My '68 Kaiser M715 - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 61 to 90 of 125
Thread: My '68 Kaiser M715
  1. #61
    Jan 2007
    near baton rouge, la
    805
    mike, you never ran it with the 6.5?
    1942 wc-53
    4bt/4l80e/compushift/np241
    dana 60/14bolt 4.88 38.6"tires
    http://www.4btswaps.com/forum/showth...highlight=Wc53
  3. #62
    Jan 2008
    Richboro, PA
    390
    6
    No, but the engine got installed in a mid-80's short bed 4x4 Chevy. It runs it's tail off for a N/A 6.2 We used an intake manifold off a 6.5 N/A 1 ton van. It is really tall, sort of like a big block Dominator intake. The thing revs like a small block.
    I'm pulling the 4BT and swapping in a 12 valve/ Allison 2000 this summer
    Here are some snow pics of the truck.
  4. #63
    Jan 2007
    805
    what gears in the axles?
    4bt too small for what you are doing?
    edit: i see you now have 4.56? right? what were they before? i went 4.88 this time
    what tranny?
    1942 wc-53
  5. Remove Advertisements
  6. #64
    Jan 2007
    805
    i think you will be happier with A 12V. the 4bt is too small for the gears you are trying to run
    1942 wc-53
  7. #65
    Jan 2008
    Richboro, PA
    390
    6
    Actually, I am plenty happy with the 4bt for general work purposes, but the NV4500 has too much of a difference between gears. An automatic would do the trick, however I got the 5.9, so I will hunt down an Allison 2000 and have more than enough grunt for anything I want to do. The 4bt will get a 4L80 behind it and find it's way into a Waggy for my wife, or possibly the '65 Power Wagon up the road from me if I can steal it from the guy.
  8. #66
    Jan 2007
    805
    you try a 3200 spring? or adjusting the pump any?
    i felt the same on the nv4500....
    1942 wc-53
  9. #67
    Jan 2007
    Tardis
    2,859
    7
    Found my new screen saver! What a beautiful pic
  10. #68
    Supporting Member
    Jul 2008
    Ojai CA
    1,640
    14
    Yes Mike: Very cool picture. We don't get snow like that out here. or even close. I drove thru Victorville coming home from the SHOT Show in Vegas 3 weeks ago and there was 2 feet of snow on the ground. but it was 41 degrees so it was melting fast.
    I think the 12VV, and Allison would be a great motor/drive train for your 715. Those are big trucks and they are as big or bigger than a Dodge 3/4Ton pickup so as long as the engine bay will swallow it, I say great!
    I think the install will be relatively easy, since you already have the 4BT inthere. Only thing I'm not sure about is whether the front drive shaft will clear the Allison on the right side. Most of the 4wd Allison applications are drivers side drop, aren't they? if it won't then you'll have to come up with a left side front axle. I would recommend a Ford Application one as the Dodge D60 axles have weird hubs and knuckles and are difficult to fit releasing hubs to. They don't have freewheeling hubs from the factory, and constantly turning the front end with a locker will kill any fuel mileage hopes for good.. The Fords have more conventional hardware and Warn makes hubs for them, I have them on mine. Milemarker makes hubs for the Dodge application but they are kind of Cockamamie Contraptions. Once you see the Dodge front knuckles apart you'll see what I'm talking about. It's real obvious, as they are completely different from every other application.
    Still I like the idea to change to the bigger drive train. It would make the truck a much more usuable tow vehicle. Also with 1200 lbs on the front axle it will climb like a goat.
    Randy.
    DeScrambler: Built from scratch, 4BT,TH400, USGear OD, Atlas 4.3, HP D44/ 4.10 ARB, HP D60/4.10 ARB, 37" MTR's
    It's not how well you do what you know how to do.
    It's how well you do, what you don't know how to do.
  11. #69
    Jan 2007
    805
    you going to intercool the 12v?
    1942 wc-53
  12. #70
    Jan 2008
    Richboro, PA
    390
    6
    Quote Originally Posted by W.R.Buchanan View Post
    Randy.
    Well, it has a divorced NP205 transfer case, so the pass. side pumpkin won't be an issue. I can change the mount to drop the driveshaft to whatever height is required to clear the Allison.
    Quote Originally Posted by mcinfantry View Post
    I started out with just the spring, then turned some screws. The motor is putting out just fine. I get into some situations where the engine is lugging, but one gear down and it is defueling at 3200. This motor mated to a 4L80 in a Wagoneer will be perfect for my wife to cruise in.(sitting on 35's and GM 1ton axles of course)
    Probably. Haven't come up with a game plan for that yet.
  13. #71
    Jan 2008
    Richboro, PA
    390
    6
    It was a good runner. 4 solid years of service, beating the snot out of it on a daily basis. The motor is a knockin'. Not bad for a free motor!
  14. #72
    May 2012
    Texas
    2,790
    50
    Very sweet truck
  15. #73
    Jan 2008
    Richboro, PA
    390
    6
    Quote Originally Posted by Drifter View Post
    Very sweet truck
    Thanks! The weather has not been kind to it. and it has deteriorated a bit since most of these pics were taken. Time to sell it/part it out, and step up to something bigger.
  16. #74
    Sep 2010
    SC
    12
    Nice truck. Always liked those trucks.
  17. #75
    Jan 2008
    Richboro, PA
    390
    6
    Quote Originally Posted by lobie View Post
    Thanks! This one might be sold. Had an interesting offer on the rolling body yesterday. I'll keep the engine/trans to rebuild for another project. We'll see if the guy comes up with the cash.
  18. #76
    Jan 2007
    New Haven, CT
    1,288
    8
    Quote Originally Posted by poolmike View Post
    Say it aint so!
    1963 Jeep J300, 4BT/NV4500/NP200/D61/D71
    1969 Jeep M715 6x6 project, 6BTA/NV4500/NP205/D60/D70/D70
  19. #77
    Jul 2008
    Southern Wisconsin
    631
    1
    Well if the "might" falls through, I know my brother would at least like a crack at the rolling chassis. What about are you asking for it? PA might be a bit of a haul, but he's not scared of windshield time if the price is right. He's been on serious Kaiser withdrawal since he sold his last one.
    1995 Dodge Ram 2500 6BT Manual Tranny 4x4 on 37" Military Michelins
    1980 Ford Bronco 4BT with Solid Axle Swap riding on 37" Swampers
    2000 VW Jetta TDI fuel sipper
    2003 VW Jetta TDI Wagon family hauler
  20. #78
    Jan 2007
    Paisley, Pa USA
    4,013
    12
    HINT! Maybe this new discussion on the project sale needs to be taken over to the PM side? Thanks & appreciated! HINT HINT!!!
    BobS
  21. #79
    Jan 2008
    Richboro, PA
    390
    6
    Quote Originally Posted by Ryan P. View Post
    Quote Originally Posted by BobS View Post
    If the deal falls through and I decided to send it down the road for sure, it will hit eBay or the "for sale" board here. Point taken Bob! sorry.
  22. #80
    Jan 2008
    Richboro, PA
    390
    6
    Quote Originally Posted by Mikel View Post
    Say it aint so!
    It ain't over yet.....I do have an extra 12 valve sitting here, but I am craving a bobbed M818 and my thoughts were leaning toward possibly selling the 715 for the needed funds. That was before the motor let go. The knocking engine is a game changer. The 12 valve would make this truck really move along. I have to do some soul searching before I do anything.
  23. #81
    Jan 2007
    New Haven, CT
    1,288
    8
    We just put a 6BT in a friend's M715. Very easy swap, with no firewall cutting. PM if you want some photos.
    How's the '47 Dodge coming along??
  24. #82
    Jan 2008
    Richboro, PA
    390
    6
    Shoot me some pics if you get a chance. The '47 is at a stop right now. I need money. I am busy working but money just seems to disappear a lot faster these days. I hope to finish the '47 next year.
  25. #83
    Jan 2007
    New Haven, CT
    1,288
    8
    Here are some pictures... Let me know if you want any details shot.
    http://www.m715zone.com/vb/showthread.php?t=22079
    http://s305.photobucket.com/albums/n...ion/?start=all
    My friend is extremely pleased with the truck. Mileage is about 15, but with tons of power.
  26. #84
    Jan 2008
    Richboro, PA
    390
    6
    That truck looks nice. I have to seriously think about an intercooler this time around. I was thinking of using one from a Sprinter, but if the factory Dodge unit works, I'll grab one of those. I'm going to my storage garage next week to get the engine. I'll bring it home and bolt all of the ancillaries on it, paint it and get ready for the swap.
  27. #85
    Jan 2007
    New Haven, CT
    1,288
    8
    Mike,
    Unfortunately all I have is these two crappy photos, but a 1st gen dodge intercooler (along with a $130 Howe radiator available from Summit) fit very nicely.
    The reason for the howe radiator is that the lower inlet in the stock radiator comes out right where the tensioner is in the 6BT. This involves moving the radiator support one hole outward. The driver's side inner fender needs to be massaged a bit too.
  28. #86
    Jan 2008
    Richboro, PA
    390
    6
    I have the Griffin rad, and I will modify that accordingly. I can't think of too many other obstacles that the 4bt didn't already create. The only difference is that I plan to run the engine straight up this time, and tilt the Chevy trans. I'll cross that bridge when I get there. Can't wait to get moving on this, but I have several other projects to get moving on first.
  29. #87
    Jan 2007
    New Haven, CT
    1,288
    8
    You may want to sell the chevy parts and go with Dodge stuff. I think you get a larger clutch and can pocket some money.
  30. #88
    Jan 2008
    Richboro, PA
    390
    6
    I haven't seen a Dodge NV4500 for sale locally for quite a while, for a price that I can afford....I do have a Dodge trans adapter that came out of the '97 donor truck with the 47RE. I would need to pick up a flywheel and clutch. Money is very tight right now, so I was planning to have the Centerforce clutch/pressure plate that is currently in there overhauled. It has worked quite well and I have done some really stupid stuff with that set up for the last 4 years. We'll see. The whole project might get sent down the road if I find the right M818 soon.
  31. #89
    Jan 2008
    Richboro, PA
    390
    6
    well, it looks like the swap is on. Time to pick up the engine out of storage and go over it with some new seals and shtuff. I'll probably look for some fresh injectors and maybe a better turbo setup. I really need a bigger garage!
  32. #90
    Jan 2008
    Richboro, PA
    390
    6
    Going to start this 4bt up one last time to troubleshoot the knock. Might be something simple, but probably not. Haven't had time to do anything with it for a few weeks, but I better get moving on it since I can't get it in my garage and the weather will be getting cold before long.
