Hi Case mount AC
Results 1 to 9 of 9
Thread: Hi Case mount AC
    New Registered User
    Apr 2007
    6
    Default Hi Case mount AC
    I've found reference in the forum to using an AC mount from Case to locate the compressor high on the left side of the engine. I have the picture with all the parts, but there was no description with it or what Case application was referenced. Could anyone help me out.
    Jul 2007
    TN
    1,107
    1
    72 Scout d60/14blt, 4bta
    New Registered User
    Apr 2007
    6
    Thanks, I've seen this one. I would like to use it but it will interfer with my front motor mount. The one I'm refering to is for a high mount on the top left side of the engine run by a seperate belt. The picture said it was from a piece of Case construction equipment and that is what I'm trying to find out.
  5. Remove Advertisements
  6. #4
    Jun 2007
    Portland OR
    406
    3
    Can you scan the picture and post it up? Maybe that will help someone who knows chime in.
    85 Landcruiser FJ60, 4BTA, Compounds, 4L80E Optishift controller, 203 doubler to splitcase tcase, SOA, 37s, other stuff.
    Build Link:
    Family Haulin' FJ60
  7. #5
    Mar 2008
    fort lauderdale, fl
    28
    Quote Originally Posted by shizlotty View Post
    like this
    http://jeeptalk.net/jtup/1188685387/..._44_190189.jpg
  8. #6
    Registered User Jakey's Avatar
    Jun 2007
    Ephrata, Lancaster County, PA
    256
    Here's what came on my stepvan.
    It's an OshKosh Chassis.
    Possibly OshKosh Motorhome chassis also use the same mount on a 5.9L?
    The mount is rather simple in design.
    1994 F350 6BT ZF
  9. #7
    Jun 2007
    portland, or
    1,462
    If the mid-mount ford/freightliner style AC mount interferes with your front engine mount just cut the lower half of the ac bracket off. It works perfectly fine without the lower half. And instead of using the down pointing tube style lower waterneck intended for this style mount just use the normal front facing waterneck with extra long bolts.
  10. #8
    Registered User my96z's Avatar
    Jan 2007
    Northern Indiana
    390
    Here is the info for Case A/C
    Attached Files Attached Files
    1997 Jeep Wrangler 4bt Cummins
    http://www.youtube.com/watch?v=NwTF01PK1iE
  11. #9
    New Registered User
    Apr 2007
    6
    Thanks all, appreciate the help.
