Show off ur motor mounts. - Page 4
Page 4 of 13 FirstFirst 12345678910111213 LastLast
Results 91 to 120 of 381
Thread: Show off ur motor mounts.
  1. #91
    '69 FJ55 Land Cruiser dieselcruiserhead's Avatar
    Jan 2007
    Park City, Utah
    1,660
    Photos of Dodge Gen III 24 valve mounts:
    http://www.4btswaps.com/forum/showpo...89&postcount=7
    1991 Toyota Pickup, Mercedes 300D OM617 diesel
    1969 Land Cruiser project in progress with 4BT
    1989 Land Cruiser project in progress with 4BT
    2010 KTM 450
    Successfully installed 4BT, Isuzu 4BD1T, and Mercedes 300D engines into different vehicles.
  3. #92
    Jul 2007
    Pennsylvania
    52
    '79 CJ-7 4BT, NV4500, D300 w/ 4:1, D44 Front w/ ARB, AMC 20 Rear w/ Powertrax. not so much original anymore, though it may look close.
  4. #93
    Jan 2007
    MD
    1,203
    Quote Originally Posted by dieselcruiserhead View Post
    the ad says 2nd gen, but it does mention 3rd gen just having 4 holes.
  5. Remove Advertisements
  6. #94
    Jul 2007
    Elm Mott, TEXAS
    854
    Quote Originally Posted by BigTorqueCJ View Post
    I utilized poly AMC V8 motor mounts and fabbed the rest.
    Those look great, but is there any safety feature for if the rubber tears?
    Part number on them??
  7. #95
    Jul 2007
    Pennsylvania
    52
    I never thought of any safety feature.? I removed my AMC 360 in lou of a 4BT and just decided to mimick the original motor mounts in my CJ-7. I have no reason to believe that the mounts should tear, but I'm open to any input here.
    Part number ... I don't know. But you can find them in any Jeep catalog or any good 4x4 shop.
  8. #96
    May 2007
    WV
    168
    Default Motor Mounts for a Ford
    Has anyone tried using the 6bt mounts from Autoworl in Montana or from Fordcummins?
    You guys that have repowered Fords, did you fab your own mounts or go another directions? I've been thinking about trying to fab a set for my '95 F-150, but I'd feel better going with some off the shelf ones if possible.
  9. The Following User Says Thank You to RedZerOne For This Useful Post:
    Rickybobby0 (10-14-2016)
  10. #97
    Jun 2007
    University of South Florida
    1,068
    Default motor mounts
    heres a picture of our crossmember just made it today...
  11. #98
    Banned from 4BTswaps
    Aug 2007
    Southern, Maine
    24
    Default Crossmember/Diff clearance
    Off-topic but if that pic is representative of your mounting location, will there be issues with crossmember clearance and front Diff during uptravel?
    Is that a jeep CJ/YJ chassis and front dana 30?
  12. #99
    Jun 2007
    1,068
    very good! ya its a 79 cj 5, its got about 3.5" of clearence between the diff and the bottom of the crossmember.
  13. #100
    Feb 2007
    So-central Kommifornia
    3,391
    156
    Quote Originally Posted by bigorangecntry07 View Post
    I assume the 3.5" is the same clearance as between the springs and their max travel bump stops for compression? Also may I humbly suggest that you consider some flat 3/16" to 1/4" plate gussets at your weld zones, in front and behind? Just enough to reinforce during the infamous 'Cummins shake' at shutdown. With almost a dozen beads there is a chance for stress risers or hydrogen embrittlement and future fractures.
  14. #101
    Jun 2007
    1,068
    when we cut out the angles we reused to scraps to do that on the inside thats why theres two beads on each angle. and for the springs its about right the springs dont have much flex in them
  15. #102
    Aug 2007
    Southern, Maine
    24
    Is the 3.5" clearance measured "now" at an unloaded ride height...you may want to factor the significant weight and loaded spring "sag" that will occur once the 4BT is mounted inside the rails. A somewhat economical option /solution may be a spring over axle (SOA) lift but it is still $ and there is a host of steering geometry and axle-wrap considertions...gotta love projects - overtime/overbudget!
  16. #103
    Jun 2007
    1,068
    ya we are bolting in the cross member with grade 8 bolts so there is some room for adjustments once we get the motor installed. also we have a 4" suspension lift so it already has upgraded springs and they are STIFF.
  17. #104
    Aug 2007
    Southern, Maine
    24
    It will be an awesome CJ when it is completed...and crawl/idle over anthing with that low gear manual tranny. Best of luck
  18. #105
    Jun 2007
    1,068
    thanks thats what its going to be used for is rock crawling sort of, we are taking it up to our farm in tennessee for work and hunting buggy
  19. #106
    Jan 2007
    New Haven, CT
    1,305
    8
    About 2/3 relevant - My 6BT motor mounts:
  20. #107
    Jan 2007
    dictatorship of NY state
    642
    My mounts. used the P30 engine brackets, frame brackets and the original 5.0 driver side mount. The front corners of the block are a little close to the cross member, I will either notch the cross member or fab spacers to lift the mounts up but I'll wait until I get the 9" rear installed.
  21. #108
    Jan 2007
    642
    More
  22. #109
    Registered User GreasedPiggy's Avatar
    Apr 2007
    San Diego, CA
    126
    Very tidy!!!
    A bit tight like you said. That crossmember is awesome, I wouldn't
    try to notch if all I had to do is successfully shim up the motor 1/2"
    at the mounts. The crossmember is in a very good place structurally,
    and tying into your frame that close to it is great. You will have less
    frame roll and the load will distribute really well.
    So the question is "Will you get interference at the tranny hump or
    the hood or elsewhere if you go up a bit?"
    (That is one of the more straightforward 4bt repowers I've seen on here)
    1975 Toyota FJ-55, Cummins 4BT CPL 858, 4L80E, NP 241, Dana 60 front, 14 bolt FF rear, ARB lockers, Scout II PS, Crossover-steer, 4-wheel discs, TSL Q78-16.
  23. #110
    Registered User DarylB's Avatar
    Feb 2007
    White Hall, Arkansas
    500
    Default CJ8 Motor Mounts - Angled Dodge Style
    Bolted on using existing frame mounting points - Driver's Side
  24. #111
    Feb 2007
    500
    Passenger Side
  25. #112
    Apr 2007
    San Diego, CA
    126
    Thumbs up
    That's very ingenious use of existing hardpoints DarylB
    Is there gussetting under the (Blue) mount plate? Pretty important
    to strengthen the fore/aft direction in case of repeated hard braking
    or a (let's hope never) front end collision. (I realize those plates are
    super thick, well over spec, but the hard corners are places of stress
    concentration.
  26. #113
    Jan 2007
    642
    Quote Originally Posted by GreasedPiggy View Post
    Very tidy!!!
    Thanks. I've got about 1.5" between the top of the turbo and the hood so I've got plenty of room to go up, that's most likely what I'll do. The tunnel isn't a problem. I also used the original tranny cross member in the stock location so I can use the original rear drive shaft, not sure about the front yet with a 3-4'' lift for 36's.
  27. #114
    Feb 2007
    500
    concentration.
    They're welded all the way around w/ 7018 low hydrogen. If anything is prone to break it'll be the weak CJ frame before the mouting point breaks. If you notice on the driver's side I had a crack where the factory seam had broken and a few cracks. We welded it all the way up, and down into one of the bolt holes where it had cracked. I'm going to clean up the mounts later & Grind them down. Also my logic was to span the weight of the engine, between the two points, as to not already stress a weak frame. Thinking about doing a CAD design on them and see if They'd sell
  28. #115
    Jan 2007
    Dublin, OH
    120
    Figured I might as well throw my mounts in here. Used Dodge Cummins rubber, the stock plates on the frame (cut down a bit) and fabbed the engine side.
    Passenger Side:
    Drivers Side:
    1993 K2500 GMC Suburban 4BT NV4500 ~ Buildup Thread
    1984 VW Scirocco ~ Daily Driver
    1983 CJ7 ~ Offroad Toy / Suburban Tug
  29. #116
    Jul 2007
    Elm Mott, TEXAS
    854
    Quote Originally Posted by fangoul View Post
    Those look great!
    1979 F-250 4WD, NP435 trans, NP205 TX case, 3.54 gears. IP turned up, H1C from 1993 12V with 12cm housing, 3" in and out FMIC.
  30. #117
    Jan 2007
    Dublin, OH
    120
    Thanks! I ended up cutting up the $100+ AC mount I got from cummins because I liked those mounts so much Ended up being easier to cut up the AC mount and brace it rather than redoing the passenger side mount.
    Now if I could figure out how to get paid more maybe I could finish this damn thing this year
  31. #118
    Jan 2007
    N.IL.
    1,450
    2
    Here is an idea I am playing around with in a 98 Jeep TJ.
  32. #119
    Jan 2007
    New Haven, CT
    1,305
    8
    Quote Originally Posted by Ggg View Post
    I would gusset the frame mounts.
  33. #120
    Jun 2007
    Russellville, AR
    30
    Default 1973 Bronco Motor Mounts
    I modified the factory motor mounts from I ground off the Bronco frame. The picture show a few of the steps. It looks strong, factory, and maintains the original transmission and transfer case locations.
    James
