Case 4-390
Results 1 to 15 of 15
Thread: Case 4-390
    New Registered User
    Dec 2010
    Connecticut
    4
    Question Case 4-390
    Hey im new to this forum but have been working on and with diesels for years, i wanted to do a 4bt swap in my 94 Zj and recently came across this Case 4-390 from what i understand scence its missing the 4"t"-390 its nn turbo but that there almost identical to 4bt's? I wanted to see what u guys could tell me ive scearced high and low and cant find much info on these motors thanks allot,, anthony
    Aug 2009
    5,463
    the 4bt was already developed in a joint-venture between cummins and case... this is essentially a badge-engineered version...
    Jul 2007
    TN
    1,107
    1
    its just a non-turbo 4bt.
    72 Scout d60/14blt, 4bta
  5. Remove Advertisements
  6. #4
    New Registered User
    Dec 2010
    Connecticut
    4
    awesome thanks allot guys. so whats the difference between this motor other then the turbo and compression ratio, what makes the compression lower? is it possible to turbo this motor?(pistons upper rings piston cooling nozzles or something?) will a 4bt intake manifold fit? i wana send the head out and have it checked/faced aslong as i kno i can use it, do u think a case dealer could tell me the year of it with the serial number? i ripped it down today ill have more pics tomorrow, i really appreciate the info
  7. #5
    Jan 2010
    Bristol TN
    36
    The non-turbo is higher compression. the piston cooling nozzles some non-turbo have them and some do not. It would probably be best to pull the pan and see if they are there, and if not remove the crank and install them before adding the turbo.
  8. #6
    Jan 2007
    New Haven, CT
    1,305
    8
    But what´s the cost (engine + turbo parts + your time) vs buying a turboed version?
    1963 Jeep J300, 4BT/NV4500/NP200/D61/D71
    1969 Jeep M715 6x6 project, 6BTA/NV4500/NP205/D60/D70/D70
  9. #7
    May 2009
    USA
    2,588
    I'd use it the way it is. It should run pretty good. Maybe try a turbo later or just swap it out for a 4bt.
  10. #8
    Jan 2007
    Paisley, Pa USA
    4,043
    12
    Quote Originally Posted by Mikel View Post
    It would involve swapping out the pistons with rings to the turbo type which in most cases have the top ring repositioned & checking or adding piston oilers. Since you have it down that far it you might as well replace the bearings also because they seem to wear out before the pistons and rings. In doing this from an economical stand point it would require a complete overhaul kit for a CPL 857 4BT turbo style engine. It would also require buying the correct turbo exhaust manifold and a replacement intake manifold cover plate and crossover piping or CAC setup.
    BobS
  11. #9
    May 2008
    SW Virginia
    117
    Does yours have an injection pump? If not your best bet might be to find a 4BT that has blown up and get all the parts from it that you need. Remember nothing lowers resale value faster than a rod out the side of the block.
    2001 Classic Roadsters Badlands - H1 Hummer Kit
    77 GM 3/4 ton 4x4 chassis, 3.73 gears, TH350, NP203, 35" tires
    chip truck 4bt w/ TH400 (picked up 7/08)
  12. #10
    New Registered User
    Dec 2010
    Connecticut
    4
    no theres no injector pump or injectors, my plan was to build it to make like 200 250hp, i wanted to use 6bt injectors, pistons, turbo and 94-98 p-pump get a center flanged manifold to hopefully get away with minimal to no firewall modification, the cylinders are pretty beat ill have more pics tomorrow or tuesday, thinking about sleveing it, or boreing it and geting larger pistons scence i need different ones anyway, can i even use the 6bt injector pump if i plug 2 holes, and once agian thanks for the answers and dealing with the questions, your info has helped allot
  13. #11
    New Registered User
    Dec 2010
    Connecticut
    4
    are the 4bt and 6bt injectors identical?
  14. #12
    Jul 2007
    TN
    1,107
    1
    no you can't just cap two holes. gotta have a 4cyl pump.
  15. #13
    Supporting Member
    Jun 2010
    Newton NC
    7,187
    10
    You'll also have to have a different front timing cover to use a P pump. Used P 7100 pumps for 4bt's are like hunting hen's teeth. If you find one it is usually big money. The engine in your photos is just a long block. No pump, exhaust manifold, or turbo. The intake plate looks ok. Appears to have a bigger inlet than the turbo models. That would be good for an intercooler set up. Lot of small parts missing. Front pulleys, fuel lines, injector lines, lift pump. Many parts could come from a a Dodge 6bt. It all just depends on how much you want to spend on it.
  16. #14
    New Registered User
    Feb 2011
    Shelby
    1
    I agree! You could not possibly use the 6BT injection pump! The firing order is totally different. Pluging holes will let fuel out the holes you want but it will not provide the proper fuel timing to those holes. The injection pump will still try to pump fuel out of #5 and #6 cylinder holes! I am also not sure that it would be healthy for the injection pump to have two holes blocked right off!!
  17. #15
    Apr 2009
    Post Falls ID
    77
    2
    Cam is different too on the turbo versus non turbo. My brother in law is putting a 4bt in his Case backhoe to replace the 4b with a cracked block. I had the 4bt gone through and the machine shop said that cams were one of the differences.
