4BT Chevy 1ton 4x4 4-link bagged X 4 Project
Results 1 to 4 of 4
Thread: 4BT Chevy 1ton 4x4 4-link bagged X 4 Project
    Apr 2010
    bellevue, Iowa
    345
    2
    Default 4BT Chevy 1ton 4x4 4-link bagged X 4 Project
    Hello everyone I'm Ryan and have been a member for only a month or so. I have been looking at everyones buildups and am impressed with the amount of inginuity that I see. I thought I'd start a thread on my project to keep track of it and hopefully avoid as many costly mistakes as possible.
    Apr 2010
    bellevue, Iowa
    345
    2
    here is what I started with.
    Apr 2010
    bellevue, Iowa
    345
    2
    My thinking of how to do triangulated 4-link in the rear.
    The lower bars will run from the front of the axle to the bottom of the plywood(3/8 plate) outside of it.
    The top bars will run from a truss to the inside of the framerail.
    pivot points will be on a vertical plane from one another, and the top bars will be parallel to the lowers.
    The lowers should be level at ride hieght.
  5. Remove Advertisements
  6. #4
    Apr 2010
    bellevue, Iowa
    345
    2
    Default It's alive
    Well I've come a long way. starting with putting off the original truck for a while. I now have a 85 1ton chevy cab-chassis truck 4x4 with a 10' flatbed (soon to be dumpbed). I started her up yesterday and wow talk about torque. Its snappy. and the sound puts a smile on my face every time i hear it. so...
    http://www.youtube.com/watch?v=JsqlYrQ9g5Q
    also look at my other videos for the initial startup.
    1989 K1500 4BT, 47RH, NP241C with NP231D input. http://www.4btswaps.com/forum/showth...ild&highlight=
    1993 C3500 Dually, Dana 60 Solid axle swap, 6BT, 47RH, 4.10's http://www.4btswaps.com/forum/showth...na-60-6BT-Auto
    93 deere 430 3cly yanmar diesel
    98 1840 case skidsteer 4B cummins
    The rest of my toys use gasoline.
