muffler for 4bt?
Results 1 to 9 of 9
Thread: muffler for 4bt?
    Aug 2010
    socal
    22
    Default muffler for 4bt?
    I've got a 4bt in a scout and its sttraight piped with 3" exhaust, I think I need to install a muffler because it is so loud in that steel can and just echos inside terrible. I plan on rhino linning the interior to dampen some of that noise, but my question is what kind of muffler will work best? anyone using a muffler?what are you using? thanks
    Isuzu reliability tester
    Jan 2008
    Burleson,Tx
    3,001
    I plan on running a dynomax ultra flow for the 3" pipe on my wifes isuzu 4bd1t powered jeep grand cherokee. Straight thru design but should help muffle a bit, I know nexxusian used one on his NPR truck with similar diesel engine and liked it.
    Nov 2008
    Stony Plain Alberta
    2,936
    1
    Any straight through design should work nicely. When I first did my swap, I hooked up my exhaust to my old 3 inch to a flowmaster super 44 muffler with dual 2.5 inch exits. I don't know if I got any vids or sound clips of it, but it sounded really cool. Then once I changed to a different turbo I went with 4 inch exhaust and straight pipe.
  5. Remove Advertisements
  6. #4
    Feb 2008
    Atlanta, GA
    107
    I don't know what level of "quietness" you are looking for but I am very happy with the stock muffler for a 6BT Dodge truck. It's a straight through desogn with 4" inlet and outlets. It's pretty quiet and available at most local part stores.
    1990 Fullsize Blazer with a 4bt and a nv4500
    See the buildups here:
    K5 Blazer (Done)http://www.4btswaps.com/forum/showthread.php?t=4970
    Military V-100 6BT Allison (In Progress) http://www.4btswaps.com/forum/showth...3206#post83206
  7. #5
    Jan 2007
    New Haven, CT
    1,288
    8
    On the highway, the roar of the engine, tires and wind noises drown any possible exhaust noises
    1963 Jeep J300, 4BT/NV4500/NP200/D61/D71
    1969 Jeep M715 6x6 project, 6BTA/NV4500/NP205/D60/D70/D70
  8. #6
    Supporting Member scout4bta's Avatar
    Jan 2007
    Mesa, AZ
    2,191
    40
    On my Scout I'm using a 24" oval magnaflow with 3" inlet/outlet PN:12279
    NRA Life Endowment member
    1980 Scout II:92 Dodge CAC, NV4500, 3.73 gears, Atlas 4.33,33/10.50 BFG KM2, HE221W 6cm2, 3200 GSK. Cold air intake & snorkel. Mileage:low 20s to high 20s. The swap
    91.5 Dodge W250 CTD
  9. #7
    Sep 2010
    BFE
    34
    I used a 3" in/out thrush muffler, all you here is the motor klak, klak, klak Much quieter than I expected... The exhaust anyway.
    87 YJ, 6.5L Diesel, THM 400 trans, hydroboost, axles flipped, wallet empty
  10. #8
    Supporting Member
    Mar 2009
    Southeast
    1,761
    161
    I used one of the Moroso 3" straight through mufflers,and it is real small in diameter and works in tight places!!!
  11. #9
    Jan 2007
    near baton rouge, la
    805
    Hearthrob 101
    1942 wc-53
    4bt/4l80e/compushift/np241
    dana 60/14bolt 4.88 38.6"tires
    http://www.4btswaps.com/forum/showth...highlight=Wc53
