3 cylinder cummins or 4 cylinder perkins
Results 1 to 22 of 22
Thread: 3 cylinder cummins or 4 cylinder perkins
    May 2010
    S.A.
    47
    Thumbs up 3 cylinder cummins or 4 cylinder perkins
    my uncle gave me his international scout 80,and i want to put either a 4 cylinder perkins in it or a 3 cylinder cummins in it.i figured out how to swap the perkins in the scout.i think the cummins bolt pattern is the same.im kinda for the cummins because it'll give me an excuse to put a cummins C on the scoutwhats yall opinion?what are the differences between them?
    HP
    torque
    bolt pattern
    measurements(length&width&height)
    cool factor
    weights
    ect....
    Aug 2009
    5,463
    are you considering a TURBO 3cyl cummins against a non-turbo 4cyl perkins?
    Mar 2009
    Chardon,Oh(cleveland)
    961
    I hope your joking about the c series.they weigh like 1600.And are you talking about the sae adapters for the cummins becasue its not the same bolt pattern
    4bta 85 dodge prospector shortbread
    TDC 75 HP sticks,hy35,big ass intercooler,6bt intake box w/ k&n,4" straight w/flow-through magnaflow.Oil filter relocation upgrade (ford 7.3d filter)HUGE!
  5. Remove Advertisements
  6. #4
    Aug 2009
    5,463
    Quote Originally Posted by dillenger1 View Post
    i thought he was talking about that "c" logo, instead of a c-series engine...
  7. #5
    Jan 2007
    Paisley, Pa USA
    4,010
    11
    Maybe first check the availability in your part of the world for both engines before you continue...
    BobS
  8. #6
    May 2010
    S.A.
    47
    i have the perkins sittin in my garage.i am talking about the cummins logo not c-series.and i can get a turbo for either.im putting scout 2 axles in it. http://www.solutionhybrid.com/jeep.w...ngine.at.30mpg
    1600lbs?its no where near that heavy.
  9. #7
    May 2010
    S.A.
    47
    whats the SAE# for the cummins?
  10. #8
    Aug 2009
    5,463
    Quote Originally Posted by deuce_09 View Post
    is it a 4-236? this is already a good option...
  11. #9
    May 2010
    S.A.
    47
    dont know the specs on it.and my uncle is fabbing up everything for the turbo.
  12. #10
    Supporting Member
    May 2008
    New Haven, CT
    459
    Why not use the Nissan SD33T, T-18, Dana 20 from a 1980 Scout II it would be a virtual bolt-in?
    1967 Land Rover Series IIA 109 Hybrid, it is STILL just a pile of parts, someday I may finish......
    Custom Chassis, Air Suspension, Rear Double Triangulated 4-Link, Front 3-Link
    Drivetrain: Taurus Fan -> 4BTA3.9 CPL 0986 Twins? (DeVito/Schwarzenegger style) -> NV4500HD -> Dana 300 -> Dana 44 Front and Rear
    Build-up thread on Pirate4x4 (before I found here)
  13. #11
    May 2010
    S.A.
    47
    i wouldn't even know where to start looking for a SD33T.
  14. #12
    Supporting Member
    May 2008
    New Haven, CT
    459
    There are a bunch of IH forums and they do pop up on Craigslist and other places.
  15. #13
    Registered User The Bladesmith's Avatar
    Jul 2008
    Oregon
    137
    They pop up becuse they are POS engines. No power, hard to find parts, etc. I Pulled an SD33 out of my Scout and would never go back!
    1978 Scout Terra, SOA, 31" Tires, Cummins 4BT, NV4500HD, NP205, 3.54 Gears
    The Project Never Ends.
    "A person can be smart, intelligent, ingenious. People... are stupid."
  16. #14
    Supporting Member
    May 2008
    New Haven, CT
    459
    Quote Originally Posted by The Bladesmith View Post
    I said SD33T, not SD33. There is quite a difference in power - a whopping 3 more HP. but it is a lot more drivable. Sure you're not going to hit 100mph, but I have hit 85mph in a Land Rover 109 hard top with the Scout II SD33T drive train without any problems. It also had no troubles towing a car on a dolly through hilly terrain.
    The proposed engines are much lower in power than even the SD33T, so I was making a reasonably easy and simple alternative suggestion. A 4BT is definitely better, but more difficult to fit. It also needs a transmission with an overdrive whereas the SD33T does not
  17. #15
    Aug 2009
    5,463
    instead of the nissan sd33/sd33t i would consider a cummins b3.3...
  18. #16
    Supporting Member
    May 2008
    New Haven, CT
    459
    Right, you can get that with the SAE #4 flywheel housing, not sure if the depth to the flywheel face is the same as the SD33T though. But I am not sure you'd want to use it with the T-19 that came in the Scout diesel. Look up Mooktank's B3.3 Explorer for some great ideas. http://www.4btswaps.com/forum/showth...ktank+explorer
  19. #17
    May 2010
    S.A.
    47
    So my uncle was at his house messin with the perkins. ( he's got a **** ton of bellhousings laying around) and after about 4hrs. He calls me and tells me to sit down. Lol then he tells me he has the scout 2 tranny bolted up to the Perkins!! So the next day I swing by his house to see how he did it and he put a tarp over it and told me to BACK OFF like I did something wrong?!? Lol he told me he don't have everything figured out yet and he don't want to get me all worked up about it for nothing. So as far as updates go, we have it bolted together but need to work out the kinks.
  20. #18
    Apr 2010
    wisconsin
    87
    Is either engine is a variable speed automotive engine.?? Or are they constant RPM power plants? That would be a big consideration. The Perkins is a four cyc and should vibrate less while running smoother. It will not take the abuse the Cummins will. Or put out the same power for that matter. That is as long as they are near the same CC's. If'n i was doing the pickin, I'd think real hard about a different engine.MM
  21. #19
    May 2010
    S.A.
    47
    This Perkins has a throttle like everything else but on a tractor it locks the throttle wherever you place it and tractors are super low geared. That's why you don't have a gas petal. When you put it in a truck, it's different. You can control the throttle with the pedal and it's not just staying at a constant rpm range. And the gears are super high copared to a tractor. So you'll use the clutch just like a pickup.
  22. #20
    Aug 2009
    5,463
    i have seen some tractors that had both a throttle pedal AND a hand-activated throttle that locks wherever it's placed... it's used in some military vehicles too, allowing them to have a minimum controllable speed about 4km/h, something around 2.5mph, the average speed of a man walking...
  23. #21
    May 2010
    S.A.
    47
    Look up deuce and a half ghost ride for laughs. Then for what you said about military vehicles having that, deuces I know for sure have what you talkin about. The pedal is for driving, and the dealio you pull out that locks the throttle is for ( I'm guessing) the pto's. Winch mostly. If anyone has driven a deuce, they know the pedal throttle is very sensitive and hard to keep at a constant rpm range when you have it in neutral to engage the pto. So they used the cable on the dash.( my unproven theory)
  24. #22
    Aug 2009
    5,463
    the auxiliary hand throttle command i've seen was not to be used with pto, i have seen it even in vehicles without pto such as some scania and volvo buses... in the case of those buses, once a driver told me that he could almost not use the feet while driving, using the retarder (as we call exhaust-brakes) and the hand throttle in the biggest part of the time, using the service brakes only when really needed to stop the vehicle instead of just reduce its speed...
Tags for this Thread
