Extra High Mount A/C compressor water inlet bracket
Results 1 to 30 of 30
Thread: Extra High Mount A/C compressor water inlet bracket
    Apr 2012
    Va
    20
    Default Extra High Mount A/C compressor water inlet bracket
    So I am in the very early planning stages to swap the gas V8 in my early 90's Ford pickup to a 4bt Cummins. Something that really excites me about this possible swap is that, from what I read on here, the engine could be an actual bolt in installation using factory Ford and Cummins hardware. That is possible using the Ford 300 inline six cylinder gas mounts that used the rubber isolators (not liquid filled). Then the breadvan 45 degree engine block mounts and dodge rubber isolators. All hashed out many times over and detailed in this helpful thread. Conflicting 300 6 Frame Stand with Ford 4BT Block Mounts Compatibility Issue
    The next thing I wanted to figure out was how to maintain all the creature comforts that are available with the current gas V8, namely air conditioning. As is widely known on this site, the stock dodge 6bt setup mounts the A/C compressor way down low on the passenger side of the engine. This would pose two problems in the install in 80's and early 90's Ford pickups. 1) the compressor or lines would get into the engine crossmember and 2) this would not allow the use of the breadvan 45 degree engine block front mounts and 300-6 frame stands for a bolt in install.
    To conquer the first problem there is plenty of info around the site about using the "high-mount A/C" water inlet setup seen on early 90's F800 trucks and the freighliner setup which ran 5.9L cummins engines. This bracket raises the A/C compressor above the water inlet and also raises the alternator. There is a good example of this bracket in the following thread. a/c bracket.
    While the above "high mount water inlet" would solve the first problem, it would negate the possibility of using the 45 breadvan engine block mounts and Ford 300-6 45 degree frame stands for a bolt in install. This is because this alternative water inlet bracket uses the bottom three front engine block mount bolt holes to hold it to the block. Now, it appears from this post that it is possible to mill down that reinforcing rib going from the water inlet flange to the lower mounting area and still be able to bolt up the bread van 45 degree engine block mounts. Then there is also this post which the author states that he milled down the bottom section of the bracket to still use the 45 degree bread van front mounts.
    Both of the above examples solve the first problem and solve the second problem, albeit with modification to the water inlet bracket (possibly detrimental to durability??) I think I have stumbled on a solution that would solve both challenges with no modifications to any brackets or mounting points. I spied a Hyster forklift with an installed QSB6.7 while working on a job site that appeared to have provisions for mounting an A/C compressor in an "extra high" configuration. See the attached photo for explanation. This bracket mounts the alternator in what appears to be the "stock" location and mounts the A/C compressor above it, all on the same bracket. More-over, from what I could tell, this bracket did not utilize the front lower three engine mount holes that will be used by the breadvan 45 degree engine mount plates (see second picture). I was cognizant enough while taking these pictures to grab the ESN from the engine so this bracket part number (and supporting hardware) could be located on Cummins quickserve. This ESN is 22023207. The bracket part number is 5260168. In quickserve, it specifies that this setup accepts a 24Si alternator. I also measured the mounting points for what I suspect is the compressor stand-off's and came up with a top mount spacing of 92mm, bottom mount spacing of 87mm, and vertical mount spacing of 128mm. This mounting corresponds to the compressor mounting mentioned in this post. The only unknown is if this new extra high A/C mount bracket has the same gauge line measurement as does the F800/freightliner brackets for proper belt alignment.
    So, any thoughts on this? Think this bracket will work on the 4bt? Anyone have a good way to get a price on this bracket without driving down to the local Cummins dealer?
    New Registered User
    Jun 2008
    Hereford, AZ
    1,055
    234
    Quote Originally Posted by kawamatt2 View Post
    ... That is possible using the Ford 300 inline six cylinder gas mounts that used the rubber isolators (not liquid filled). Then the breadvan 45 degree engine block mounts and dodge rubber isolators. All hashed out many times over and detailed in this helpful thread. Conflicting 300 6 Frame Stand with Ford 4BT Block Mounts Compatibility Issue
    I found that this gave the wrong drive line angles, since the front of the 4BT was riding high in the engine compartment.
    If you go to my build thread in my signature below, the details are available. Starting at Post #59, I start to see that something is wrong. At post # 65, DarrenGT gives a summary of problems with using the stock 300 CID (straight 6 cyl) engine stands.
    Quick summary: As near as I can figure out, the frame kick-up on the F150 & F250 chassis is different than the frame kick-up on the E350 chassis. When using the Cummins 4BT E350 engine mounts, with Ford 300 engine stands, on the Ford F150/F250 chassis - The center line of the drive line is no longer parallel to the center line of the rear axle pinion.
    Russ
    p.s. This swap is <slowly> being completed. Life had other plans for a while...
    Supporting Member
    Jun 2010
    Newton NC
    6,845
    8
    I'd say that part has possibilities. I believe the water inlet mounting area is the same on the B series engines and the CR units which is the QSB 6.7. The one thing I see in the photo is the 4 mounting pads at the top seem to be spaced too far apart for most ac compressors. Of course you could make a steel mounting plate to attach the compressor to the bracket. There is a similar bracket for the QSB4.5 but it had only 1 mounting pad instead of the 4. Not sure what it was about. Might want to sit down when you ask Cummins for the price. I'd guess in the $200 plus range. The other option is to mount the ac on the driver's side next to the #1 valve cover. Freightliner and Case Tractors had this option. That one isn't cheap either. What you see in the photo below is about $700. A custom fabricator could do something far cheaper.
  5. Remove Advertisements
  6. #4
    Apr 2012
    Va
    20
    Quote Originally Posted by Russ McLean View Post
    Russ
    Thanks for the info Russ! So if I am understanding you right, the front of the engine is riding higher than it should be? Resulting essentially in the angle of the ujoint at the trans or transfer case being less than the angle at the rear axle? I would think that if you measured the new angle of the powertrain, you could add leaf spring shims to compensate the rear axle, no?
    Quote Originally Posted by char1355 View Post
    Great info, thanks!
    Very good concern and I realize that the mounting points look "off". Possibly the angle the picture was taken or the snow tricking your eyes. If you read the bottom of the 5th paragraph of the original post though, you will see that I measured the mounting points. To reiterate, the spacing between the top two standoffs is 92mm, the spacing between the bottom two standoffs is 87mm, and the spacing between the top set of standoffs and the bottom is 128mm. This corresponds (according to this thread) with the mounting points used on the freightliner/F800 compressors, which are SD7H15 style and specific Sanden part number of 4474. So....the only unknown at this point is whether the gauge line (distance between front mounting points to pulley midpoint) is 49mm on this new bracket as it is on the Freightliner/F800 brackets.
    Diameter (A): 119
    Gauge Line (B): 49.00
    Dimension C: 92.00
    Dimension D: 87.00
    Dimension E: 128.00
  7. #5
    Jan 2007
    N. AZ I-40
    2,204
    39
    Cool. One more option. But...will it fit under the hood? Probably sits as high as the ac mount above the injection pump.
    69 Bronco 4bt/HE221/NP435/203/205, 3.54 D60s OX locker F/Detroit R, military H1 beadlocks and 38" rubber
    "sealing the deal on this forum section as a whole..(and/or his entire membership here){which has been an issue before}ps: you were warned.... Redhedbronco reported for vulgarity character attack."-47Ford-1.5Ton ​A few ratty whiners here!
    Please, Drifter, don't give me any more advice because I can't afford it and I don't want to destroy my engine or truck.-JimmieD
  8. #6
    Apr 2012
    Va
    20
    Bet your right. Don't think it will be an issue in a Ford F-series package though. Are there other instances where you would be using the front engine mount locations (and need this bracket) in a smaller engine bay? Seems like most smaller truck installs usually include some form of custom mounts anyways.
  9. #7
    Oct 2011
    Marysville, Pa
    51
    2
    I agree with russ that the engine sits too high in the engine bay with the 300 mounts. Also, my truck is a 1995 f150, and my frame standoffs were behind the cross member, but the engine stands are almost centered on the cross member. It was easier in the long run to just fab motor mounts with the engine in place. The AC mount does look promising though, and an F150 definitely has the hood clearance for it.
  10. #8
    Jun 2011
    Oregon
    538
    2
    The bracket in your picture will NOT fit the older 2 valve B series engines. The upper portion of that bracket is 100% specific to the commonrail cylinder head design. That bracket would be about an inch off from being able to fit the 2V head design. It is too close to the head. Another significant downside to the Cummins bracket is it's REALLY tall. It hangs the top of an AC compressor quite a ways above the top of the valve cover(s) where it would be in the hood in many conversions.
    I'm almost finished with an accessory mounting system for the older B series engines that will solve a lot of issues for the conversion guys. It was partially inspired by the bracket in this thread, but doesn't have any of it's shortcomings. The system we are manufacturing is designed to accomodate all common 8 groove pulley alternators and AC compressors including all the Ford 4G, 5G, 6G, FS10 and Dodge Denso and Sanden pieces. In addition the system includes a universal upper waterneck that can point in any direction and support multiple different hose diameters. The lower water connection is also configurable for different hose diameters.
    The part number I have for that bracket from Cummins is 5260171. You will need a lot more than the bracket to make it work even on a commonrail engine as it only fits specific industrial alternators and AC compressors.
  11. #9
    Supporting Member
    Jun 2010
    Newton NC
    6,845
    8
    Yes, that is something I forgot about. On the CR head the water outlet and thermostat housing are on top of the head. On the B series it comes off the side of the head. 69Rambler the part you're working on sounds great. Can't wait to see it.
  12. #10
    Apr 2012
    Va
    20
    Quote Originally Posted by 69rambler View Post
    Darn! There goes my cheerios! Could you possibly elaborate some more on this? I understand the 2V head has the thermostat pointed to the off drivers side of the head and the 4V has it pointed strait up. So you are saying that the cast-in thermostat housing of the 4V head is not as large as the bolt on upper water flange on the 2V head, therefor this new bracket wouldn't sit flush over the upper water outlet? If I look at this picture though (borrowed from this thread) it looks like the mounting point for the lower alternator mount in this instance would be the mounting point for the upper two bolts in this new bracket. Can you explain in what way this new bracket wouldn't match up with the water outlet pictured below? Would the holes not line up vertically or horizontally, or would there be interference? You seem like you've already been down this path, have any other threads you could link to or pictures of interferences?
    How would this bracket put the A/C compressor any higher than the alternator in many of the "high-mount" setups posted on this site? Reference the picture above. That alternator and bracket sure looks higher than the valve cover. No argument intended, just looking for data.
    Great news! Have any pictures or more specific description of what you are working on? Are you selling anything yet? Have a website? What are some of the shortcomings of this bracket, other than it likely not fitting a 2V head? Thanks!
    You reckon cummins would have only put one part number on that bracket? In looking on the parts list in QuickServe for the ESN I listed above (22023207), Cummins lists two part numbers for that water inlet bracket: 5260169 and 5260168 which are both close to your 5260171. Wonder if your number is a later revision? Do you have an ESN to go along with your 5260171?
    Understood you will need more than just the bracket, but this thread was pertaining specifically to that bracket. Also, did you read my first post all the way through? What do you consider an "industrial alternator and AC compressor"? I've already mentioned twice that the mount pads for the A/C compressor on this bracket are the standard dimensions for Sanden SD7H15 compressors. Also, QuickServe mentions this bracket fits a 24si alternator.
    Thanks for any other info you can provide!
  13. #11
    Jun 2011
    Oregon
    538
    2
    The picture in your post above is the Ford/freightliner bracket. I have used these in a couple swaps and wouldn't use that path again. Especially on a 4BT where front mounts are required. The bracket in your original post is nothing like the Ford/freightliner mid mount.
    The part number I listed was cast in the bracket I had which was recent production. A 24SI alternator with an 8 groove pulley is not a pickup application. The connection locations for the AC compressor you choose is a very important factor you may be underestimating, especially true for the ford/freightliner setup. The downsides to the bracket in your original post are- It hangs the AC compressor way above the top of the engine, it will only fit the commonrail head design engines. The bolt pattern and spacing is completely different from the 2V style engines. Most 2V style upper waternecks are not conducive to the AC compressor being right there.
    There will be pictures and information on our website when the parts are ready in a few weeks. This has been a concept of mine for years, we've machined dozens of application specific Cummins accessory mount systems to get around the problems associated with the EXPENSIVE and not so versatile Cummins offerings. The thing that makes our kit so appealing compared to anything else is the combination of alternator and AC flexibility, compactness and completely universal water connections. You can point the upper neck at any compound angle you want, it rotates 360 in one axis and 90 in another and you can choose between 1.5 or 1.75" upper connections and 1.75 or 2" lower connections.
  14. #12
    Apr 2012
    Va
    20
    Good advice! If you noticed my first post though, I've already (along with alot of other fellows on this site) deduced that using the "Ford" bracket prevents the use of front engine mounts.
    Understood; the Ford bracket is nothing like the bracket from the QSB6.7L. My question was, can you explain (with pictures and hard data/measurements) how the bracket mounting is different up near the water outlet when comparing the 24V head with the 12V head. Do you have any specific info other than "it just won't work, so don't try it and buy the widget I'm producing instead?" This forum is about sharing information, no?
    I don't doubt this, did you think I was questioning your part number? The more part numbers we can put to this stuff, the better!
    Nor is the 21SI alternator requirement of the Ford setup posted above. The medium duty offerings are definitely not unobtainium though. I wouldn't let the fact that I can't re-use my stock (to the truck) alternator hold me back from a swap, nor would it seems anyone else on this site. Is it very common to re-use the stock alternator on a 4bt swap?
    Very good point! And it bears repeating in this quote. Although, as mentioned, I have done some research on the mounting platform and outlet connections and believe the best option for this style of high-mount compressor bracket is the Sanden 4474. It has the proper mounting arraignment, common connection sizes, and side outlet connections. Is there some other consideration a person should take into account?
    Hope! So are there some that might be better suited for this? Just looking for options here. Any pictures/part numbers/measurements you have would be appreciated.
    There will be pictures and information on our website when the parts are ready in a few weeks...The thing that makes our kit so appealing compared to anything else is the combination of alternator and AC flexibility, compactness and completely universal water connections.
    Would you have a link to your website or any documentation of prototype installs and such?
    Thanks for your help.
  15. #13
    Jun 2011
    Oregon
    538
    2
    As I stated above, the commonrail high mount AC bracket does not fit the 2V head design because it is atleast an inch too close to the head for the 2V waterneck to fit. The bolt pattern in the commonrail head is similiar to the bolt pattern in the industrial 2V engine waternecks, but it isn't the same and it's shifted up or down some (don't recall exact vertical difference right now).
    I think replacement parts sourcing is a very important consideration when doing a diesel conversion. If you use an alternator or AC compressor from an industrial/medium duty application the cost is going to be much more than a pickup version of the same part and availability may not be as good.
  16. #14
    Nov 2013
    Redding CA, Texas Resident
    60
    12
    So what did you end up doing? I am looking for options for my Jeep.
  17. #15
    May 2008
    Mesa, AZ
    1,258
    22
    I fabbed an aluminum plate and some aluminum brackets that ended up being very similar to that F800 bracket, but the compressor and alternator are closer together and the alternator sits much lower:
    The compressor is an ear-mount Seltec,and the outer ears are used for support brackets for the alternator. The only problem with this arrangement (which I didn't realize at the time) is that the Seltec compressors are NOT meant to be mounted with the ports more than 45° from vertical, as it can cause oiling issues. Sanden compressors can be mounted 90° from vertical, so they would be the logical alternative.
    Beware: I had issues with belt squeaking and shaving rubber dust on the compressor. It turned out that the accessory bracket mounting surface on the upper water neck was NOT perpendicular to the front face of the engine! The compressor and alternator sat cocked at a slight angle which caused the belt to ride on one edge instead of flat and even. It was not visually noticeable until I recently put the bracket back on after resealing the engine. Something looked a bit off, so I threw a square on it and lo and behold it was quite a bit off. I had to machine the spacer between the plate and water neck at a matching but opposite angle to compensate. It's square to teh block face now and should fix the issues.
    Also FWIW, I may end up running a Seltec TM-21 compressor if I can get the outlets to clear the oil filter housing. Second option is a Seltec TM-16. The TM-15 I had on there never moved enough gas at idle and low speed due to the smallish crank pulley on the Cummins (only 6-3/4" OD vs 8" OD for a Chevy 6.0 gas engine crank pulley), so the AC worked like crap at low speed and idle during the summertime. A 16 will be better than the 15, but the 21 will easily match the performance of the stock R-4 compressor on the 350 TBI gas motor (which had an 8" crank pulley) that my truck originally had. The 21 is a direct mount, however, so I would have to modify my brackets. The 16 is available ear mount, but it may not clear the oil filter housing with the ports in the proper vertical position. More experimentation is needed...
    1991 V1500 Blazer (Silverado), 5.9L 12V P-pumped Cummins (5x .012 sac injectors, #6 fuel plate, WH1C with external 38mm wastegate running 30psi), NV4500 with 1-⅜" input shaft, SBC Con-O clutch, NP205, HAD, 4.10 D61/14BFF spinning 37" Nitto Exo Grapplers
  18. #16
    Nov 2013
    60
    12
    Ok legit, very detailed. Thank you very much, I will look into this and see what works.
  19. #17
    Jan 2007
    Tardis
    2,859
    7
    Quote Originally Posted by MaxPF View Post
    Max, that is almost exactly what I had planned for my alternator position with my Ford acc mount. I am thinking of keeping my alternator mounted to the water outlet and running a brace up from one of the compressor mounting bolts. Did you have any issues with belt squeal with that amount of wrap? I think you and I must have the same engine since I see you have a forward shutdown solenoid as well. I haven't seen many setup this way yet.
  20. #18
    Oct 2013
    Idaho
    208
    44
    I used this one from Jonseys off road.
    Same one here: http://dieseladapters.com/Quick_Mount_Cummins_AC.html
  21. #19
    May 2008
    Mesa, AZ
    1,258
    22
    Quote Originally Posted by twiisted71 View Post
    I had no squeal for the first few months. However, as i found out recently the water neck on my engine wasn't square to the block face, so my bracket sat a couple degrees out of square. This caused the belt to wear wierd and it started squealing. Left rubber dust all over my compressor and alternator too. Anyway, I fixed that issue but haven't had it running yet since the fix.
    I think the forward solenoid is standard for 6BTs with the P-pump. I bet Dodge moved it due to fan shroud interference. Does yours have the magnetic fan clutch?
  22. #20
    Jan 2007
    Tardis
    2,859
    7
    OH LOL I just realized you have a 6BT! I have a 4BT set that way. More proof of the swappability of parts.
  23. #21
    New Registered User
    Sep 2014
    West Plains, MO
    2
    Hey I recently completed a 6BT swap in my 97 C3500 Dually. I used the industrial a/c bracket which accepted my factory 6bt a/c compressor. My 6Bt was from a 94 Dodge 2500 truck. I have a belt alignment issue with the a/c compressor on this bracket with the harmonic balance. It is almost 3 grooves off, 1/4 inch. There is no adjustment to the bracket, and my new a/c compressor matches the one I took off. Anyone else have this issue? I have attached some pictures of what I have. The a/c compressor pulley sits too far rearward, toward the firewall.
    I used the original a/c bracket, cut the top and bottom off it, and put it on top of the new a/c bracket so my radiator hose nipple would come out horizontal. The bracket I got from Cummins, part# 3930888
  24. #22
    New Registered User
    Sep 2014
    West Plains, MO
    2
    So I found my answer after some SEARCHING lol. I guess the ''gauge line'' is the distance from bolt hole center line to the center rib on the pulley. The stock 94 dodge a/c compressor is about 44.45mm best I can tell. I found another post showing the compressor for this bracket needs to be 49.0 mm. This would move it up to about where it needs to be, about .180 forward of its current location.
  25. #23
    Apr 2011
    Houston, Texas
    214
    I liked the Jonesey mount and bought one, but would like to use a high output alternater, 200 or more amps. Does anyone here know if such a matchup is possible without major mods to the accessory mount? Can't seem to get a response from Jonesey (?).
  26. #24
    Jun 2011
    Louisiana
    516
    14
    Why not use your factory compressor and fab a mount like this.
    2006 Hummer H3 - on the road....tuning in progress
    4L60e w/ US Shift controller
    4BT CPL 1260, VE pump, BW 171270 turbo
    Build Thread
  27. #25
    Apr 2011
    Houston, Texas
    214
    Hey J Mack --- I notice the your mount locates the Cummins tensioner diffrently than my Jonesey's plate. Mine has another plate for the tensioner that extends out quite a ways. Did you mod yours to that configuration or did it come that way. I like the tucked in arrangement much better.
    Also notice you have a fluid dampener. Have you run it yet? If so, how do you like it?
  28. #26
    Oct 2013
    Idaho
    208
    44
    Quote Originally Posted by Tango88 View Post
    I changed the pin location on a Cummins OEM belt Tensioner #3934819,gates 38525 to make it work with my mount.
    I also used a 200 AMP single wire alternator from these guys, http://www.paperformance.com/scripts...?idproduct=291
    Still working on the swap so I have nothing to report on the Fluid Dampener yet. Build thread here will get updated when I get it running: http://forum.ih8mud.com/threads/target-carrier.796065/
  29. #27
    Apr 2011
    Houston, Texas
    214
    Thanks J Mack --- but I still don't get how you mounted the Gates. The plate I got from Jonesey's came with an extended tensioner mount as seen in the pic below. Did your come in a different configuration?
  30. #28
    Oct 2013
    Idaho
    208
    44
    Looks like you either have an earlier or later version of the mount then mine. Not sure if Jonesey’s is still in business or if they just changed owners but diesel adapters made the Jonesey’s mount and you can see it here http://dieseladapters.com/images/77b...3407e1af17.jpg
    I would contact them and try to find out what you have.
  31. #29
    May 2008
    Mesa, AZ
    1,258
    22
    Made some mods to my accessory brackets. Here's what it looks like now:
    There's more than 180° wrap on all pulleys in this setup. I had to move the tensioner below the compressor and add an idler pulley between the compressor and alternator. Also required was a different lower water neck, as the original one interfered with the new belt routing and tensioner.
  32. #30
    Supporting Member
    Jun 2010
    Newton NC
    6,845
    8
    That setup should never slip a belt.
