ford starter
Page 1 of 2 12 LastLast
Results 1 to 30 of 31
Thread: ford starter
    New Registered User
    Jul 2009
    wi
    9
    Default ford starter
    the 7.3 ford starter bolts to the ford small block adapter with centering bushing.it is12 tooth pinion the cummins is 13 tooth.will it still work?
    Jan 2007
    N. AZ I-40
    2,252
    50
    I'm using a 3 hole from a f-600 on my bh adapter. It is 10 tooth. The pinion is in line with the mounting holes, not offset like the normal 13 tooth starters that the Ford BH adapter uses. I took off bell housing and checked gear lash and engagement just to make sure I wasnt screwing it up and would recommend anybody not using what starter was intended. to do the same. Just to be safe. I have heard people using 7.3 starters, but cannot verify myself. If this does work well please post. Early Bronco/4bts need this for frame clearance issues.
    New Registered User
    Jul 2009
    wi
    9
    I used a 94 to 00 7.3 ford starter with a 3.5x3.94x.44 bushing to center the starter.I blocked the pinion gear out & installed the starter on an engine on a pallet ,the gears meshed perfectly.Will run in truck tomorrow.
  5. The Following User Says Thank You to ferkey For This Useful Post:
    02TJ (05-22-2015)
  6. Remove Advertisements
  7. #4
    New Registered User
    Jul 2009
    wi
    9
    Started the engine several times today everything seams to work fine.
  8. #5
    Jan 2007
    Paisley, Pa USA
    4,043
    12
    For Future references, do you have the ID tag information on this starter?
  9. #6
    New Registered User
    Jul 2009
    wi
    9
    The starter is already on the truck . The application is f250 7.3 diesel 94 to 00.The starter is a 3 bolt & only the top & bottom holes are used.The solenoid sits no farther from the block than the outside of the starter motor itself.
  10. #7
    Jan 2007
    Paisley, Pa USA
    4,043
    12
    OK, let us know if it develops any issues as far as tooth meshing. I indexed this thread in the Tech Topics Index & was the reason that I asked. If I had the number I could cross reference it and provide all of the mfg part numbers & interchanges.
  11. #8
    Registered User wbdave's Avatar
    Aug 2009
    jersey shore
    495
    Quote Originally Posted by ferkey View Post
    ferkey can u post a link or some sort of #, im looking to replace my starter so i dont have to demolish my frame rail... theres 2 models ive found just want to make sure i get the correct 1. and if the bushing was an easily attained piece?
    94 Ranger 3.9L Cummins
    99 F-350 CC DRW 7.3L
    92 D-350 12V
    4BT-Ranger Build Thread
  12. #9
    New Registered User
    Jan 2010
    haskell ok
    8
    I have about 8000 miles on the same set up it works perfect. The pinoin is offset to make up the difference in tooth count.
  13. #10
    New Registered User
    Jul 2009
    wi
    9
    The starter was bought off e-bay the only #I got is 17578 don't know if that is a ford #. Just started driving the truck.The bushing I had to have made. The truck is a02 ranger 2wd with m5r2 &8.8 3.55 Lots of fun!
  14. #11
    Jan 2007
    Tardis
    2,859
    7
    Ferkey do you have any pics of your rig? Is it a torsion or coil spring suspension? I read that you did a 3" body lift, was this to clear the engine or trans? could you have dropped the engine a corresponding amt and avoided the body lift? Is your intake plumbing running across the top of the engine or ran forward to an IC? C'mon details man, details.
  15. #12
    New Registered User
    Jul 2009
    wi
    9
    I have coil springs &used a94 f150 5sd .I moved the trans mount back 3in &down 1in. The bell housing ,oil pan ,brake booster,steering shaft,steering pump,fan shroud & shift lever all cleared.I did'nt want to cut frame or pan so I resorted to the 3" lift.The intake pipe goes over the top.
  16. #13
    New Registered User
    Jul 2009
    wi
    9
    The starter #is motorcraft sa-817 ,denso 280-4204, mitsibushi m8t50071,&several others .I used the top and bottom bolt holes with a centering bushing.Everything seems to be working fine so far.
  17. #14
    Aug 2009
    jersey shore
    495
    i bought the one off ebay, 17578 or something like that. installed w/o a bushing, i have yet to start the engine with it...not to that point yet. i did engage it (manually) and it seemed to hang up a little on the disengage, im hoping it doesnt do that during normal operation but i guess ill find out lol
    92 D-350 12V
  18. #15
    New Registered User
    Jul 2009
    wi
    9
    It is a fairly sloppy fit without the bushing.I now have about 100 starts on mine and it is working fine.
  19. #16
    Feb 2010
    NJ
    210
    what exactly is this bushing for? is it hard to make?
    1989 Jeep Wrangler with 4bta zf5 np205 d30 front(posi-locked)ford 8.8 posi rear 4 inch suspension 3 inch body k&n intake 33's BFG AT pump mods
  20. #17
    Aug 2009
    jersey shore
    495
    i used the starter w/o the bushing and had no problems. started and shut down engine about 10 times with no problems of starter being stuck engaged.
    92 D-350 12V
  21. #18
    Dec 2008
    Steamboat Springs, CO
    48
    ferkey, do you have any pictures of this setup? I am looking into using the 7.3 starter right now. Is that starter 12v?
  22. #19
    Registered User treetopflyer's Avatar
    Jan 2007
    Yuma, AZ
    65
    1
    Ferkey...I have a question about the "3.5x3.94x.44 bushing to center the starter" you mentioned in #3. In my ignorance, I don't know what one is...can you elaborate further on it? Is there a part number or source for it? A picture would really round out this "Stickey. If the 7.3 ford starter is narrower that might save me cutting into my early Bronco frame too.
    69 Bronco, 01NB TDI
  23. #20
    Jun 2011
    Lecoma Heights, MO
    13
    3.5"=inside diameter, 3.94"=outside diameter, .44" =thickness
  24. #21
    Nov 2009
    NJ
    149
    I've got a 4bt sitting on a stand with the powerstroke starter bolted to it. I'll try to get some pics up later tonight, I dont know if I have enough post yet to post a link.
  25. #22
    Nov 2009
    NJ
    149
    Here you go.
    I used the stock spacer machined down. The starter was a tight fit into it, I had to sand the ID a little. It wasnt enough to have to machine it, just a few minutes with some emery cloth. I have to take a little more off the spacer still, it doesnt engage deep enough.
    I also cut off the third mounting hole, so it does stick out past the adapter plate.
  26. The Following User Says Thank You to snoranger For This Useful Post:
    GCW Matt (10-14-2014)
  27. #23
    Oct 2009
    miles city/Havre MT/ Around
    734
    22
    thats the starter I used on my 4bt with no spacer or mods.
    1989 ford ranger 4bt... standby for further details
  28. #24
    Mar 2008
    raleigh, nc
    14
    Just figured I'd ask, any idea if this will bolt to on the other side of the motor to a dodge adapter/nv4500??
  29. #25
    Oct 2009
    734
    22
    no for that you need the starter oun of a dodge cummins, but i cant think what year.
  30. #26
    Mar 2008
    raleigh, nc
    14
    Quote Originally Posted by lawnboy View Post
    no
    right you are. I had to see for myself because the pics I saw looked very close. Took one to the shop today and it bolted up nicely with all three bolts, perfect fit, did not protrude wide of the adapter. Problem, however, is twofold: 1) gear is about 4mm smaller and 2) gear doesn't reach deep enough into adapter to reach flywheel. Someone could probably make it work but not me.
    Just thought I'd pass along my findings.
  31. #27
    Oct 2011
    tacoma wa
    12
    Quote Originally Posted by snoranger View Post
    Here you go.
    are you talkin the stock cummins starter spacer
  32. #28
    Oct 2011
    tacoma wa
    12
    man I think im goona try that tomorrow
  33. #29
    Nov 2009
    NJ
    149
    Quote Originally Posted by LoCoFoMoCo View Post
    Yes I am.
  34. #30
    New Registered User
    Sep 2014
    Ewing IL
    2
    6
    Is this what everyone is using, or is there a better option now?
