What came with the 4BT back in '95
Results 1 to 11 of 11
Thread: What came with the 4BT back in '95
    Apr 2013
    California
    15
    Default What came with the 4BT back in '95
    Due to smog rules I've got to use in my case a '95 or newer but, I don't want to use later than '96 because it would have to be smoged every year. Therefore as I start the search for a donor, what vehicle(s) did the 4BT come in back in '95-'96?
    Moderator
    Sep 2008
    Alaska
    3,853
    67
    Quote Originally Posted by peter edmund View Post
    PE, I ran in to the same problem here (Alaska) with emissions testing a swap several years ago, I ultimately resolved it by choosing an older swap recipient.
    Best of luck.
    Oh, if you want, the NPR Isuzu and W4xxx series of GM "Forward Control" cab over trucks came with the 4BD2-TC Isuzu for power, they even had an overdrive auto (that particular trans is much maligned, I believe with the engine properly producing power, an external trans cooler and filter a stock Jatco should last indefinitely with proper maintenance when loaded to anything less than he NPR's 14,500Lb gross weight rating).
    New Registered User
    Jun 2008
    Hereford, AZ
    1,055
    234
    ... what vehicle(s) did the 4BT come in back in '95-'96?
    Step vans - Look for retired bread trucks, chip trucks and maybe a parcel delivery truck. Note that UPS scraps all their old trucks, consequently, the UPS motors are very scarce on the used parts market.
    Make sure that the engine that you by has a legible EPA sticker that states that the engine meets the EPA on-road requirements for the specified year of manufacture.
    EPA off-road engines from agricultural and construction equipment will not meet the requirement.
    NOTES: The EPA on-road engines are not legal in light duty vehicles. There are more details somewhere on this site.
  5. #4
    Moderator
    Sep 2008
    Alaska
    3,853
    67
    Quote Originally Posted by Russ McLean View Post
    Russ, excellent point!
    I assumed (yes, ass you me, duh ) that the OP would be familiar with the "light duty" vs "medium duty" emissions regs, I should have asked.
  6. #5
    New Registered User
    Jun 2008
    Hereford, AZ
    1,055
    234
    Quote Originally Posted by nexxussian View Post
    I know what you mean - I forgot the Isuzu engines - probably a better choice, since the Cummins 4BT is now spendy.
    Peter, consider an older Dodge or Ford diesel truck that is EPA and California smog approved. I would hate to have you get lots of time and $$$$ into the project and run into registration problems.
    The "wise-ass" in me recommends moving out of CA.
    Take a look at my build thread. This is a "relatively easy" swap. Well over a year and lots of $$$$ spent - and I'm not done yet.
  7. #6
    Supporting Member
    Jun 2010
    Newton NC
    6,672
    7
    Trying to pinpoint a 4bt that was made between 95-96 may not be an easy task. If you find a possible engine run the serial # past Cummins and they can tell you all about it, date of manufacture, epa certification, etc. If it didn't have a serial # I'd pass on it. Every states rules seem to be different. Some have no regulations at all. Also the older the vehicle the more latitude you'd have in an engine search.
  8. #7
    Apr 2007
    Minneapolis
    720
    4
    My 95 build Ppump engine was in an Oshkosh built stepvan, I think the same chassis/sheet metal as the freightliner. FLH?
    Judging by the layers of vinyl lettering on it, This truck was FedEx ground,then RPS(roadway) before it hit the auction block, where the fella I bought it from picked it up for about $1600.
    While ups does have contracts with wrecking yards to destroy it's fleet vs resale, I have talked with a wrecker who would be more than happy to sell me an engine, axle, transmission.
    99 Durango 4BTAA P pump, Glowshift gauges, hx30w9 (today), 3K GSK, custom ground 100 plate, AFC tuned, 96 47RE +billet single disc TC)
    My Build thread
  9. #8
    New Registered User
    Nov 2011
    KC, Mo
    2
    So you possibly havbe a lead on multiple 4bt's?!!!
  10. #9
    Nov 2008
    Stony Plain Alberta
    2,934
    1
    My van was an 89 model year and the 4BT I pulled out of it was a 93 Recon. Find a 95-96 Recon tag and stick it on the 4BT of your choice.
  11. #10
    Dec 2009
    Palmyra, Nebraska
    365
    2
    Quote Originally Posted by khaoskustoms View Post
    Intriguing.
    I have an aftercooled 4bt that still has the recon CPL /ESN tag on it.
    It may well be something worth hanging onto in the long run.
    Now if I could just find some JWAC injection lines for the darned thing!
    Mark.
    The election is over, the talking is done.
    My party lost, your party won.
    So let us be friends, let the arguments pass.
    I can pat my elephant, you can pat your ass.
    We're on a rocket sled to societal failure and the pilot is a freaking madman in a straightjacket.
  12. #11
    Apr 2007
    Minneapolis
    720
    4
    Having a later year (1996) recon tag IS NOT the same as having a (1995) epa tag. (example)
    My Build thread
