Oil Pressure Sensor
Results 1 to 4 of 4
Thread: Oil Pressure Sensor
    Feb 2007
    North Carolina
    365
    Default Oil Pressure Sensor
    Hey Guys,
    I'm in the final stages of my build and I need some help. I'm trying to connect a oil pressure sender to my original 1974 FJ40 instrument cluster. I didn't do a whole lot of research but i did see that it was a good idea to use a FJ40 oil pressure sensor so that its data would match the fj40 cluster.
    I bought an original fj40 oil pressure sender and mounted it to the oil pressure port on the drivers side of the 4bt just left of the fuel lift pump. It works but I'm reading a high oil pressure on my gauge. My fj40 gauge doesn't have numbers associated with it but the needle is sitting on the high "H" of the gauge. It isn't pegged though. Should this diesel read a higher pressure than the original straight 6 F-motor? Thanks
    1974 FJ40 4BT cpl 858, VE Pump, 366 spring, KDPf, HY35w, SBC Con-O, NV4500, Dana 300, 4.10, 35s
    Jan 2007
    Paisley, Pa USA
    4,020
    12
    Quote Originally Posted by 1974FJ View Post
    Hey Guys,
    Yes, in in most cases it's in excess of 50 psi on a cold start up.
    BobS
    May 2011
    Santa Barbara
    825
    50
    I will be putting a tee and a oil pressure gauge so I can compare the readings on my stock dash gauge. Cummins shop manuel says 10 psi at idle. (I am trying to keep my interior stock without a after market cluster 1965 GMC 4X4). Hope it is somewhat helpful.
  5. Remove Advertisements
  6. #4
    Oct 2010
    Grand Island, NE
    428
    My 6bt is 70psi at cold idle ~50*f About 40 when warm.
    Sent from my Droid using Tapatalk
    '04 LB7 Duramax CCSB | S&B Intake | 4" exhaust | EFI Live tuning by HUSKER DIESEL PERFORMANCE:
    '95 Chevy ECLB 2wd - 12v/NV4500 swap complete | 253rwhp, 530tq | 23mpg
