Diesel conversion Legalities?
Results 1 to 19 of 19
Thread: Diesel conversion Legalities?
    Jan 2010
    New York
    24
    Question Diesel conversion Legalities?
    Anybody here have any problems in NY registering a gas truck that was converted to diesel? Are there steps that I need to take beforehand? Things I need to get together? Any advice?
    Vendor
    Jan 2007
    New York
    808
    Depends on the year of the truck. Your not going to get away with dropping a B3.9 engine is say a 2000 Ram, no way, no how. If your going to drop a B3.9 in old iron, 1975 or older, no issues.
    Paul
    Jan 2007
    258
    There is also the mostly unenforced Federal law, which would pretty much eliminate swapping these motors into most, if not all, highway vehicles. The 3.9 was never EPA approved for use in light duty vehicles. It also doesn't meet the requirements of being either a "replacement" or "upgrade" engine. Replacement being an engine exactly like what was removed- removing a 5.2 from a Dodge Ram and installing another 5.2 is a replacement. Removing a 5.2 and replacing it with a similar setup 5.9 (which was optional for that vehicle) is an upgrade and is also allowed.
    Then there is an approved "swap". This means removing the original engine and replacing it with something completely different, but you must keep the emissions equipment from whichever is newer, the vehicle or the engine. You can put a 2000 Chevy V-8 into a 1974 Vega, but you would have to use the 2000 emissions equipment. If you put a 1975 350 into a '95 Camaro, you need to fit the Camaro's emissions equipment to the old 350.
    You also can't install a diesel into anything that didn't originally have a diesel. You could put a 2000 Dodge 5.9 into a 1985 Chevy diesel pickup, but not into a Ford Expedition because it never came with a diesel.
    Those laws are pretty much unenforced though, except in California. You pretty much have to worry about local and state laws. Here in NH we have a basic emissions inspection that just consists of plugging the inspection computer into the OBD-II diagnostic port to make sure there are no current codes. They only do this with 1996+ vehicles, 8500 lbs. GVW or less, and depending on year, some originally equipped diesels are exempt. Now that I can no longer do my own inspections (there are ways to fool the state computer) my 2000 4bt Durango will no longer pass.
    Just pointing out the fed. laws for those who don't know and may care. Most don't care.
    Jim
    Milan, New Hampshire
    2000 Durango 4bt/NV4500 project
    4bt Durango Photo Album
  5. Remove Advertisements
  6. #4
    Jan 2010
    New York
    24
    I was looking to swap out a 5.0 in a '94 F150 for a 5.9. Anybody from NY have any issues with this swap? Im running into silence from the DMV.
  7. #5
    '69 FJ55 Land Cruiser dieselcruiserhead's Avatar
    Jan 2007
    Park City, Utah
    1,660
    I would call until you find someone who can answer.. What nhdiesel said pretty much seems about right in my experience... Here in Utah it is almost a non issue and I recall from my 1990s and earlier when I lived in NY state that it was all pretty easy and basic and never had any emissions checks where I lived, if it helps...
    1991 Toyota Pickup, Mercedes 300D OM617 diesel
    1969 Land Cruiser project in progress with 4BT
    1989 Land Cruiser project in progress with 4BT
    2010 KTM 450
    Successfully installed 4BT, Isuzu 4BD1T, and Mercedes 300D engines into different vehicles.
  8. #6
    Jul 2008
    Southern Wisconsin
    631
    1
    In my experience, if you live where there are NO emissions checks, or where the emissions checks do NOT include a visual scan of components (sniffer only), then the rules are just:
    1) Same year or newer engine
    2) All emissions equipment for engine going in must be maintained.
    If you have emissions checks, especially with a visual scan, then it can get real complicated real quick.
  9. #7
    Jul 2009
    Arizona
    181
    1
    Some states have a rolling 25-30 year exemption on emissions too. In Cal when I swapped a chevy V8 into my 72 Z, it technically wasn't legal, but it wasn't smog tested so you could get away with it. I did ALMOST get busted once though on that, its very infrequent, but at the time they were running roadside test as sort of a survey (so they said), this was in about 99 or 2000. My wife called me and told me about it, it was near our house and had I get stuck in it, it would have probably have been problems. While the car was exempt, it still didn't mean I was not SUPPOSED to have the emissions hooked up. Needless to say in that hot rod it had nothing but a crankcase vent to the air cleaner. As I say thats very rare and in some states counties that don't have testing are probably never going to check it. That was in Cal. btw, but in your case as mentioned above, I sure would get more info before I put something in that got you in trouble.
    Regards,
    D.
  10. #8
    Jan 2007
    Paisley, Pa USA
    4,010
    11
    If you read the fine print of the EPA regulation it states specifically you must have all emissions devices in place that were originally EPA tested and approved for for that vehicle type & chassis that was a mass produced vehicle sold here in the USA. This would mean that it is illegal to transplant a 1982 6.2L GM diesel from a 1 ton chassis into a 1982 1/2 ton chassis because the 1 ton did not have the EGR valve. This would be normally be checked doing the visual inspection required in some states such as PA. According to the now retired head of our state inspections, if you install a 2010 engine into a 1985 chassis the engine must meet all of the unimproved emissions requirements of the vehicle as built and approved in 1985, not the 2010 specifications of the engine. I had a few conversations with that fellow and he was quite willing to teach anybody who wanted to learn.
    Attached Files Attached Files
  11. #9
    Mar 2010
    nor cal
    47
    I was wondering this also and i called the smog referee and was told that in california you can go bigger in engine as long as it is the same year and newer and has all the emmision equipment. it seemed odd that you cant go smaller.
  12. #10
    Registered User sirhannick's Avatar
    Jan 2008
    Barrington, IL, USA
    305
    Bob is right. My diesel conversion is 100% illegal. That is, if the EPA shows up and inspects my truck. However, when I got my emissions testing paper in the mail from the state of Illinois I managed to talk my way into getting it diesel exempt from testing. This is pure luck though, and even in the eyes of Illinois inspectors who REALLY know their vehicles, my truck is illegal. I only got away with it because it was a Dodge Ram and all 2nd Gen Rams look the same regardless of weight class. I'm using a 93' EPA certified engine in an 01'. Not legal....
    PS I hope the EPA or Illinois DMV doesn't read this....
    2001 Dodge Ram 1500 2WD 3.9L Turbo Diesel w/NV5600 <progress pics> <thread> (SOLD)
    166HP 4BT, Fuel Pin, 366 Spring, 4" SS Exhaust, HY35 (9cm2), 01' Ram I/C, 6spd NV5600
  13. #11
    Jul 2007
    Wisconsin
    144
    14
    After reading these posts, I'm realizing that my rig might not be as legal as was once thought. It was badly asumed that as long as the engine was newer than the vehicle, then the sky was the limit as to what could be dropped into the engine compartment. While we don't have any smog testing in western Wisconsin, I should still be vigilant for roadside test points during my travels in other areas as well as keep my nose clean with the State Patrol. There's no reason to draw any more attention than what is absolutely necessary.
    Thanks for clarifying this isue,
    Brian
    P.S. So would it be somewhat environmentally friendly to route the crankcase vent tube back up to my air cleaner inlet?
    1974 Plymouth Satellite Sebring Plus, intercooled 4bt, 224 gears in an 8.25 rear end, 3 speed 727 Slap Stik
    2003 VW Jetta TDI 5-speed overdrive (driven like it's been stolen by the Mrs.)
  14. #12
    Jan 2007
    258
    The good thing about the Federal requirements is that the official federal position is to leave enforcement up to the states as they see fit. It seems kind of needless to have strist federal laws if they aren't going to be enforced. Just leave it up to the states to decide. But officially, as long as you are legal for your state's laws, you won't (at this time anyway) have to fear any problems with the feds.
    Jim
  15. #13
    Jan 2010
    New York
    24
    Bump, looking to hear from any NY guys who've done this. Well, hoping to anyway....
  16. #14
    New Registered User
    Aug 2008
    upstate ny
    4
    If you regester it as 8600 GVW the emissions portion of the inspection is visual only (no plug in and check for codes) I've never seen or known of any one actually doing a visual check of emissions equipment. They all check the normal stuff (lights, brakes, E brake, ball joints, tie rods etc)
  17. #15
    Oct 2009
    Central Ca.
    13
    Just finished a 6BT swap into a 91 suburban. I am in CA. in what they call an "enhanced smog area". After 2 trips to the state referee, and a physical trip to the local DMV, I am offically a diesel vehicle, exempt from smog checks. Just got my vehicle tags yesterday. I was told that the vehicle must be at least 8600GVW or greater, because the original vehicle was rated at that (1993 dodge). All the original sensors and associated wiring, and computer must be installed. They even wanted the original contactors(relays) for the heating grid. The engine must also be the same or newer model year of the vehicle recieving the engine. I realize that I am in CA. not NY, but we have stupid smog laws, we even have a self appointed organization that creates laws, and is self funded by writing ticket!! They are called the "Air pollution control district". I read the laws, and made phone calls, before the swap. You must find the loop hole in the law. After all this, the state referee was impressed with the swap, and asked alot of questions about it. In the near future, according to the referee, the laws will be changing, so get the projects done and through the system quick.
  18. #16
    Mar 2010
    nor cal
    47
    I spoke with the referee here in livermore CA and he wold be the one inspecting the vehicle. He said the swap of a 5.9l from a 92 one ton into a 79 chevy one ton with a 454 would be ok. I made a lot of calls to get the answers bt this seems like the best way to go
  19. #17
    Jan 2007
    Park City, Utah
    1,660
    Does anyone actually have or has seen info on where it is it 'illegal' according to the EPA? I realize there is the vehicle size category issue (so your truck should be heavy if using a 4BT) but I feel this is a pretty minor technicality and if your state is OK with it then I feel that is fine. The EPA will never, ever enforce this.
    2010 KTM 450
  20. #18
    Jan 2007
    Paisley, Pa USA
    4,010
    11
    Quote Originally Posted by dieselcruiserhead View Post
    ALL Dodge Diesel optioned trucks were rated at 8510 GVW and above. This was part of the emissions requirements back in 1988 and why Dodge never installed a Cummins in a half ton or a heavy half ton/light 3/4 ton (5001-7500# class) pick up truck. At that same time gasoline engine trucks with a GVW of less than 8500 pounds were required to be equipped with similar emission equipment required on all passenger cars of that era. There has always been a set of emission requirements on all passenger cars and light trucks since the dawn of air injection reactor pumps and catalytic converters were installed. Also, bordering on politics which we won't go into, I would say "Never say never" with the current political group that we currently have in charge of things. To them anything other than a hybrid or battery powered vehicle is strictly a dinosaur that need replaced. The original EPA rules are attached to a prior post in this thread and are linked in the Tech Index.
  21. #19
    Jan 2010
    New York
    24
    I was at the DMV the other day taking care of some things, and I asked one of the people who work there this question. They didn't know offhand but asked their manager. The answer came back that there should be no problem whatsoever at the DMV, just show the reciepts from a shop showing the work done. It would have to be inspected though afterwards by a diesel shop when the reggie was up again. Sounding good.
