chevy s10 with vw diesel
Results 1 to 14 of 14
Thread: chevy s10 with vw diesel
    New Registered User
    Dec 2010
    wisconsinn
    6
    Default chevy s10 with vw diesel
    hello, if any one can help me please do.
    I want to put a 84 1.6l n/a vw diesel engine in a small truck, like chevy s10, gmc sonoma, or dodge dakota. i want a 5 speed tranny in it. what truck will require the least mods.
    Aug 2009
    5,463
    1st-gen s10 or 1st-gen ranger wouldn't be the worst to be fitted with a 1.6idi... but a 1.9 vw would be more suitable, if you go with a turbocharged one it can be reasonable even in a 2nd-gen s10...
    Apr 2010
    Spokane, WA
    1,340
    58
    VW Truck (aka Rabbit or Caddy) would be the least mods...
    1990 Ford F250 SCSB on RCLB frame, 4x4, ZF5, 7.3L IDI, 37s.
    4BD1T going into a 96 F350 crew.
  5. Remove Advertisements
  6. #4
    New Registered User
    Dec 2010
    wisconsinn
    6
    what do you mean by 1st generation s10? is that before a certain year?
  7. #5
    Aug 2009
    5,463
    Quote Originally Posted by theheling View Post
    those '82-'93 square-bodied ones...
  8. #6
    May 2009
    USA
    2,588
    That's a hard question. Someone would have to have intimate knowledge of this swap. Did you try searching?
  9. #7
    New Registered User
    Dec 2010
    wisconsinn
    6
    yes I have been searching and researching for a quite a while.
  10. #8
    New Registered User
    Dec 2010
    wisconsinn
    6
    Quote Originally Posted by cRiPpLe_rOoStEr View Post
    how much would need to be changed?- like bellhousing adapter, motor mounts, flywheel? I have never done a swap but I do very well in custom fabrication.
  11. #9
    Aug 2009
    5,463
    i don't remember what exactly need to be changed, just remember about the bellhousing adapter, but back here is not so hard to find ready plug n' play kits to adapt vw engines (from those ea827 gassers like used in those vw fox or the idi/sdi/tdi) into chevy gearboxes, specially the chevette's one...
  12. #10
    New Registered User
    Dec 2010
    wisconsinn
    6
    do you know where i could get a kit that is cheap? do you know if the tranny for a 2.2L, 2.8L, or 4.3L engine is the best.
    thank you
  13. #11
    Dec 2007
    colorado
    250
    Default diesel small trucks
    GM did use a Isuzu diesel in the love-pup. Ford, Mazda and Mitsubishi did use a Mitsubishi diesel. Nissan did make some smaller diesel pick ups.
    1990 f150 4BTA, md50r2 3.50 gears.
    1991 Mitsubishi (fuso) FE flatbed 5 speed.
  14. #12
    Aug 2009
    5,463
    thank you
    i don't know where you could get one of those kits in the u.s., but as you said you can do custom fabrication by yourself, good luck...
  15. #13
    New Registered User
    Dec 2010
    wisconsinn
    6
    thank you all for your help
    does anyone know if a 5 speed trans from a 87 chevy s10 will match the driveline on a 92 s10.
  16. #14
    Aug 2009
    5,463
    sure, it would match... they're already the same stuff...
