cummins 3.3 should I buy?
Results 1 to 16 of 16
Thread: cummins 3.3 should I buy?
    Jul 2009
    Portland, OR
    28
    Default cummins 3.3 should I buy?
    I was just in the thinking stage of maybe putting a 3.3 in a toyota 4runner. As I was thinking I mentioned to a friend who had a friend that had one sitting in his garage. it only has 100 hrs on it and looks brand new. Came out of a forklift governed to 2000 rpms. He is only asking $1200 for it. Seem like a good buy to me. Comes with wiring harness and computer. The two red flags I'm worried about is the computer part and the 2000 rpm governor. Is the governor and easy thing to change in these motors and how? The computer part also scares me a little too. I'd much prefer the older mechanical version instead of the newer computer models. Not sure if I can make that work. Like I said I'm still in the thinking about it stage but $1200 sounds like too good of a deal to pass up.
    Anyone successfully putting them in a toyota? How do they mate up the transmission? What kind of MPG are you getting? I have a lot to learn and $1200 is a lot to spend without knowing anything about them.
    Mar 2012
    Vermont
    52
    if it has a computer it must be the QSB 3.3 version
    I haven't seen any being put into a toyota yet although that would make for a killer rig
    I do know the older B3.3's have been put into jeeps and cruiser's and that the owners are reporting mid 30's for mpg's..
    As for the governors, i believe it is a plate and a spring set-up....
    Is your pump an inline or rotary pump?
    still, 1200 buckaroos for a running 3.3 is a steal of a buy...
    oh and a group called phoenix castings makes adapters for the sae4 housing on the cummins to just about any transmission/bellhousing...
    hope this helps
    Jul 2009
    Portland, OR
    28
    Thanks for the feedback. I guess I'm having a little trouble visualizing the conversion. I get the bell housing adapter concept. What I'm not sure about is how the clutch is going to mate up to the engine and transmission. It was to be a clutch for the transmission I'm sure so it fits on the flywheel. So how does it bolt to the engine flywheel it's it's not made for the size of the flywheel? How does it fit the engine? Sorry if I have my info incorrect. I don't have a lot of experience with this stuff so just some bit and pieces here and there. Is there any other complicated issue with the computer design? Making sure your blank sensors is working right with the blank blank so the computer knows to blank? I would much prefer the mechanical design. But more efficient, more power, and the fact my friend has one readily available is hard to beat.
    You ask if it's rotary or inline? Isn't the QSB common rail so it's an injector design?
  5. Remove Advertisements
  6. #4
    May 2009
    USA
    2,588
    If you don't buy it please message me about it.
  7. #5
    Nov 2010
    Everett, WA
    234
    There should be a bellhousing adapter and a flywheel adapter. The flywheel adapter adapts it to your flywheel, so it's stock from there back. I'm not sure if they make toyota adapters, but if yours is a manual I seem to recall that it is very similar to the Dodge ax15, which they do make adapters for...
    Is this a turbo engine?
    Sent from my LG-VM701 using Tapatalk 2
  8. #6
    Jul 2009
    Portland, OR
    28
    Yes this is a turbo engine. 2008 common rail. He just said the governor has been reflashed to factory levels. He also said it's at 85 horsepower currently but he would reflash it to 115 horse if I bought it. The adapters don't seem to complicated. Now I'm just a little worried about the computer, all the wires, all the sensors, and making that all work right. I'm going to make sure I can find a wiring diagram for it before I buy it.
  9. #7
    Jul 2007
    Louisiana, U.S.
    514
    Click the link in my signature. You'll find photos of a Phoenix Castings adapter set. It consists a SAE 4 flywheel housing to small block Dodge bellhousing adapter and a SAE 10 flywheel to small block Dodge flywheel adapter. My flywheel adapter is sized for a "shallow" SAE 4 flywheel housing. The flywheel adaper for the standard depth SAE 4 flywheel housing is cone shaped.
    http://www.phxgrp.com/transmission.htm
    I'm using a Jeep AX15 transmission bolted to a Dodge Dakota Bellhousing. The Jeep AX15 and the Toyota transmission are both Asin Warners and are basically the same tranny. See the link I've pasted below for an explanation.
    http://www.jeeps-offroad.com/showthread.php?t=4740
    Peak Mechanical uses the QSB3.3T in its mine certified Toyota Tacomas. (Notice the solid axle conversion.)
    http://www.peakmechanical.com/mine%20truck.html
  10. #8
    Aug 2009
    5,463
    Quote Originally Posted by 95Z28A4 View Post
    that might ease the swap... fuel-efficiency might be greater than with the stock IDI 5L-T 3.0L turbocharged from the toyota hilux (overseas tacoma)...
  11. #9
    Jul 2009
    Portland, OR
    28
    IDI get better mileage than a direct injection? I don't know much specifically about that toyota motors but traditionally IDI's don't get the mileage direct injections get. Plus I've already done the motor from outside the US thing with my old land cruiser and a 3b toyota diesel. You wait a month for a part to come from austrailia, shipping is super expensive, exchange rate isn't good, and the rare part is marked up 3 times over. Then once you get it, you figure out they shipped you the wrong part. Toyota told me I bought the last 24 volt glow plugs in the entire US! They were $62 a pop! I even had to rewire around the glow plug controller because that was $850. It was a great motor in ever sense of the word, but not very fuel efficient, and expensive to work on.
    The wide ratio of power to torque tells me the cummins 3.3 is a very low revving motor. Which also tells me it could really benefit from a wide selection of gears. With a big overdrive, low resistance tires. Thanks for those links. If I decide to do this swap those will become very helpful. Right now I'm second in line for that engine so hopefully it comes through. It is a big undertaking however. Mr. 95z28a4, how did this swap turn out for you? Was it a lot of work making all the computer stuff work right? Pedals and all that fun stuff? What kind of a mileage are you getting in yours?
  12. #10
    Aug 2009
    5,463
    Quote Originally Posted by eou_edu View Post
    definitely NO... for this reason i said the fuel-efficiency with the b3.3 would be greater than if you slapped a toyota IDI 3.0L 5L-E despite its lower displacement...
    direct injection is usually about 20% more efficient
  13. #11
    Jul 2009
    Portland, OR
    28
    Quote Originally Posted by cRiPpLe_rOoStEr View Post
    Sorry I read you other post wrong. 20% sounds about right. They say that 5lt toyota diesel gets about 30-35 in the 4runner. So 20% better, and geared right to run on the road, as well as some other small fuel saving tricks I think 35-40 mpg is pretty reasonable. I guess I will see. My friend sold his that I was eye balling but he is going to try and get me a mechanical 3.3. He has source for them apparently. All the computer stuff and making that run right started to scare me. What if I wired up the gas pedal wrong? Seems complicated and expensive. The common rail would be cool, but the only reason id go with it is if that was my only option (which is might be) or I was sure it would be a lot more efficient. Which I don't think it is. The best I can compare that to is comparing the dodge 5.9 common rail vs the old mechanical 12 valves (which I currently own a 96 dodge). Common rails are about the same mpg to the mechanical versions having a slight edge. When I usually read about mileage tests in diesel magazines the old 89-93 12 valves are the king...............But I'm really just trying to justify my decision, who knows what I'll end up with. Thanks for the feedback thus far.
  14. #12
    Aug 2009
    5,463
    35mpg wouldn't be so hard to achieve, but considering the higher displacement i wouldn't expect the qsb3.3 to get a mileage so better than the 5L-T
  15. #13
    Jul 2007
    Louisiana, U.S.
    514
    Haven't yet completed the swap. I can't seem to get time off work. I worked nearly 1600 hours OT last year and 1000 hours each for the 2 previous years. I have accumulated over 400 hours vacation that I can't take. I'm hoping things will slow down a bit at the end of the this year. My Grand Cherokee must be complete by summer 2013.
    I made my own wiring harness. It costs over $150 for the plugs and wiring not including relays, switches, LED's etc. I plan to use a modified 2000 Ford Superduty Powerstroke pedal with Williams 131973 APPS.
    If you want to read an all inclusive thread on B3.3T conversions, click the link below.
    http://www.dieseltruckresource.com/d...j-t112807.html
  16. #14
    Jul 2009
    Portland, OR
    28
    Thanks for the link. I read through about the first 10 pages. I was a little disappointed to learn the guy that swapped on in a YJ jeep that was pretty high geared was only getting about 29 mpg on average. Maybe my expectations are too high.
  17. #15
    Nov 2010
    Everett, WA
    234
    I read through that entire thread a while back, but I seem to remember that he eventually got up to around 35mpg with it. Another thing to consider is that barn doors have a slight aerodynamic advantage over a Wrangler...
  18. #16
    Jul 2007
    Louisiana, U.S.
    514
    Keep reading. As stated above, he eventually got 35+ mpg after tuning and tweaking. The thread contains at least 2 more builds to completion. One of those builds is also a wrangler by a Cummins employee getting 35 mpg. The other is a newer S10 getting 40 mpg. The guy with the S10 has also built a 4BT f150 and is a member of this forum. I think his username is 4BTSonoma.
