4bt rebuild kit
Results 1 to 3 of 3
Thread: 4bt rebuild kit
    New Registered User
    Apr 2010
    converse, tx
    6
    Default 4bt rebuild kit
    Where can i find a rebuild kit for the cummins 4bt? who has the best deal?
    Vendor CrewCab59's Avatar
    Jan 2007
    Knoxville,TN
    4,087
    I wouldn't be looking for the cheap cost , you need to look at the kit and see what's included and how the gaskets are made .
    I will say Cummins and cheap doesn't fit , build it right the 1st time and it will last.
    Scott
    Aug 2008
    northern nicaragua
    129
    yeah, what Scott said. The cheaper kits will be missing stuff that you should be replacing during a rebuild. This isn't the place to try saving money IMO.
    79 Ford F250 Supercab w/ 6BT VE, ZF 5.42, NP205. 3.54 gears HE351cw/hx55 compounded turbos, Hamilton 181/210 cam, 24v tappets, 60lb. valve springs, 4" straight piped mandrel bend exhaust. Hotrodded VE pump, +60hp injectors, custom 3" dual ram intake, ARP studs, Danin gauges.
