Vibration and Noise of 4BT
Results 1 to 22 of 22
Thread: Vibration and Noise of 4BT
    Mar 2010
    Dalton, Ga
    17
    Default Vibration and Noise of 4BT
    Hi, I have been looking into swapping a Cummins 4BT into my 77 F150 and the only bad things i've heard about this is the added noise and vibration that im going to get. To me, the increased fuel economy, torque and longevity of the diesel would outweigh these drawbacks but i'd still like to know just how bad it is before hand and how to lessen it.
    So is there any particular year or model 4bt that has less vibration or noise than the others? Is there a way to balance these engines better? How about motor mounts, what material is best at absorbing that vibration?
    Supporting Member scout4bta's Avatar
    Jan 2007
    Mesa, AZ
    2,258
    46
    There are no versions of the 4B that vibrate less. That's because it's a 4 cylinder, but there are some things you can do that will help. First item is use the heaviest flywheel you can get, that would be the chevy version for the 4B, weighs in at 62 lbs, that is if your using a manual trans.
    Some of the forum users swear by the liquid filled isolaters, I've found that the first gen Dodge isolaters with a couple of holes drilled in them combined with the chevy flywheel works great.
    For noise theres some good threads in the stickys on that subject.
    NRA Life Endowment member
    1980 Scout II:92 Dodge CAC, NV4500, 3.73 gears, Atlas 4.33,33/10.50 BFG KM2, HE221W 6cm2, 3200 GSK. Cold air intake & snorkel. Mileage:low 20s to high 20s. The swap
    91.5 Dodge W250 CTD
    Mar 2010
    Dalton, Ga
    17
    Ok thanks for the info. My truck is an automatic c6. Is there a heavier flex plate available that will bolt up to the c6 and 4bt?
  5. Remove Advertisements
  6. #4
    May 2009
    USA
    2,588
    You could try a 6bt damper or a Fluidamper too.
  7. #5
    Jan 2007
    Mesa, AZ
    2,258
    46
    Quote Originally Posted by Justin's Green Truck View Post
    I don't know if you can bolt up a C6 to a B series, anyone?
    91.5 Dodge W250 CTD
  8. #6
    Isuzu Diesel Innkeeper
    Jan 2007
    New Zealand
    8,267
    634
    Some 4BT's have balancer shafts hidden in the oil sump.
    Isuzu 4BD1T Junkie.
  9. #7
    Mar 2010
    Dalton, Ga
    17
    Well theres a website called fordcummins and they sell an adapter for the B series that will make it fit with the C6, so if I get that adapter it should work. I was just wondering if there was a heavier flexplate that could be used with the C6.
    Which 4bt's would have those balance shafts in them you think? Or could the balance shafts be installed on any 4bt?
  10. #8
    Mar 2010
    Dalton, Ga
    17
    So, would the harmonic balancer from the 6bt help lessen the vibration from the 4bt? Is it heavier?
  11. #9
    Jan 2007
    New Zealand
    8,267
    634
    No. Harmonic balancers are to stop the crankshaft experiencing torsional vibrations at certain frequencies. They do nothing for engine vibration.
    Isuzu 4BD1T Junkie.
  12. #10
    New Registered User
    Jan 2007
    Fort Collins CO
    9
    You can put a c6 behind a 4bt if you have a ford adaptor. I have a ford small block windsor adaptor so if you had a small block c6 transmission you would be in business.
  13. #11
    Mar 2008
    Grand Rapids, MI
    314
    I did a 6BT Swap in my 89 and used the C6 that was bolted up to my original 7.3 Diesel. It is different bolt pattern than the small block.
    The Cummins came out of a 85 F350 as my doner truck and it used a Waive Ring to take up the space between the flywheel and the Torque converter:
    I thought it looked a little flimsy so I had a solid ring made at my buddys machine shop:
    Not sure if it the same application for the 4bt's but it may be an option.
    Here is a link to my webshots with the Cummins Conversion Pics:
    ON EDIT,..I cant post any attachments until I have 10 Post,..Sorry,,pics to come later,..
  14. #12
    Jan 2007
    Paisley, Pa USA
    4,043
    12
    Quote Originally Posted by DarrinGT View Post
    DarrinGT:
    Post your links. I gave you the missing 2 posts credit needed to post your links.
    BobS
  15. #13
    New Registered User
    Mar 2011
    Penn
    6
    Be careful making things too solid between the flywheel and torque converter. Automatic transmissions have what is called a flex plate for a reason. Torque converters are slight out of true and can expand under pressure causing alignment to the engine to change. The flex plate ( and wave ring ) take up this miss alignment.
    Some 4B has a balance shaft that bolted to the main caps. I have one that is going on mine at some point. These add about 4" to the bottom of the engine.
    Balance shafts do work, I've got a International backhoe with a 4 cyl diesel D239 that vibrates less than my old Leroi Tract air that uses a 225 ish CID 4 cyl gas. The IH has a smooth machinery type of vibration.
  16. #14
    Jan 2007
    N. AZ I-40
    2,252
    50
    The balance shaft is used in low rpm applications. They are only rated for a certain amount of rpms(cant remember, but was lo) and not used in hiway apps. I dont know if anybody is using one in a vehicle but I wouldnt personally. With a gov spring upgrade you would probably be building a large, expensive grenade. Some Lord or marine jelly motor mounts help. If you use poly on trans/t-case it will bring it right back so try to use rubber or something soft all the way back to isolate vibrations.
  17. #15
    May 2009
    USA
    2,588
    Internal balancing of rotating and reciprocal parts is supposed to help smooth things up. Fluidampr says their's is not a balancer. A combination of things should help. Mounts are the main thing. Lord's are good. I called them and they didn't have a clue what I was talking about. If someone knows the Lord's part number for the 4bt please post it.
  18. #16
    Jan 2008
    Bend, OR
    186
    4
    When making your motor mounts, it will help some if you position the isolators on a 45° angle. This way the "jumping up and down" of the pistons is not transmitted directly to the frame. Half of the forces are going down and half of the forces are pushing the mounts outboard.
    '88 Ford Ranger 4.6 gas, 273k mi. Original owner and paid for 21 yrs ago. Why yes I'm cheap!
    2003 Ford Expedition: 4BT with air-to-air intercooler, 3200RPM spring, CPL 858, M5R2 trans, 3.73 gears, 31.8" tires-- mostly done; Daily Driver since Nov 2010.
  19. #17
    Jan 2007
    N. AZ I-40
    2,252
    50
    Quote Originally Posted by CR_Magruder View Post
    Angles will work with solids but is not recommended for Lords/liquid mounts.
  20. #18
    Mar 2008
    Grand Rapids, MI
    314
    BobS
    DarrinGT:
    Sorry been a while, Here are the pics of the Wave ring.
    Little hard to see it but it is installed on the flywheel here:
    Here is is removed:
    Here is the spacer my buddy made:
  21. #19
    Jan 2007
    N. AZ I-40
    2,252
    50
    Quote Originally Posted by DieselSchlepper View Post
    http://www.4btswaps.com/forum/showth...ighlight=fluid Two numbers from Crewcab.
  22. #20
    Mar 2008
    Grand Rapids, MI
    314
    Quote Originally Posted by redhedbronco View Post
    Darrin, have a weird feeling in the stomach about the spacer. Not saying anything bad, just a gut feeling.
    It has been in there for 3 years and 30K miles with no issues,...
  23. #21
    Jun 2007
    Stephenville Tx 76401
    1,271
    I was all worried about the vibration while building my Bronco . I just used those flat dodge motor mounts. I never even think about the vibration now. Mine has been running over a year. Now it is noisy but I have no AC so the windows are down most of the time, but after I'm on the road no problem hear either. Quiter than the box van.
  24. #22
    May 2009
    Michigan
    706
    1
    think you're buddy could make another one and sell it to a local guy?
