dodge starter bolt size?
Results 1 to 10 of 10
Thread: dodge starter bolt size?
    Jan 2007
    MD
    1,203
    Default dodge starter bolt size?
    stupid question, i know...
    I had one fall out and I don't know the size and i won't see it until tomorrow night and I want to make sure i can replace it...
    TIA
    2001 CTD Durango - Sold
    2000 24V Ram QCLB 5speed - Current
    Jan 2007
    Sioux Falls, South Dakota
    1,068
    From the 1989 Dodge CTD Part Book -
    twelve point cap screw, M10-1.50 x 35mm
    Cummins p/n 3903834, $10.60 for all three...
    1989 D250 CTD, 727HD, D70/3.07, BHAF, DIY Cold air, Tuned VE, 4" exhaust
    Jan 2007
    MD
    1,203
    Quote Originally Posted by sdstriper View Post
    thanks, i wonder if it's the same for my 2nd gen adapter, hmmm, i should be able to find one in my pile of parts like that.
  5. Remove Advertisements
  6. #4
    Feb 2007
    142
    This is to funny. When I was putting mine together with the dodge adapter, I could not figure out the starter bolt size. Some of the bolts in the adapter where metric and some not. None I had felt right being threaded into the starter location.
    I thought- no problem, I will just go to the Dodge parts counter and get one for the truck I got the adapter from. I tell the parts guy I need some starter bolts for a 97 Dodge ram with a 5 speed and a cummins. He says it only uses one bolt to hold the starter on. I say BS, I have one and know it takes 3. He procedes to argue with me and insists it only takes one bolt. I say fine. I want 3 of them anyway. He tells me he only has one in stock. I am about to blow my top . How about just telling me the size of the bolt? He says he doesn't have that information. So I think- Just buy the bolt and drive all the way accross town to the hardware store and hopefully you can match it up. "I will take your one starter bolt" Thats $11. $11 for one bolt! I about hit him.
  7. #5
    Jan 2007
    1,068
    It is likely different. The second Gen adapter is different as well as the starter if I recall correctly, thicker adapter to accomodate a lockup Torque Converter.
  8. #6
    Jan 2007
    MD
    1,203
    yea, it would figure. I don't remember it being a 12point socket. i'll find out tomorrow night hopefully.
  9. #7
    Jul 2007
    TN
    1,107
    1
    mine have a 10MM head on them. not sure what bolt though.
    72 Scout d60/14blt, 4bta
  10. #8
    Jan 2007
    MD
    1,203
    Quote Originally Posted by K204DR View Post
    that sound familiiar, i remember them kinda being a pain to get to...
  11. #9
    Vendor CrewCab59's Avatar
    Jan 2007
    Knoxville,TN
    4,087
    The stock bolts 94-98 are 12 point ,most get rounded off and get replaced.
    Scott
  12. #10
    Jan 2007
    MD
    1,203
    not sure what happened entirely, but it looks like the top bolt backed out, eventually the other 2 worked themselves free enough for the starter to come out enough to not engage. When that happened it took out the bottom ear of the starter. Luckily enough for me, my buddy was able to TIG it up last night and i put it back in good as new-ish. The bolts in it were probably the wrong bolts they only had like 1/4" engagement. I have 3 12 point bolts that would work sitting here in my pile of parts from my swap...that's probably them, ugh. I was going to use them but i couldn't find my 12 point socket, ugh. I ended up with putting long enough bolts in...hopefully...locktite too.
