turbo upgrade
Results 1 to 8 of 8
Thread: turbo upgrade
    Feb 2011
    sidney NE
    15
    Default turbo upgrade
    hi i have a 1984 chevy dually whith a 4bt cummins stock injectors stock turbo stock fuel pin whith the fuel turnd up a little bit whith sum big ass stacks the egts get a lil high when pushing it up a mouitain 1300 deg and pushing about 21 psi . Im puting a a intercooler off a 92 first gen dodge and i was wodering if the 6bt h1c turbo or sum turbo off a newer 6bt would be a better upgrade for my setup i have a big junkeyard a welder and lots of ingenewity thank you
    Supporting Member
    Mar 2009
    Southeast
    1,761
    161
    Quote Originally Posted by worldperformer View Post
    I like the HX 35's...
    Nov 2008
    Stony Plain Alberta
    2,937
    1
    HE341's are good too.
  5. Remove Advertisements
  6. #4
    Isuzu reliability tester
    Jan 2008
    Burleson,Tx
    3,001
    I like the he341 for most apps but if you tow heavy (say over 8,000 pounds) you may be better off with an hx35 due to the larger 12cm exhaust housing. I bet in your case (since its a dually) you will be happy with an hx35 and a good intercooler.
  7. #5
    Feb 2011
    sidney NE
    15
    what trucks or equipment can I find hx35 in
  8. #6
    Feb 2011
    sidney NE
    15
    What trucks or equipment can I find the he341 in
  9. #7
    May 2007
    Nc
    10
    hx35 with a 14cm
    or a hx35/40
  10. #8
    Dec 2009
    South Kansas City
    212
    1
    the hx35 out of a 94-02, 01-02 auto's have an HY35, 03-04 have the HE341. I am getting ready to put a HY35 on by 4bt. the hx will give you a little higher boost. hy/He341 will boost a little earlier but higher EGT's at High boost. HX is your best bet
Tags for this Thread
