Tach Sensor Location
Results 1 to 3 of 3
Thread: Tach Sensor Location
    Supporting Member
    Jun 2010
    Newton NC
    6,832
    8
    Default Tach Sensor Location
    We are always looking for new ways to get an accurate tach reading from an engine. Has anyone ever mounted a hall effect sensor on the Cummins timing case to read off the injection pump gear? That's where Ford gets it's reading on the 6.9/7.3 engines. Seems like it would be relatively easy to install a bung in the timing case to read the pump gear. Shouldn't weaken the timing case if done correctly and should give accurate engine rpm. Any thoughts?
    Jan 2007
    Paisley, Pa USA
    4,010
    11
    I believe that has already been done. I think there is a link in the sticky under tach that shows one.
    BobS
    Dec 2009
    Palmyra, Nebraska
    365
    2
    Interesting that this should come up.
    I recently acquired a VE timing case from an early 1991 Dodge and it has a port on it that looks to be for a sensor to read off of a gear.
    It's the only one I recall ever seeing with this port.
    Mark.
    The election is over, the talking is done.
    My party lost, your party won.
    So let us be friends, let the arguments pass.
    I can pat my elephant, you can pat your ass.
    We're on a rocket sled to societal failure and the pilot is a freaking madman in a straightjacket.
