Ford 5 speed manual shift problem
Results 1 to 21 of 21
Thread: Ford 5 speed manual shift problem
    May 2011
    Central Texas
    330
    31
    Default Ford 5 speed manual shift problem
    OK, so the 4bt swap is on hold right now, but I have this problem with the 98 explorer 5 speed shifting. Hope someone here can point me in the right direction. It has 167K on it. I have a real problem getting it to go in gear sometimes, especially when its cold (cool - Texas mornings in july aren't that cold). Anyway, even when its hot, when I come to a stop, if I keep the clutch pedal engaged, I can shift to any gear with ease. But, if I let up on the clutch ( in neutral), then engage the clutch pedal again, its almost impossible (most times) to get it to go into any gear. If I pop the clutch to re-spin the gears, no help. Its like the all the gears are sitting there tooth-to-tooth, and nothing but the tooth. Thanks.
    Nov 2009
    flatland
    2,103
    4
    Clutch or hydraulics or both hi miles should be done..
    Sep 2011
    Calgary, Alberta
    93
    2
    Yes, it sounds like a dragging clutch. Possibly hydraulics cause the clutch not to fully disengage. It also could be a seizing pilot bearing. I have seen this overlooked way too many times. When you are at the point that you can actually shift into any gear with the pedal down, listen for any noises that appear or disappear when you dis and engage the clutch. If you hear a noise with the pedal in, it is very possible it could just be the pilot bearing. Thus turning the input shaft making it hard to get into gear. The noise also could be the release bearing but will unlikely cause a hard to get in gear situation.
    1951 Ford F3, Ford F-450 Dually Frame, 453T DD, 10 speed fuller
  5. #4
    May 2011
    Central Texas
    330
    31
    Had my mechanic rebuild the front end and on the test drive had him test the shifting problem I'd been telling him about. BTW, while under the vehicle, I ask if he would look at the clutch thru the inspection plate while I worked the clutch. He couldn't see the clutch, but the pressure plate and hydraulics worked OK. What he was able to demonstrate was that you need to wait several seconds after you depress the clutch, before trying to put it in gear, then you eliminate what feels like a hard stop you're up against. Its like you have to let the internals in the transmission spin down before trying to engage a gear. Is this worn synchro clutches. Would like to understand how, if this is the problem, that it feels like a hard stop, instead of just letting you grind the gears like it didn't have any synchro clutches.
    One thing, tho, is that I backed out of a parking space, and it was like it was hung up in reverse. Had to let out on the clutch a time or two to get it out of gear. What I don't understand is how plain wear can cause it to not be consistent. Just trying to picture what's going on inside the gear box. Any ideas? Thanks guys!!
  6. #5
    Jun 2011
    Oregon
    538
    2
    Quote Originally Posted by Ugene View Post
    Your explorer has an M5R1 built by Mazda. The 4.0 version is a little undersize for what it's expected to do. The miles you have on your Explorer are right inline with the high life expectancy of one of these if it has the 4.0. The 4.0 transmissions are usually rough inside. It's unusual not to replace the input and cluster for deformed gear teeth.
    I agree with clutch hydraulics or worn pressure plate as the likely cause, but something else to look at, and relatively simple to check, is the shifter pivot seat bushings. Pull the shifter boots and pull the shifter out by removing the 3 small bolts holding the seal plate on the top plate. There should be some spring washers and one upper and one lower plastic pivot seats in there.
    These seem to last around 50K miles before they deteriorate and need replacing. They are very cheap and easy to replace. Makes worlds of difference in how the Mazda transmissions shift when these are in good shape VS non-existent.
  7. #6
    May 2011
    Central Texas
    330
    31
    Quote Originally Posted by 69rambler View Post
    I got around to changing the clutch master cyl. This helps in that the clutch no longer tries to engage while I'm sitting at a light with my foot on the clutch. However, at times, I'll have it in low and can't get it out of gear w/o shutting off the engine; the engine is not loading up like the clutch is trying to enage, it just wont come out of gear. At other times, I can't get into low w/o going to some other gear first, usually reverse is the only gear I can get. Once, I couldn't get in any gear. I shut off the engine and was was able to move the gear shift around into any gear.
    Guess I'll go after the pivot seats next.
  8. #7
    Apr 2010
    Spokane, WA
    1,337
    58
    Also these Madza trannys have crappy shift forks, the fingers wear down and I've had one wear completely off on a M5R2. I'm guessing the 1-2 shift is the worst? I have to rev match on that shift in my 91 Explorer with the trans out of my 01, the original trans did the same thing. I'm no tranny expert but I'm assuming accelerated synchro wear is a result.
    Very cheap and easy to replace the forks though, just remove the tranny tunnel access panel, pop off the top cover and take it to a bench for tear down.
    I've heard it said that they wear bad from resting your hand on the shifter while driving.
    1990 Ford F250 SCSB on RCLB frame, 4x4, ZF5, 7.3L IDI, 37s.
    4BD1T going into a 96 F350 crew.
  9. #8
    May 2011
    Central Texas
    330
    31
    Today another symptom. After releasing the clutch at a light, pedal full down, it wouldn't come out of first gear. Testing the pedal I could tell it wasn't fully released, it was too near the point of lugging the engine, but not at the nomal engagement point (about an inch further up). I was thinking I was going to have to shut it off to get it out of gear. So I tried something different, I raced the engine and it released and came out of gear.
    It also has this unusual sound when you first crank it up until it warms up. Its synchronous with the engine revolutions and sounds like a ching, ching, ching, ...
    once per revolution and sounds like its coming from behind the engine. Its like a large washer that's loose and gets tinged every revolution of the engine. I think it needs to be looked at for sure.
  10. #9
    Jan 2007
    N. AZ I-40
    2,169
    39
    Clutch. Probably a shot spring.
    69 Bronco 4bt/HE221/NP435/203/205, 3.54 D60s OX locker F/Detroit R, military H1 beadlocks and 38" rubber
    "sealing the deal on this forum section as a whole..(and/or his entire membership here){which has been an issue before}ps: you were warned.... Redhedbronco reported for vulgarity character attack."-47Ford-1.5Ton ​A few ratty whiners here!
    Please, Drifter, don't give me any more advice because I can't afford it and I don't want to destroy my engine or truck.-JimmieD
  11. #10
    Mar 2012
    Austin, TC
    19
    I'll second redhedbronco on the clutch issue. However it sounds like the rest of your components are pretty worn too given the age and milage, particularly synchros. But I'd bet if you do,the clutch she'll run for a while longer and ease most of your problems.
  12. #11
    May 2011
    Central Texas
    330
    31
    Finally figured it out. A couple days ago, I was trying to put it in (non-synchronized) reverse. When it finally went in, just as it was going in, it clipped 4-5 teeth on the gear before going in. This means the input shaft was being driven. It was then that it clicked inside my head. You see, the clutch engages just fine, at the right pedal height, etc., and its always repeatable that way. And releases there too. But sometimes it would be hard to get out of, or into gear, unless you shut the engine off. And there is this light sound coming out of that area that matches the engine rpm. So, what I've concluded is that its the bearing in the flywheel that's going bad and trying to seize up. As this bearing goes bad, it begins to drive the input shaft to the transmission, even with the clutch released. If the transmission is in neutral, it spins the input shaft, and this make it hard to put into gear. (Is there a mechanism to prevent the shifter working if the input shaft is being driven, and its in neutral?). If you shut off the engine, you can put it in gear, and then re-crank and get going. If its in gear and the bearing seizes, the engine is connected directly to the driveshaft, regardless of the position of the clutch. With it in neutral and your trying to put it in gear, the synchros will attempt to spin up the input shaft to match the gear you're going to. But, with the bearing seizing up, they have to fight the bearing in order to spin the input shaft up to the right speed, and when the bearing gets bad enough, its wins, and shifting becomes difficult.
    Its scheduled for the operating table sometime in the near future. No medical insurance, so I'll have to pay out of pocket.
  13. #12
    Nov 2009
    NJ
    149
    Its not uncommon for the pilot bearing to "go bad" in these trucks... My '94 Ex is having the exact same problem right now. What happens is:
    The pilot bearing is a roller bearing, when the grease dries up, and the bearing no longer rolls freely.
  14. #13
    May 2011
    Central Texas
    330
    31
    Update. Well, apparently the pilot bearing spit out 3 or four ball/rollers after hitting HARD spots and after that it must have freed up the front end of the shaft because the synchronizers are back and shifting is no longer a problem. However, a wierd symptom has shown up: while stopped at a light, with clutch (which engages/disengages at the correct point) fully depressed and the xmission shifted into 1st gear, sometimes, the synchros start spinning up really fast. going to neutral stops this and trying to go back in gear restarts it. Can't see how that happens mechanically. Just passing this along...
    Replacement is on hold do to having to replace the intake gaskets to fix the lean mixture codes and the check engine light so I could get it safety checked again.
  15. #14
    Jan 2007
    Tardis
    2,859
    7
    These trans are notorious for issues. If you are 2wd the '05-up Mustang 5 speed from the 4.0 is a nice upgrade, since it sounds like you have numerous internal things going on now.
  16. #15
    May 2011
    Central Texas
    330
    31
    Thanks for the info. Wish I'd a known. The replacement is on the shelf awaiting $$ and a slot in my mech's schedule.
  17. #16
    May 2011
    Central Texas
    330
    31
    After opening up the replacement, we noticed that one of the tines on the (aluminum) 'fork' that's attached to the shift handle shows evidence of wear, while there's no noticeable wear on the other tine. Everything else looked good. Should this uneven wear be a concern? Should it be replaced? I see a steel one on ebay.
  18. #17
    Registered User eggman918's Avatar
    Feb 2010
    Paulden, AZ.
    1,567
    145
    If it were me I would replace it/them for peace of mind if for no other reason,I just replaced all 3 of them in the ZF I put in my truck.I started with the plan to just do main and counter shaft bearings and syncros but when I opened it up and saw what I had I ended up doing the needle bearings and shift forks as well I'm sure the forks would have worked "well enough"........but the needle bearings and forks cost just under $200.00 and with the time i had in it that wasn't that big deal.It's in now and working great and I KNOW it was done right and should out live me.
    Just my two cents.
    Steve E.
    The "Filthy Beast" 1968 F-250 4x4 crew cab 131" wheelbase 3.55 Dana 44HD/Dana60..4BT HE 221W 6cm exhaust ,VE pump advanced,power screw turned up 2 turns, F-800 inter cooler 3" plumbing ,ZF-5. NP-203/205 http://s1042.photobucket.com/albums/b429/eggman918/
    The key to knowledge is first to understand what you don't know,then you can start to learn the things you don't know....?
  19. #18
    May 2011
    Central Texas
    330
    31
    Thanks for that encouragement. I got the forks and worked my way through the process of replacing them. Now I'm the rebuilding the shifter stub.
    Question: Anyone have a clever way to press the old pins out?
    Question2: The backup light switch connector was damaged so I got a new one.
    The Neutral Safety switch was missing on this used unit. Locally, noone has it. O'Rileys and NAPA pull up the one for an automatic even for the manual. Autozone shows I don't have this part on my vehicle. There's a place to screw it into the transmission. Its in the exploded view of the transmission. But it doesn't show up in the start circuit as the switch on the clutch pedal takes care of the lockout function. So, what is it used for on a '98 Explorer M5R1? Does the computer have a need to know?
  20. #19
    May 2011
    Central Texas
    330
    31
    Well, guess what? I must have been toxic the time I bought the replacement because I bought the one for a 3.0 V6, not the one for the 4.0 V6. I replaced the forks. I also rebuilt the shifter base.
    My first question is to know if the 3.0 will bolt up to the 4.0 engine? If that's true, are their lengths the same, or 'close enough' for gubment work as they say? If that's OK, are the ratio's close enough to get it back on the road? I could nurse it along while I have the pleasure of rebuilding the current one. Where do I go to find out the above? Thanks so much.
    The pilot bearing went out at 167K. It now has 224K. The main bearing got loud enough to hear it this past week. I'm definitely toxic now because of a corroded molar and unable to ream out the roots til we get my oil pressure adjusted downward. Thanks much...
  21. #20
    May 2011
    Central Texas
    330
    31
    I was able to build a tool to push the pins out. (Turns out you only need to push one pin back in order for the new parts to slide in) : I drilled a hole in the head of a fine thread bolt so the bolt would slip onto one pin and not fall off, and, while holding an interposer between the other pin and the nut, back the nut off by hand until the bolt is held snuggly between the pins. Then continue to back the nut off until one of the pins breaks loose. I was surprised at how loud that was. But I could not tell which pin was backing out when it popped. But it was on its way out...
  22. #21
    Supporting Member
    Jun 2010
    Newton NC
    6,681
    7
    When they say press fit they mean press fit. Good to see you're making progress. Need to post up a few photos. We all like the pictures.
