Big Rig Cab on 1 ton frame
Results 1 to 20 of 20
Thread: Big Rig Cab on 1 ton frame
    Oct 2007
    N/A
    202
    Default Big Rig Cab on 1 ton frame
    Has anyone put a big rig cab on 1 ton truck chassis? Did you have to modify the cab, like make it shorter or narrower?
    Dec 2007
    southern mn
    12
    Hi, I have seen several such rigs. The older Peterbilt, KW, etc cabs are smaller than most modern pickups. Just make new cab mounts for your chassis to lone up with the cab. Now the real work comes to cut down the front end assy (hood & fenders) to make it look right. There used to be some front end kits available. Search the internet. One name that comes to mind is little big rig. Brad.
    Oct 2007
    N/A
    202
    Maybe it would be better to put the cab on a 1 1/2 ton chassis those wheels should fill the wheel wells. Might not have to do too much hood / fender mods.
  5. #4
    Aug 2009
    5,463
    would be cool to use a 1 1/2 ton frame with a big rig cab to mount a motorhome...
  6. #5
    Oct 2009
    Escondido ca
    16
    lilbigrig.com/Home_Page.php
  7. #6
    Oct 2009
    Escondido ca
    16
    (mystarcollectorcar.com/3-the-stars/star-truckin/476-the-kenworth-that-thinks-its-a-1919-chevrolet-dually-one-ton-truck.html)
    place a www in front of this link
  8. #7
    Oct 2009
    Escondido ca
    16
    one more
    thedieselpage.com/readers/vanwinkle.htm
    Again place a www in front
  9. #8
    Oct 2007
    N/A
    202
    It looks like the Little Big Rig is actually a fiberglass cab designed to fit on a ford 2wd F250 chassis. I was thinking about using an old mack DM cab and hood.
  10. #9
    Jul 2009
    Arizona
    181
    1
    I always thought a B Series Mack would be cool on a 1 ton truck frame. I think being smaller they may have a chance at fitting:
    http://www.seriouswheels.com/pics-19...-yellow-sy.jpg
    D.
  11. #10
    Oct 2009
    Escondido ca
    16
    Quote Originally Posted by reverendd View Post
    D.
    That is sweet, I would put a sleeper on it to open up the cab for little more leg room.
  12. #11
    May 2009
    USA
    2,588
    That's really unique. What years are the B series? Does the original engine work or would you 6bt or 6ct?
  13. #12
    Jan 2007
    Paisley, Pa USA
    3,997
    11
    Quote Originally Posted by cRiPpLe_rOoStEr View Post
    I like part of this idea...A salvage yard school bus medium duty 60 passenger size chassis shortened to the right wheelbase would make a good cheap donor for the chassis and drive line. I have seen 6BT busses sell in running condition for $1,000 and less depending upon the age. In a lot of areas they scrap them everyday because of the age requirement required by law. The most expensive part would be the body parts. I'm thinking that if you do some good shopping around this could be done for less than $5,000 not counting paint and labor.
    BobS
  14. #13
    Mar 2008
    Green Bay, WI
    2,080
    16
    See my build thread.... I took a GM Breadvan frame for my 1947 Ford 1.5 ton chassis.....
    1967 Kaiser Jeep 5/4 ton M-715 4x4
    12 Valve/ ZF 5 / NP205 Twin Stick
    Dana 60 Kingpin / Sterling 10.25
    **OLD**1947 Ford 1.5 Ton DRW
    Cummins 6BT P7100 - HE341 Turbo
    Eaton Fuller RT-6610 10 speed - 4 Link Rear / IFS
  15. #14
    Apr 2009
    Hong Kong
    80
    1
    Here's some examples I've found for such a truck. They are Peterbilt cabs and hoods mounted to Ford and Dodge chassis.
    Ford F-350 Chassis:
    http://truckaccessoryguide.com/2007/...-pickup-truck/
    Dodge 3500 Chassis:
    http://www.dieselpowermag.com/featur...ilt/index.html
    Ford Chassis:
    http://www.dieselpowermag.com/featur...ram/index.html
  16. #15
    May 2008
    MA
    109
    I really like the looks of that Dodge/Peterbuilt
    97 12v Ram 3000 gsk, 370's, dtt billet tranny and tc, straight piped and other pump tuning things
    '41 Dodge WC 4bt in the works
  17. #16
    Jan 2007
    258
    My father is in the process of doing this with an Internation Eagle cab on a Dodge Cummins 2500 chassis. Its a long term project but the cab is on, it needs some nose work and interior, and a custom body for the rear.
    I almost bought an old International cab for my Cummins Ram. I think it was an old 190. But I dropped the ball and someone else got it. I'll be looking for something else when I get back to work and get the money.
    Jim
    Milan, New Hampshire
    2000 Durango 4bt/NV4500 project
    4bt Durango Photo Album
  18. #17
    Jan 2009
    NE Ohio
    1,339
    1
    At one time when OEM or re-pop sheet metal wasn't as readily available for my '70 GMC 1 ton with 4-53T,I acquired a GMC General cab [aluminum] and hood [fiberglass] . The hood was too big
    and bulky and inner fender interfered with the steering in a trial fit . I ended up donating the stuff to an acquaintance in upstate NY who operated a General .
    B model Macks and KW/Pete are both very popular on pickup chassis .
  19. #18
    Apr 2011
    Middlesboro, KY.
    16
    I've already seen an R model Mack on a pickup frame. Looked great! He even had it rigged up so that the air brakes worked! Air over hydraulic that is. Never the less, it did'nt stay around long; He sold it for WAY less than what he could have gotten for it! It's a idea that's catching on! Better try it before they make some kinda new law against it!
  20. #19
    Sep 2011
    Washington,Mo.
    336
    My dad had a MiniBigRig that was a KW with the integrgateed 60in.stand up sleeper.Was on a F350chassie with a 5.9 cummins VE pump. with a nv4500.
    Dale
  21. #20
    Aug 2011
    Louisville,Ky
    28
    This is more all built from nothing but its sweet http://www.blastolene.com/pissd.html
