a/c bracket
Page 1 of 2 12 LastLast
Results 1 to 30 of 58
Thread: a/c bracket
    New Registered User
    Aug 2009
    Lakehills,Tx
    4
    Default a/c bracket
    I'm putting a "93" 6bt into a 1995 K-2500 with ifs and was wondering where to mount the a/c compressor.
    I need to move it from the bottom to the top. Does anyone make a bracket for this?
    Registered User B1jetmech's Avatar
    Jan 2007
    176
    You can try this bracket from the local Cummins dealer. I don't know the part number off the top of my head but this will locate the AC compressor up to help clear the frame.
    You might want to check to make sure the relocated AC compressor clears your oil filter, It should. This is how it looks on the 4BT.
    Nov 2009
    NJ
    10
    Go to Autoworld of MT website and give them a call they make a bracket to use the gm ac compressor in the stock spot and its not to expensive.
    Ryan
  5. Remove Advertisements
  6. #4
    Dec 2009
    Beaverton Oregon
    132
    I am looking for one of those brackets as well... anyone have one or a part number???
  7. #5
    Vendor rube bonet's Avatar
    Jul 2009
    phx,az
    502
    11
    this is in a 1988 blazer k5, but should give you a good idea of placement...
    the cast iron piece that bolts to the block is -- cummins 3930888
    compressor (and application) is 1995 ford f800 w cummins 6bt
    alternator is gm 22si, cummins pulley is 3918275
    lower alt mount 3930820
    tensioner is 3978021
    tensioner mt(stock)--3930838
    The alternator mt in pic I fabbed so I could keep stock dodge outlet, but stock piece looked just like it w/o hole, and no room for that style outlet
    The tensioner bracket I fabbed for more clearance, could have just knocked corner off stock piece
    The water inlet I fabbed to give me the most room, but I suppose I could have searched and found a short straight inlet, it was just faster for me to make one.
    The whole setup fits great, no frame notching (which is a terrible idea on the 1/2 ton chevys or blazers IMHO), no body lift, fits under hood with lots of room.
  8. #6
    Jan 2008
    Texas Hill Country
    494
    Any Chance you can post the Sanden Model number of that Compressor?
    Quote Originally Posted by rube bonet View Post
    The alternator mt in pic I fabbed so I could keep stock dodge outlet, but stock piece looked just like it w/o hole, and nor room for that style outlet
    " I drank what?" - Socrates
    1986 Jeep Grand Wagonner
    4bt/47rh/Np241
    Daily Driver unless im driving my VW THING
  9. #7
    Jul 2009
    phx,az
    502
    11
    SANDEN COMPRESSOR mod# U 46029 ser #002191306970--
    I also forgot to post O ring numbers for between block and plate, and plate and water inlet--3906697
    belt---serpentine 8 rib 72" long
    hose inlet that is supposed to go with these brackets, (90 degreee forward with downward swoop, didn't clear frame) 3921382
    I hope this helps, I spent quite a bit of time trying to track down all the numbers...cummins is a pain to deal with w/o an ESN, and all the other
    All this info should help quite a few conversions, will all work on a 4bt--probabbly just need a remote oil filter adapter
  10. #8
    Jan 2008
    Texas Hill Country
    494
    I searched Sanden for a U 46029 and they say that compressor doesnt exist. is it actually made by someone else?
    4bt/47rh/Np241
  11. #9
    Supporting Member scout4bta's Avatar
    Jan 2007
    Mesa, AZ
    2,179
    40
    Quote Originally Posted by Thinder View Post
    I think it was made for someone else. Probably a Ford part number?
    NRA Life Endowment member
    1980 Scout II:92 Dodge CAC, NV4500, 3.73 gears, Atlas 4.33,33/10.50 BFG KM2, HE221W 6cm2, 3200 GSK. Cold air intake. Mileage:low 20s to high 20s. The swap
    91.5 Dodge W250 CTD
  12. #10
    Jul 2009
    phx,az
    502
    11
    The sticker says Sanden & ford on it, was purchased thru ford dealership.
  13. #11
    Jan 2008
    Texas Hill Country
    494
    HEy thanks for those Part numbers! I saw the one from Ford, its a bit pricey!! I have an email in to Sanden with that part number to get some specs on it. And hopefully I can find some cheaper alternatives.
    4bt/47rh/Np241
  14. #12
    Dec 2009
    Beaverton Oregon
    132
    Thank you very much for posting the part numbers! Anyone have an extra laying around?? I need the 3930888 soon.
    Thanks!
  15. #13
    Vendor CrewCab59's Avatar
    Jan 2007
    Knoxville,TN
    4,087
    There are about 10 different compressors to chose from , the cost depends on what head the compressor has and if you want a top of the line Sanden or a aftermarket.
    Scott
  16. #14
    Jan 2008
    Texas Hill Country
    494
    I see. I dont need the capacity of the F800 compressor i dont think. I would opt for small over effeciency, since i have an under dash unit. What other compressors can you use? Ive been searching the Sanden website looking at guage lines and bolt pattern but there is no way to search other than part number so its kinda hit or miss.
    Quote Originally Posted by CrewCab59 View Post
    Scott
    4bt/47rh/Np241
  17. #15
    Jan 2008
    Texas Hill Country
    494
    Just got an email from Compressor Works in Texas. They say the Sanden for the ford f800 is 4602. Sanden says that is a vbelt compressor. waiting for a reply.
    4bt/47rh/Np241
  18. #16
    Jan 2007
    Knoxville,TN
    4,087
    All most sd7 compressor has the same mounting pads.
    The cheaper end compressors are $125 and up , the problem is the fitting are out the back and by the time you add a filter relocation kit than your at the same as the high end compressor.
    Scott
  19. #17
    Jan 2008
    Texas Hill Country
    494
    There seems to be a few differnet pad dimensions, even between Dodge truck years and the Guage line can vary quite a bit at least according to sanden's website. Im going to head over to a parts house today and dig through their catalog
    Scott
    4bt/47rh/Np241
  20. #18
    Jul 2009
    phx,az
    502
    11
    Please post up if you find a comparable compressor that works, esp if its more reasonable. I cringe at buying that kind of stuff thru the dealerships.
  21. #19
    Jan 2008
    Texas Hill Country
    494
    Wilco
    4bt/47rh/Np241
  22. #20
    Jan 2007
    Knoxville,TN
    4,087
    You can't use the dodge compressor ,without using a filter relocation . So yes they will have a different mounting pad.
    The P # are in the tech section.
    Scott
  23. #21
    Dec 2009
    Beaverton Oregon
    132
    I am still looking for one of those relocation brackets if anyone has one or could make something like it, I would sincerly appreciate it, pay shipping and give you some cash. Cummins wants $150 ish and that is a bit steep for my budget on this truck, which is already several thousand over and $14K to go... Please help
    Thanks!
  24. #22
    Jan 2008
    Texas Hill Country
    494
    1939,
    Thats how i feel too. Im still searching but raw data is hard to find. I looks like the 5.4liter triton F150 has an 8 groove pulley with a long guage line (PN 108225b but the mounting is all wrong) and they are cheap. Im about to build a bracket and say f*** IT. If thats where this goes Ill get them burned on the CNC Plasma and make a handful of them.
    4bt/47rh/Np241
  25. #23
    Jan 2008
    Texas Hill Country
    494
    OK here is what I have found. These are the essentials for the frieghtliner mount:
    Mounting Hole dimensions: horizontal distance between top holes: 87mm
    Horizontal distance between bottom holes: 92mm
    Vertical distance between holes (both are the same) 128mm
    Pulley Stick Out (guage line) : 49.00mm
    Sanden Part numbers that will work (there may be more but this is what i have found):
    4474 ---3/4X7/8 female connections on the side in the rear on head
    4417 & 4485 & 4818 -- Appear to be the same compressor all pad mount rear
    All are availble on teh sanden website for $386.00
    I will keep looking for more that are cheaper.
    It doesnt look like the Dodge ram compressor will fit this mount at all. The 1994 era wont bolt up and the 2000 era has the wrong guage line.
    All of this is based on sanden's drawings and i have not tried this in real life so take that into account.
    Hear are a few more:
    4432 --90degree pad mount
    4666 & 4667 -- 3/4X7/8 reer exit male
    4bt/47rh/Np241
  26. #24
    Jan 2007
    Knoxville,TN
    4,087
    Quote Originally Posted by 1939dodge View Post
    I am still looking for one of those relocation brackets if anyone has one or could make something like it, I would sincerly appreciate it, pay shipping and hive you some cash. Cummins wants $150 ish and that is a bit steep for my budget on this truck, which is already several thousand over and $14K to go... Please help
    Thanks!
    If that's steep than you'll want to look at a different set up becuase you'll need more than just the bracket for A/C.
    Scott
  27. #25
    Jan 2008
    Texas Hill Country
    494
    Might have found a break through.
    the sanden FLX-7 series. Its a universal customizeable compressor. it has its own pad with interchangeable connections, and electrical pigtails. Im talking to Cool Pro in Fortworth about getting one but they are about $160 bucks on Ebay. THey have 4 or so basic styles, and you customize the rest to fit your needs.
    I will fill you in as info becomes available.
    4bt/47rh/Np241
  28. #26
    Dec 2009
    Beaverton Oregon
    132
  29. #27
    Jan 2007
    Knoxville,TN
    4,087
    Tell me how the Hell do you get I was being a dick because I said there are cheaper ways than that set up . If you don't like the cost of the Cummins bracket then make your own because the compressor you have has the wrong bolt pattern.
    Scott
  30. #28
    Jul 2009
    phx,az
    502
    11
    Crew Cab, I assume you were not trying to be a dick in that reply... But sure sounded like one. If you followed my build thread you would see that I have the full AC and everything out of my 95 Ram that I am installing into the 39 Dodge. It is just a hunk of metal it should not be that expensive, although I know they are sometimes. To make one would cost under $50 in steel.
    Thinder let me know how it goes. I was just going to use the Sanden on that side.
    If you are referring to the cast piece on the block...the steel itself may be less than 50, but i would like to see the cost of someone casting their own 1 off piece (or replicating it out of billet or plate)...and selling it to you for less than 150.
    I thought that part was actually very reasonable, especially compared to cost/time fabbing up satisfactory replacement. I thought the plate steel brackets were a little spendy, but the only real expensive part was the compressor--and hopefully thinder will solve that issue.
    I myself am just looking for a used bracket--so if anyone has one, pm me
    I didn't think crewcab sounded like a dick, just realistic...
  31. #29
    Registered User tndonor's Avatar
    Jan 2007
    E. Tennessee
    329
    14K + and you cant fork out the 150 for a bracket. If you cannot afford the bracket, you cant afford the other ways Scott didnt post. You sir are the dick. If you ask for information and get answers, be thankful. These are not chevys where 55 vendors make the same part for $3.
    How about investing in exce lessonsl, learn to budget for all these things that come with a custom build, and not take it out on those who offer to help.
    Classy!
    1967 M715 6B NV4500 203/205 doubler HP60/14 4.56s with detroits.
  32. #30
    Jan 2007
    Paisley, Pa USA
    4,008
    11
    OK guys, NOBODY is going to be happy if the name calling doesn't go away. Clean it up NOW! We all know the rules!
    BobS
