95 Dodge cummins 3500 2wd with nv4500
Results 1 to 3 of 3
Thread: 95 Dodge cummins 3500 2wd with nv4500
    New Registered User
    Oct 2010
    Utah
    7
    Default 95 Dodge cummins 3500 2wd with nv4500
    I am currently looking at a truck that has everything I need on it..... well almost...... p-pumped 12v with all accessories still in working order. The truck has 145,487 miles on it and runs great. PROBLEM..... 2WD..... I am questioning the transmission and my ability to convert it to a 4wd application. I will be swapping this into a CHEVY and am looking to put an NP205 t-case in the mix. Is the 2wd nv4500 going to be useless to me due to the 31 spline output shaft or is there something I can to do remedy this problem cost effectively? I am totally open to any ideas or suggestions or even a link to an existing post on this site that I may have missed in the endless corridors of threads!!! Thanks for your time.
    Feb 2007
    Front Range Colorado
    618
    Quote Originally Posted by octobertide View Post
    May as well get it. If you are looking to mount a GM NP205 behind it, then you are going to have to replace the output shaft anyways, unless you are starting out with a GM NV4500, so it becomes a toss up. Do you buy a 4X4, and then swap out the output, or just convert yours to a GM output and tailhousing? Seems about the same either way.
    New Registered User
    Oct 2010
    Utah
    7
    Thanks for the advise! I will look into this further. I thought I was limited to the 29 spline dodge np205's from the gen 1 years. If I can use any of the chevy parts I will. Can this handle the torque from the cummins though?
