4BT specs
Results 1 to 5 of 5
Thread: 4BT specs
    Jun 2013
    Victoria, Australia
    43
    6
    Default 4BT specs
    Hey guys, I'm considering a Cummins 4BT conversion on my 1997 Fairmont Ghia, at the moment I'm running an I6 gas engine with some work done to her. It is also 4L.
    I'm curious if it would fit in my engine bay, its also about 100kg heavier than the optional 5L Windsor V8.
    The heat shield is covering the exhaust manifold, is the 4BT engine the same side for the exhaust?
    What would I be looking at for a good second hand 4BT engine?
    Thanks much guys.
    Nov 2012
    Southern Indiana
    28
    Welcome to the site, Look thru the sticky's as what you are looking for is in there. Yes the Exhaust is on the right side of the vehical.
    Feb 2007
    So-central Kommifornia
    3,391
    156
    Welcome to here, Damo! Check out the threads in the Project Build section, one of the guys stuck a 4BT in a '74 Plymouth Satellite. There's also a '39 Chev hotrod build that has some good pics of engine naked in frame to give an idea of dimensions.
    Main problem is height, 4BT is very tall. Don't know where you'd find one in Australia, but stateside the going price is at least $2,500 to $3,000 lately, but for 'deals' a guy runs into.
    Specs:
    Bore and Stroke 4.02 in. x 4.72 in.
    Displacement 3.9 liter (239.3 c.i.)
    Compression ratio 17.5:1
    Rated Speed 2800 rpm
    Peak Torque 1700 rpm
    Dry weight (base engine) 570 lbs.
    Horsepower 4BT 105 @ 2,800
    Torque 4BT 305 ft lbs
    Dimensions:
    Model - Weight - Length - Width - Height
    4BT - 705 lb - 30.1" - 24.9" - 36.9"
    4BTA - 725 lb - 30.1" - 24.9" - 36.9"
    Also you need a Cummins Adapter Plate to go between engine and bellhousing.
    Please, READ STICKIES at top of forum sections!
    1967 Dodge Town Wagon now D-200+ - CPL 858 - HTT Stage II/H1C 16cm2 Ex/58mm Comp wheel, no W/G, turned fuel pin, twisted screws, 3,200 spring, milled head, '92-'93 CTD intercooler [THANKS BILL!!!] Dodge NV4500, 4.10 DANA 60HD rear, '72 Dodge D-200 front axle, 1 ton+ springs, Air-Lift front airbags, front/rear swaybars, Tom Wood's driveshaft, Hercules All Trac A/T in LT 245/75-16.
  5. Remove Advertisements
  6. #4
    Supporting Member scout4bta's Avatar
    Jan 2007
    Mesa, AZ
    2,193
    40
    The 4BT wet weight is about 750 lbs (340 kg).
    NRA Life Endowment member
    1980 Scout II:92 Dodge CAC, NV4500, 3.73 gears, Atlas 4.33,33/10.50 BFG KM2, HE221W 6cm2, 3200 GSK. Cold air intake & snorkel. Mileage:low 20s to high 20s. The swap
    91.5 Dodge W250 CTD
  7. #5
    Feb 2007
    3,391
    156
    Quote Originally Posted by scout4bta View Post
    True, not counting Cummins adapter plate, flywheel, clutch assembly & hydraulics, bellhousing, transmission, fabricated motor mounts, aftercooler and maybe things like P/S, P/B or Hydroboost.
