Jeep Cherokee VM to Isuzu Diesel conversion ?? Please help
Results 1 to 6 of 6
Thread: Jeep Cherokee VM to Isuzu Diesel conversion ?? Please help
    New Registered User
    Aug 2010
    Australia
    2
    Default Jeep Cherokee VM to Isuzu Diesel conversion ?? Please help
    Hi... I'm new to the forum and am feeling a little relieved to find that the forum exists. I'm hoping that someone can help with some tips on swapping out a dead VM diesel out of a 1997 Jeep Cherokee for an Isuzu 4JB1-TC, 2.8L turbo 4 cylinder engine. I haven't quite settled on which engine yet but it seems that the Isuzu is a good match to the jeep driveline. I've been told that it can't be done by a workshop but I can't accept that this is the case as the motor is mechanical and the few electrics that there are in a diesel must surely be able to be adapted. I'll be doing the work myself so that will at least make the project more viable. I have heard of a Mercedes 5 cylinder being installed into one of these but I'd rather stay with 4 cyl and later techonlogy. Can anyone tell me if there are any adapter plates available anywhere and if anyone has already done the conversion I'd be very interested to learn from the experience. Cheers & Thanks.
    Isuzu Diesel Innkeeper
    Jan 2007
    New Zealand
    5,088
    Is the jeep VM diesel any relation to the 2.5 VM diesel used in the 1985 rangerover?
    Isuzu 4BD1T Junkie.
    Aug 2009
    5,134
    in the philippines the isuzu 4jb1 is widely used to repower jeep wranglers, specially if fitted to the ax15 manual transmission...
  5. #4
    New Registered User
    Aug 2010
    Australia
    2
    I haven't seen the two motors together (i.e. Jeep & Range Rover VM diesels) but they both use the multi head 4 cyl VM of the era and they both seem to suffer from the sam over heating issues so I am making the presumption that they could be the same or similar. Hence the reason to repower to something else.
  6. #5
    Jan 2007
    New Zealand
    5,088
    Quote Originally Posted by patanga View Post
    If that is the case, there are kits from the UK to fit the 4JB1T to rover gearboxes, they might give you most of what is needed.
    Isuzu 4BD1T Junkie.
  7. #6
    Aug 2009
    5,134
    i remember a pushrod 2.5L vm motori 4cyl turbodiesel that was used in the argentinian-made cherokee and brazilian-made dodge dakota until 2001... this engine was not already a bad engine, but in the cherokee it had some problems related to head gasket burning...
  • You may not post new threads
  • You may not post replies
