I received your inquiry this afternoon and the rubber durometer of our 2469
is 60, which is typically a bit harder than most mounts run. More often you
will see 50 as the duro on a typical mount.
John Leonard
Anchor Industries
30775 Solon Industrial Pkwy.
Solon, Oh 44139
440-473-1414 x 439
http://www.anchor-online.com/
http://www.showmetheparts.com/anchor/
-----Original Message-----
Sent: Thursday, January 30, 2014 12:48 PM
To:
jtlanchor@oh.rr.com
Subject: Cummins motor mount info.
Hi. I have installed a Cummins 4bta into a 1981 Dodge Ram 2wd automatic p/u,
mainly for fuel mileage. I am currently using the oem slant6 mounts but need
to upgrade and I am researching which motor mounts to use. The Dodge frame
has mounting holes for the Cummins 2710 style mount. The Cummins 4 cylinder
motor is known for it's vibration, so I am considering using the V-8 mount
2469 instead, assuming that the rubber is a bit softer to absorb vibration
better.
Your advice please. Thank you
