Can I flip the NP241 transfer case?
Results 1 to 7 of 7
Thread: Can I flip the NP241 transfer case?
    Apr 2011
    Dallas
    12
    Default Can I flip the NP241 transfer case?
    I have a 89 Grand wagoneer with a drivers side NP231. I want to mate it to a allison 1000 in my 4bt swap.
    BUT I've read that you can't mount the NP231 that I have. I would have to use a NP241 TC.. even though it's a passenger side case.
    The front dana 44 is offset to the left.
    Any way I could flip the TC?
    I also need help finding the adapter for an allison 1000 to a NP241
    Jul 2009
    longmont, CO
    986
    1
    NV TC's have an oiling system w/ a sump input that needs to be submerged, hard to reverse, but could check; TC's are cheap, just get exactly what you need, inputs are easily replaceable for different spline count.
    May 2008
    Mesa, AZ
    1,251
    22
    No, you can't. Drivers drop 241's are more common than pass drop 241's anyway, so you shouldn't have problems finding one.
    1991 V1500 Blazer (Silverado), 5.9L 12V P-pumped Cummins (5x .012 sac injectors, #6 fuel plate, WH1C with external 38mm wastegate running 30psi), NV4500 with 1-⅜" input shaft, SBC Con-O clutch, NP205, HAD, 4.10 D61/14BFF spinning 35" Mall Terrains
  5. #4
    Apr 2011
    Dallas
    12
    thanks! that's what I needed to know.
    I'll look for a drivers drop tc
  6. #5
    Jan 2008
    Texas Hill Country
    494
    I got mine from a 1995 Dodge ram 2500.
    " I drank what?" - Socrates
    1986 Jeep Grand Wagonner
    4bt/47rh/Np241
    Daily Driver unless im driving my VW THING
  7. #6
    Isuzu reliability tester
    Jan 2008
    Burleson,Tx
    3,001
    I'm no expert on this but I think the allison uses a very large unique output shaft (again I may be wrong). Why not just use the stock transfer case that comes behing the allison? You can get them in manual shift no adapters or anything fancy needed.
  8. #7
    May 2008
    Mesa, AZ
    1,251
    22
    The Allison uses the same 29 spline output as the Dodge manual and later automatics use. And you are correct, an NV261 would the the absolute simplest case to put on, since it came behind the Allisons. Just make sure it hasn't suffered from pump rub, and put in the kit to prevent it from happening.
    The best reason one might want to use a 241 rather than a 261 is that slip yoke eliminator kits are available for them. In that case, you would have to use a Chevy 241, because the SYE mainshaft won't be compatible with a Dodge 241DHD. I think you can put the Dodge input in the later Chevy case, but not 100% on that one...
