4BT Engine Quiet Kit
Results 1 to 16 of 16
Thread: 4BT Engine Quiet Kit
    Vendor steed's Avatar
    Aug 2009
    Fort Stewart, Ga
    704
    27
    Default 4BT Engine Quiet Kit
    I just wanted to start a thread on sound deadening blankets Iíll be getting for my truck in the next few months. I just arrived to RC South, Afghanistan so Unorthodox Customs in Puyallup Washington will be doing the work.
    A few weeks ago I was searching for something I can mount underneath my hood to help quiet my engine a little. I came across Advanced Thermal Products http://www.atpwrap.com/ APT currently has a quiet kit for the Cummins 6.7 http://www.atpwrap.com/html/dodge67cummins2009.html as well as the ISB 5.9 the kits consist of blankets that attach under the hood, valve cover, oil pan, exhaust manifold and turbo. I donít know the dB reduction.
    Anyways they currently donít have anything for the 4BT so in Dec, unorthodox customs will remove my oil pan, valve cover, turbo, down pipe, and center dump exhaust manifold and ship them to APT to build a custom setup for my Tacoma.
    I know a lot of people will like there 4BTs a little quieter and hopefully this kit will dramatically reduce engine noise, my Tacoma is very poorly insulated. Because of this my Tacoma should demonstrate how well this kit works.
    The kit is pricy but hopefully if the dB is reduced enough in my Tacoma, that it might build enough interest for 4BTSwaps to have a group buy for other members of the site. Just FYI I am not affiliated with this company, nor will I receive any kick backs from them. I just wanted to pass this information along and once the kit gets put on my Tacoma Iíll update this thread with pictures and if I can find them a dB meter ill get before and after dB rating.
    Steed
    2011 Toyota Tacoma
    Supporting Member GLTHFJ60's Avatar
    Jun 2010
    Durham, NC
    1,637
    225
    I'm interested in hearing how much of a difference this kit makes. Any chance we could get videos before and after from inside + outside the truck?
    Johnny C - KK4HAN - TLCA# 17825
    Olde North State Cruisers
    1987 4BTJMashup - MoonShine - 4BT/NV4500/D300/D60/14B and a bunch of other modifications. - DD
    Land Cruiser adventures, documented through YouTube
    Quote Originally Posted by Dougal
    I'm an engineer, I find solutions that work and really hate marketing dribble.
    Jun 2007
    Portland OR
    405
    3
    Hopefully it works out well. I'd be in for a group buy if it does.
    85 Landcruiser FJ60, 4BTA, Compounds, 4L80E Optishift controller, 203 doubler to splitcase tcase, SOA, 37s, other stuff.
    Build Link:
    Family Haulin' FJ60
  5. Remove Advertisements
  6. #4
    Apr 2010
    Spokane, WA
    1,340
    58
    If you can actually get a meter and measure the dB difference from the driver seat that would tell a lot.
    1990 Ford F250 SCSB on RCLB frame, 4x4, ZF5, 7.3L IDI, 37s.
    4BD1T going into a 96 F350 crew.
  7. #5
    Jul 2012
    Langley, BC
    30
    I'm curious about the cost too. Not listed on their site. Wonder what the dollars/db will be
  8. #6
    Sep 2012
    Pinellas County, Florida
    145
    1
    Subscribed and interested.
  9. #7
    Registered User Moochoff's Avatar
    Jun 2012
    Spirit Lake, IA
    950
    238
    Subscribed!
    Jake
    Current Build: 88 1/2T YJ, fueled 4BT, hx30w6, 5spd
    Old Projects: Dodge 4BT/47RH, 98 S10 5.7/4L60E/4.10
    Fabbing>Therapy
  10. #8
    Sep 2012
    Illinois
    20
    Would you need a pretty big radiator with that? I'd imagine a blanket like you described would trap heat. What about weight?
  11. #9
    Aug 2009
    Fort Stewart, Ga
    704
    27
    Here is the price list the companyís president Tim Thompson sent me
    4BT Quiet Kit:
    1 Center mount low mount turbo $325.00
    1 Valve Cover $150.00
    1 Oil Pan Cover $300.00
    1 Down Pipe Cover $100
    Total: $775.00
    like I said before its expensive, but right now the inside of my truck is so loud I have to blast my stereo to here and talking is pretty much out of the question unless you yell. Thatís mainly because I have very little insulation in my truck right now.
    I donít know if heíll lower the price for a group buy, but most places would if you can get a nice hand full of people to get a big order.
    After they get my parts theyíll be able to make a blanket for a HE351VE, center dump manifold, valve cover and the oil pan. My pan has been modified to clear my axle and a turbo drain was added, so if anyone has a modded pan like me youíll have to send them yours.
    2011 Toyota Tacoma
  12. #10
    Aug 2009
    Fort Stewart, Ga
    704
    27
    Videos and pictures are to easy, im not sure on the weight. as far as heat it will trap heat in but i dont know how much differnce its going to make.
    2011 Toyota Tacoma
  13. #11
    Supporting Member
    Jun 2010
    Newton NC
    6,985
    10
    I wouldn't think heat would be an issue. 4bt's generally run on the cold side. Most guys complain about them not heating up.
  14. #12
    Jun 2012
    Spirit Lake, IA
    950
    238
    Ive heard that manifold, turbo, and downpipe blankets will noticeably lower egt's... Looks as if the heat normally put off by the exhaust side is routed away from the engine bay and might balance out the gained heat from the other engine covers. No personal experience but interested in trying something when I wrap my project up
    Jake
    Fabbing>Therapy
  15. #13
    Jun 2007
    Stephenville Tx 76401
    1,271
    .. I was all worried about mine before I GOT it up an running .. Now 2 years later I never even notice it being loud .. Now I don't notice it being as loud as my 2000 dodge tr. If you can understand that I am used to my 2000 24 valve tr.
    ... I did not just step out of cheby gas tr. I've been in diesels truck for a while 91...93.. and now a 2000..and this farm 4BT FOR FUN MOSTLY ....
  16. #14
    Jun 2010
    Durham, NC
    1,637
    225
    Quote Originally Posted by steed View Post
    Here is the price list the company’s president Tim Thompson sent me
    4BT Quiet Kit:
    Total: $775.00
    like I said before its expensive, but right now the inside of my truck is so loud I have to blast my stereo to here and talking is pretty much out of the question unless you yell. That’s mainly because I have very little insulation in my truck right now.
    I don’t know if he’ll lower the price for a group buy, but most places would if you can get a nice hand full of people to get a big order.
    After they get my parts they’ll be able to make a blanket for a HE351VE, center dump manifold, valve cover and the oil pan. My pan has been modified to clear my axle and a turbo drain was added, so if anyone has a modded pan like me you’ll have to send them yours.
    While the prices seem high, if they have a significant dampening effect then it'll be worth it.
    Looking forward to testing results!
  17. #15
    Sep 2012
    145
    1
    any updates on this?
  18. #16
    Registered User brobrad's Avatar
    Sep 2011
    Moselle Mississippi
    1,179
    21
    Yup, I'd like to see before and after video with some good audio.
