6 dump truck, I liked the 4 instead of the 6 since it will fit in nicer, It should have the power to push it right? I saw the guy on the board whos putting one in his 1947 ford dually and looks really nice just i know theses are not big power producing engines but can make some more hp with a couple mods, Is there any certain year engine i should look for?
  7. #5
    Jan 2007
    Knoxville,TN
    4,087
    They were most in kurbmaster,unimaster and some olsons.
    Scott
  8. #6
    Mar 2008
    Green Bay, WI
    2,081
    16
    Quote Originally Posted by wheelie31 View Post
    Thanks... the 49 F6 is a perfect canidate for a 4BT...... a simple turbo mod and an intercooler and you'll be where you want to be. P-pump'd 4BT's are probably the best... but my VE pump still is stout... (hell of a lot better then a gas guzzling big block or the old flat head that sat there.
    1967 Kaiser Jeep 5/4 ton M-715 4x4
    12 Valve/ ZF 5 / NP205 Twin Stick
    Dana 60 Kingpin / Sterling 10.25
    **OLD**1947 Ford 1.5 Ton DRW
    Cummins 6BT P7100 - HE341 Turbo
    Eaton Fuller RT-6610 10 speed - 4 Link Rear / IFS
  9. #7
    Dec 2009
    Houston
    78
    My bread truck (a Ford) came with a Borg Warner. I am planning on pulling it this weekend, if you decide to buy one (a transmission, not a truck), PM me.
    There is nothing like the warm glow of burning bridge.
    Hung like Einstein, Smart as a Donkey
  10. #8
    Feb 2010
    Memphis, TN
    582
    6
    I bought a Ford Step Van yesterday morning here in Memphis. It has a 4BT and a manual transmission --- I'm not going to be using the transmission, so if you want it, shoot me a PM. I've not driven the truck yet; however, it was being driven until a year ago --- they just didn't need it anymore, so they parked it.
