4BT radiator hoses
Results 1 to 7 of 7
Thread: 4BT radiator hoses
    Jun 2008
    Virginia
    13
    Default 4BT radiator hoses
    Does anyone know the radiator hose numbers for a 4BT going into a 1986 GMC 3500 truck? I have off the shelf hoses but can not read the numbers.
    Registered User turbos10's Avatar
    Jun 2007
    Texas
    915
    I made the top from a few misc. peices and some pipe. The bottom is the same....I doubt you will find an off the shelf hose.
    Mar 2007
    Long Island, NY
    242
    I just made the rad hoses for my Jeep yesterday, go to your local parts store and ask if you can go back and look at the hoses, measure connection sizes first, and approx measurements you will need.
    The top hose is Autozone number 61252 (I think it is also a Goodyear number too). Fit after trimming a couple inches off the rad end. Engine side is 1.75" ID, rad 1.5" ID.
    Lower hose is comprised of two hoses number 61323 is on the engine side (2.25" ID), reduced to 2"). The rad side hose is number 61252 (1.75" ID on each end).
    The local plumbing shop hooked up up with a street elbow and reducer which I soldered together, BTW, copper is not cheap $21 for the two pieces.
    ME AND MY DIESEL YJ ON COVER OF JP MAG MAY 2008!!!!!!!!!!!!!!!!!!1
  5. #4
    Jul 2007
    New Hampshire
    748
    10
    Did you swage the ends of those fittings to provide a lip? If you didn't, the hoses will pop off the copper.
    I did that a long time ago to get around an alternator and the hose popped off after 10 miles. And yes it was tight.
  6. #5
    Vendor CrewCab59's Avatar
    Jan 2007
    Knoxville,TN
    4,087
    If you use a upper stat neck from a 5.9 you can use a stock 5.9 hose and fit's the Gm neck.
    Scott
  7. #6
    Mar 2007
    Long Island, NY
    242
    Quote Originally Posted by Goat View Post
    Nope.
    Upper right pic, it held for 3 years.
  8. #7
    Jan 2007
    Arkansas
    96
    Wolf,
    If your setup is the same as mine, 1977 C/10 then the hoses should be:
    Gates Hoses #'s Upper Hose #21729 and Lower # 21731
    Hope this helps.
    Chuck
