Glow Plugs not working
Results 1 to 5 of 5
Thread: Glow Plugs not working
    New Registered User
    Feb 2011
    North Carolina
    5
    Unhappy Glow Plugs not working
    I'm new to the site and hope someone can help. I have a 1995 W4 with the 4BD2T, as best as I can tell. The glow plugs have no power to them and the engine won't start. If I shoot starting fluid into it, it will fire and run fine. It will restart fine as long as the engine is still warm. I downloaded the manual from a link I found in a thread and it shows a fusible link coming off the starter going to the 2 relays in the box on the left framerail. Don't seem to have power there. Anyone know where the fusible link is located? I asked the Chevy dealer (they do commercial trucks) and they had no idea. I also saw where it was mentioned you could run a wire through a "ford" starter relay to the glow plugs, using a fuse. What size fuse would you guess? I have owned this truck for 3 weeks and it has been an adventure!! Any help would be appreciated!
    Supporting Member
    Jan 2007
    Michigan
    718
    2
    From the manual, it looks like the fuseable link that supplies power to the two glow plug relays is located just ahead of the starter and is wired directly to the 12 volt terminal on the starter. I would encourage you to try and get the OE glow plug system working if you can rather than bypass it.
    Andy
    Stock FJ62, FZJ80
    SOA Samurai Tintop
    Ford E-350 4x4 Diesel
    M-29 Weasel
    Misc. NPRs and diesel engines(4BD1T, 6BD1, 4BD2T, 4HE1TC,4HK1TC, 7.3 PSD, 6.4 PSD)
    New Registered User
    Feb 2011
    North Carolina
    5
    Thanks for the reply. What year manual did you get this picture from? My fuse/relay box mounted to the frame by the batteries hase one fuse and 2 relays in it. There are 3 wires coming off the starter. I will try to chase down where they go. I would love to get the OEM circuit working and have been looking for a manual. I have owned this truck for about 3 weeks and it's been a pain! The wife says it's got to go and I don't want to put any $$ into it. I will try to check this weekend.
  5. #4
    Supporting Member
    Jan 2007
    Michigan
    718
    2
    It came from an Isuzu Commercial Truck factory manual for 1995. It covers NPR and W4 diesel trucks. I also have a supplement for 1995.5 models. Couldn't tell you what changed.
    Andy
    Stock FJ62, FZJ80
    SOA Samurai Tintop
    M-29 Weasel
  6. #5
    Oct 2009
    Micanopy, FL
    13
    I had the glow plug relay go bad on mine, located in a plastic box behind the front wheel well drivers side. Voltage was getting to the relay but the relay was not clicking so no voltage to the plugs.
