Please mention 4BTswaps.com when calling // Site Info & Advertise with Us
Results 1 to 26 of 26
Thread: Hydroboost or Vacuum pump
    Feb 2008
    Berwick, Pa
    159
    Default Hydroboost or Vacuum pump
    I have both a hydroboost and a vacuum pump which one is better, I was sort of thinking the hydroboost because it will be more out of the way. Any thoughts would be appreciated.
  2. #2
    Jan 2007
    Burton, Ohio
    195
    I started with vacuum assist and was not happy with my braking while handling a 7,000 lb. load. I switched to hydroboost and to a smaller diameter master by 1/16" and it's made a world of difference. The smaller master requires a little more pedal travel but there was plenty of distance between the pedal and floor when depressed. Filtering is recommended on your brake /steering fluid line.
    1985 Dodge Ram Prospector, short bed, W150. 4BTA w/VE, Bosch 190, HY35W, 6BT air inlet and air filter, hydro-boost brakes, nv4500, NP208.
  3. #3
    Dec 2007
    norfolk va
    211
    I need to run a vacuum pump for my climate controls. if you dont have any other vacuum accesories, i would go hydroboost. if you would like to part with your vacuum pump, let me know.
  4. #4
    Jun 2007
    Ephrata, Lancaster County, PA
    250
    Quote Originally Posted by cgarr011 View Post
    Lots of vehicles have factory electric vacuum pumps that run the HVAC and or cruise control.
    With the knowledge of how to wire them up, you won't need the mechanically driven pump.
    1987 Cummins 4BT VE pump+H1C
    1990 Cummins 4BT VE pump+HX35
  5. #5
    Jan 2007
    MD
    1,216
    Quote Originally Posted by Driverswanted View Post
    how do you like your 190's with that much of a load? I have an HX35 and 12cm non-wastegated exhaust housing already.
    edit: sorry to hijack.
    as to the hydro/vacuum debate: I went with the vacuum pump because it simplified my install since my durango had vacuum boost brakes and vacuum actuated cruise control.
    2001 CTD Durango - Sold
    2000 24V Ram QCLB 5speed - Current
  6. #6
    Jan 2007
    Burton, Ohio
    195
    The 190's worked fine with the load. I rotated the stock injectors back in until I have time to clean up the 190's. I ran too retarded for a while and sooted them up. Not sure how different they are yet since I never used the stock injectors until now. I do, however get the same boost under heavy load.
    I forgot. I also have a Ferd diaphram vacuum pump for climate controls. It was a lot of work installing it in the beginning on the serpentine belt of my project but now it only feeds the climate controls. Yah. and electric with maybe a reservoir would be all one needs for the climate controls.
  7. #7
    Dec 2007
    norfolk va
    211
    I have breifly looked at the electric pumps and they were expensive but i am sure it was more vacuum then i needed for just climate controls if i switched over to hydroboost. I am with DD, i was hoping that the vacuum pump would simplify the install.
  8. #8
    Jan 2007
    Cancun, Mexico
    273
    I started my project with the Vacuum pump and booster. I am not happy with the way the vacuum system works any more. I don't pull anything but when I go off roading it feels like I don't have enough brake power when playing on the rocks. I have a Hydroboost system coming for my TJ Jeep and also a small 12v vacuum pump so I can still control my Climate Controls. I will post when all that is done..
    2005 Dodge Ram 2500 4x4 Cummins
    1997 Jeep Wrangler 4bt Cummins
    http://web.mac.com/my96z28ss
    http://www.youtube.com/watch?v=NwTF01PK1iE
  9. #9
    Oct 2007
    Lexington, VA
    1,607
    Vacuum pumps suck.. (pun intended)
    I really like the two hydroboost systems I have put together, but I have not needed vacuum for anything either. Even if I did need vacuum for something I would deal with that as a separate issue, and stick with the hydroboosted brakes, they are much better.
    Can you convert to manual heater controls?
    There are electric cruse control units out there, http://www.rostra.com
    Someone has to have a small cheap vacuum pump just big enough for the heater stuff if you have to go that way??
    Grigg
    1948 Chevrolet 6400 (2 ton) updated with:
    - Detroit Diesel: Silver 4-53T
    - Roadranger 10 speed overdrive: RTO-6610
    - 4 wheel disc brakes, hydroboosted
  10. #10
    Jan 2007
    N.IL.
    742
    Ford has used small electric vacuum pumps on all sorts of their cars and trucks. The PSD Super Duties have a small electric vacuum pump and reservoir. I am sure other makers have done the same too.
  11. #11
    Jan 2007
    Burton, Ohio
    195
  12. #12
    Jun 2007
    Portland OR
    279
    Quote Originally Posted by Ggg View Post
    Are you talking about this guy? It's for a PSD. It'll pull about 30 inches and was very easy to hook up, just a 12v + and a -.
    85 Landcruiser FJ60, 4BTA, 4L80E manual shift, 203 to splitcase doubler, SOA, 37s, and more.
    Family Haulin' FJ60
  13. #13
    Jan 2007
    MD
    1,216
    is there a part number?
  14. #14
    Jun 2007
    250
    The left pump in this pic is from a Volvo, it looks just like the pump used on 1999+ Powerstroke Fords.
    The pump on the right is from a foreign car, I got it from a Nissan, they can be found in lots of foreign cars and minivans.
  15. #15
    Jun 2007
    Portland OR
    279
    Quote Originally Posted by Diesel Durango View Post
    Looks like you can see the part # in this pic. I had a shop order it for me and got decent price ($95).
    6C3Z 2A451 A
    hey Yakk, I'm assuming those came from a salvage yard, could you share what they cost?
    Family Haulin' FJ60
  16. #16
    Dec 2007
    norfolk va
    211
    that ford pump sounds like the ticket, did it produce vacuum for the brakes in the ford or just accesories?
  17. #17
    Jan 2007
    N.IL.
    742
    Just the accesories, heat, etc. The SD trucks with the PSD engine have hydroboost brakes.
  18. #18
    Jan 2007
    N.IL.
    742
    Quote Originally Posted by boots4 View Post
    Yes that it it boots thanks for the picture.
    I ran the part number and it goes for around $107.
  19. #19
    Jan 2008
    Itasca, Texas
    30
    Default Electric vacuum pump
    I wonder if that little dumplin' would power up vacuum wipers? Probably not but it's cheaper than converting to electric wipers. I read on a hydroboost companies website that you could not use a hydroboost system with all drum brakes. Does anybody know if that is true and why if it is?
  20. #20
    Oct 2007
    Lexington, VA
    1,607
    Quote Originally Posted by studedude View Post
    Mostly true, but some exceptions.
    In a small vehicle with disc brakes and a hydroboost the brakes seem to be very touchy, and try to grab. I could be wrong, but it is because they are self energizing (unlike disc brakes) and take less pressure to operate, the hydrobooster is just a little to strong.
    I had a medium sized dump truck with factory drum brakes and a hydrobooster, that worked fine, and many trucks were built that way, and may still be.
    This explains it all,
    http://hydratechbraking.com/forums/v...ht=drum+brakes
    Grigg
  21. #21
    Jan 2007
    MD
    1,216
    thanks for the information and part numbers!
  22. #22
    Apr 2008
    Austin, Texas
    400
    Talking Hydroboost or vacuum boost
    My C3500 has a hydroboost set from the factory and I'll never install anything but that in a vehicle that I would be towing with. My truck will stop it's 6500lb weight and a 10,000lb trailer on a dime... I guess that could be helped by it's 6 tires, though...
    Jonny 1983 C-20, 2wd, 6bt, Getrag; 196?, C-?0 Crewcab, Cummins in (slow) Progress
    "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
    -AEC Hundley USNR
  23. #23
    Nov 2007
    S. California
    400
    Default hydroboost with drum brakes
    If the brakes are too sensitive on the front you can use wheel cyl`s with 1/8" or 3/16" smaller pistons. they will speed up the shoe to drum contact and lower the applied force to the shoes. the hydro boost will still have plenty of pressure to lock-up the brakes if needed. You may have to experiment with different w/c diameters to get a balanced system. You`ll always have plenty of reserve power with the hydroboost over a vaccum boosted system.
    71 vega w/ sd22 nissan diesel turbo, 5speed, 50 mpg. 70 chev suburban 4x4,60/14bolt,divorced 205,pto winch,3.73 detroit locker rear, power loc front, 35s, 2400 allison 5speed, tcm by Brayden Fleece, 8.2 Detroit fuel pincher turbo v8, 18 mpg. `94 suburban 1/2 ton 4x4, 3.42,`92 6bt, 47rh, Hx35/12cm, 4" exhaust,3200 spring.16/17mpg city, 22mpg freeway
  24. #24
    Jan 2008
    Itasca, Texas
    30
    Default Hydroboost for drum brakes
    Thanks, have a cold one on me. I figured there had to be a way to work it out as they used power assist brakes on some pretty heavy vehicles in the past. So, some way of decreasing the applied pressure to the brake shoes should do the trick. Grigg, this is on the 1.5 ton 53 Stude so it is not real light even though it has a flathead six in it! And I think that electric vacuum pump should operate the wipers quite nicely.
  25. #25
    Mar 2007
    466
    There are a lot of vac pumps available in the salvage yard. VWs of the 80s with cruise. A lot of the 80s GM cars. (Look under the front of the front fender). Newer P30s and motor homes have them. I am a salvage yard kind of guy. (Read that cheap)
    I recently ran into the vac problem with the climate control also. I am adding an aftermarket ac system. Most of them have vac control. I found one that is all electric (no vac). I will spend a little more time on the install and have all electric so I don't have to mess with the vac pump now or in the future.
  26. #26
    Jun 2007
    FC CO
    384
    I've read cautionary tales when powering up an older non-power drum brake system. It seems that the drums may not take too kindly to the extra force trying to push the shoes through the drum. Realize that drums distort out of round under braking, and that there is a limit somewhere in there. Just another point to consider when dealing with modifying brake systems.
    Ken
  • You may not post new threads
  • You may not post replies
