ford motor mounts
Results 1 to 2 of 2
Thread: ford motor mounts
    Oct 2011
    limerick pa.
    16
    Default ford motor mounts
    Where can I find the engine side motor mounts for a 4bt to fit in my 300 6cylinder ford truck? I know they put 4bt's into e-350 chassis as a replacement for the 300 6, Its supposed to be almost a direct bolt in. Anybody know?
    Jun 2010
    Albuquerque, NM
    46
    Quote Originally Posted by 79dentside View Post
    Hi 79dentside,
    I finished my swap into my 1972 F100 this summer and it was a bit of a learning revolution. From my research I found that your and my pickups are not a direct swap for the 4bt. The direct swap begins with the 1980 F series. The 300 engine perches and mounts are the same from 1967 through 1979, and are common with the Ford FE series engines. PM me with your email address and I will send you photos of the engine perches that I made and the other fabrication details that I encountered.
