How hard is it to swap a 4bt into a 2000 f150 4x4
Results 1 to 25 of 25
Thread: How hard is it to swap a 4bt into a 2000 f150 4x4
    Jun 2011
    Montrose South Dakota
    13
    Default How hard is it to swap a 4bt into a 2000 f150 4x4
    the truck has an auto trans and a 5.4
    what would i have to buy to make the swap happen and a ruff estimit of the cost plus the cost of the 4bt
    Jan 2011
    Guadalupe River State Park Texas
    59
    Ahhh, that is the holy grail of questions. Trying to get a good estimate is tough there are a lot of factors, do you plan on buying all the parts to do the conversion or can you fab some up. There are several F150 running around with 4bts, there is even one for sale in the classifieds here, so it can be done. but it could cost anywhere from 5,000-13,000 to do a conversion it just depends on what you want. For my conversion, I might even make money on my conversion but I did have a 6.0l diesel that I parted out. It really just depends on how much time and effort you want to put into it. I can tell you this the 4bts can cost more than the 6bts. There are several places that sell conversion parts for all kind of trucks you will have to do a whole lot of reading.
    Jakob
    2004 Ford F250 crew cab Fx4 Lariat. was 6.0l (RIP 10-31-10). replaced with a 1997 12v cummins 5.9l and a 47rh built by Garmons.
    New Registered User
    Jun 2011
    Clayton, DE
    13
    why stop at 4bt on that body style? when my 150 grenades the trans, which i hope it holds till i get the ranger done...(4bt) i want to do a 6bt into it... it should fit fine with a 3in body lift...
  5. Remove Advertisements
  6. #4
    Jun 2011
    13
    Quote Originally Posted by 4bt 86 Ranger View Post
    I might go with the 6bt and just by a wholw old dodge truck and considering that i all ready have a 3in body lift on mine
  7. #5
    Sep 2010
    Texas
    24
    2000fordf1504x4, I just recently watched a vid on youtube where a 4BT H1 whoops up on a 7.3 Powerstroke. That was a mostly stock 4BT too. Oh yea, are you on F150forum.com under the same name? If so I believe we were discussing this on a mileage thread or something.
    My question, how do you convert the tach signal in order to get the crusie and tach to work? I have an 02 4.2 2wd and some have suggested Dakota Digital but I'm still a little confused on how that works and how it would work with the PCM. For all the other gauges I've been told just swap the sensors over. Can that be done on the tach sensor if its near the flywheel and I reuse the 4.2 flywheel for my transmission?
  8. #6
    Jun 2011
    13
    yes im on the f150 forum under the same name and i dont know how to make the pcm or tack work at this point im kinda thinking about buying an older truck that has a 5 speed for the swap
  9. #7
    Sep 2010
    Texas
    24
    For the tach I hear Dakota Digital is the way to go. It will convert the system from the diesel by counting and timing teeth on the flywheel and turn it into a gasoline 4cyl signal that will be read by the computer. That and the gauge sensors are all you connect to the ecm, just need a separate controller to control you transmission. I met a nice Canadian who had swapped a 4bt into a tahoe and he was telling me about the part he has the controls his tranny and it even has a built in tach output that will get the cruise to work. fordcummins.com is saying the compushift is what you will probably want, but i don't remember what the Canadian had, give me some time though and I'll find out.
  10. #8
    Jun 2011
    13
    I will give you some time to find out and thanks for all of your ideas so far
  11. #9
    New Registered User
    Jun 2011
    Clayton, DE
    13
    97-98 had a mechcanical speedo gear... where as 99-up have a elctronic... if that help you any... which if you want a 5 speed it will help because that allows you to run a ZF-5 allot easier...
  12. #10
    Jun 2011
    13
    that helps a lot i might buy a truck that allready has th zf 5
  13. #11
    New Registered User
    Jun 2011
    Clayton, DE
    13
    the zf5 came in the 99-up superdutys that were the 5.4 or v-10... zf-6's came in the powerstroke trucks... The m5od2 came in the regular f150's... its basically a mazda trans
    m5r2... i always think its a m5od2...idk why
  14. #12
    Sep 2010
    Texas
    24
    M5R2 outside the Ford community. M5OD-R2 is the official designation. Literally, Mazda 5-spd with overdrive. The R2 designates it as the med. duty, R1 is light duty and is found in Mazda B series. The R2 was found in most half ton rated standards that had something 351 and below in the 90's and up...most of the time.
  15. #13
    Sep 2010
    Texas
    24
    Quote Originally Posted by 2000fordf1504x4 View Post
    He had a compushift that he got from fordcummins.com. I wasn't running an intercooler but is running a modified compression housing on the turbo to make up for that somewhat.
  16. #14
    Jun 2011
    13
    Maybe i should just swap one intomy dads 05 superduty because it has a 5.4 with the 5 speed but i dont think he would like that plus the truck only has 60,000 on it
  17. #15
    Jan 2008
    Bend, OR
    186
    4
    Quote Originally Posted by zapzap View Post
    Not sure about the Dakota Digital converter as used on a flywheel. The ford PCM is looking for 35 pulses on a 360-degree pattern (missing one pulse out of 36). See earlier discussion here: http://www.4btswaps.com/forum/showth...-tach-sig-wire
    CR
    '88 Ford Ranger 4.6 gas, 273k mi. Original owner and paid for 21 yrs ago. Why yes I'm cheap!
    2003 Ford Expedition: 4BT with air-to-air intercooler, 3200RPM spring, CPL 858, M5R2 trans, 3.73 gears, 31.8" tires-- mostly done; Daily Driver since Nov 2010.
  18. #16
    Sep 2010
    Texas
    24
    Quote Originally Posted by CR_Magruder View Post
    CR
    So what your saying is just find out how many pulses my pcm needs (I have the 6 cyl engine) and machine a new gear for the factory CPS sensor?
  19. #17
    Jan 2008
    Bend, OR
    186
    4
    That's how it worked for me. I'm not sure how many teeth the 6-cyl crankshaft has. I did not see a specific description for the 6, so one could assume it is the same as the V8. There is a document that Ford produces to describe the engine controls for model year 2002 vehicles here: http://www.motorcraftservice.com/vdi...f/obdsm208.pdf. See page 40.
    I would want to be sure of the number of teeth, since it is a lot of work to machine or waterjet-cut a tone ring out, only to find the scaling is off. If you can get a good view of the crankshaft postion teeth on your engine with the sensor out, you could just count the teeth while barring the engine. The sensor on my V8 was in a place that made it hard to get a peek down the hole while in the truck.
    CR
  20. #18
    Jan 2007
    67
    My 91 M5r2 came with speedo gear, the zf I have laying here , I think a94 has no drive or hole for cable.
  21. #19
    Jul 2008
    zip 71110
    95
    Autoworld in Great Falls, MT just finished a 4BT swap in a newer F-150 pickup. Pics are on their facebook page of it. It is/was a red '07 or '08 I believe from Canada.
    '04 F250 XLT ext cab long bed 4x4 with 4BT, ZF6, 3.73 gears, 285/75/R16
    22mpg+ /15 mpg towing
    www.autoworldmt.com www.destroked.com
  22. #20
    Jan 2007
    N. AZ I-40
    2,229
    39
    Quote Originally Posted by wrenchbender View Post
    Like that 59CC conversion
    69 Bronco 4bt/HE221/NP435/203/205, 3.54 D60s OX locker F/Detroit R, military H1 beadlocks and 38" rubber
    "sealing the deal on this forum section as a whole..(and/or his entire membership here){which has been an issue before}ps: you were warned.... Redhedbronco reported for vulgarity character attack."-47Ford-1.5Ton ​A few ratty whiners here!
    Please, Drifter, don't give me any more advice because I can't afford it and I don't want to destroy my engine or truck.-JimmieD
  23. #21
    New Registered User
    Jun 2011
    Taber
    9
    Yes it was mine, 2008 F150 FX4, now with a 4BT cummins and its very nice to drive and the fuel mileage is wicked 30 to 40 on average depending on how a person drives.
  24. #22
    New Registered User
    Jun 2011
    Taber
    9
    I opted out on the funky cruise control set up untill someone can figure out how to get my factory buttons to work.
    Any help would be appreciated.
  25. #23
    Jan 2012
    Hillsboro Ohio
    41
    Your truck used the 36 tooth -1 right. I took a 3.0 tone ring from a ranger balancer, and I am going to mount it to my balancer, and use the stock crank sensor and pcm. PM me and I can get you some pics and more details.
    Tim
  26. #24
    Jan 2007
    69
    for the tack I used the stock relucter wheel from the 4.6 and made a adapter to mount it on the crank and made a mount to hold the stock crank sensor . I will try to get some pics
  27. #25
    Jun 2011
    13
    I'm going to start tech school in August so hopefully I can start the swap within the next year or two
