Bread Van Alt and AC brackets?
Results 1 to 16 of 16
Thread: Bread Van Alt and AC brackets?
    Dec 2007
    Middle GA
    11
    Default Bread Van Alt and AC brackets?
    I read somewhere about the alternator and AC brackets from the bread van with the 4bt that was originally chevy stuff being ideal for a 6bt swap into a chevy. Anyone have any experience with these? The thread that was linked was not working so I could not go and read more about it, I just saw it somewhere and thought that I could save a lot of trouble by picking up these brackets instead of having some made.
    Also, if I did this, I would probably have to swap over to the cummins 8 rib pulleys. Are the bread van pulleys the proper 8 rib ones? Do they have the correct diameter on the alternator to make my stock tach correct?
    Jul 2007
    TN
    1,107
    1
    I haven't seen a breadvan with a/c on it, i'm sure they're out there though.
    72 Scout d60/14blt, 4bta
    Dec 2007
    Middle GA
    11
    Thats a good point, there probably aren't a whole lot of them with AC...let alone ones that have been parted enough for me to get the AC bracket from.
    Where does the alternator bracket put the alternator on these things? It looks like the are on the right side right in the middle and would interfere with the location of my AC compressor.
  5. Remove Advertisements
  6. #4
    Registered User 66gaza's Avatar
    Jan 2007
    England
    696
    I have chevy alternators on my 6BT, can't remember which ones but it is a standard cummins mount. Look at my build thread for pics.
    Gaza
    Let your words be soft & sweet...lest you have to eat them later.
    6BT into a Rover thread http://www.4btswaps.com/forum/showthread.php?t=19
  7. #5
    Dec 2007
    norfolk va
    244
    the only factory a/c brakets that i have heard of are the ones that cummins made for kenworth on the 6bt. it puts the a/c compressor upper passenger side of the motor. I have found them a little hard to find so far but i have not been looking to hard. Initial research says that you have to buy them from kenworth. here is what i got
    used on the 93-97 k-300 medium duty trucks
    part #3930888
    requires a straight water neck, 3941929
    59 chevy apache - 4bt, getrag np205, 14 bolt/dana 60, 39" michelin XLs, monster
    84 chevy c30 crewcab - 454 in it, 6bt / md 3060 soon
  8. #6
    New Registered User
    Nov 2008
    Louisville, KY
    5
    Default AC on a 96 Chev Pickup
    I got a 6bt ac bracket to put on my 4bta, but there was interference with the passenger side engine mount. If anyone wants it I'll let it go cheap!! The Cummins mount bolts to the three bolt holes on the top front of the head and would put the R4 compressor through the hood. I ended up using two pieces of 2"X3" steel angle iron 3/16" thick to fashion an L-shaped mount. It bolts into the two threaded holes (one 8mm and one 10mm)in the front of the head, and the vertical part of the L goes down just to the outside of the identification plate.
    Welded a piece of 1/2" OD tubing (1/8" wall) and hung a Seltec compressor off it with a 3/8" bolt. Used the Cummins v belt pulley and a 45" v belt.
    It goes in the shop Tuesday for custom hoses and then I'll be cool - literally.
    4BTA in 1996 Chevy C3500 2WD SRW Crew Cab/4L80E/corporate 14 bolt FF with 4.10 gears (soon to be 3.21)
  9. #7
    Jan 2007
    Arkansas
    97
    KYRODDER,
    Do you have any pictures of your mount?
    Chuck
    1977 Chevy C-10 4BT ZF-545 Trans 3.08 Gears 32" tires.
    Pump screws have been turned some, Turbo HX30W
    3" exh through twin 5" Stacks
  10. #8
    New Registered User
    Nov 2008
    Louisville, KY
    5
    Will try to get a pic next week.
  11. #9
    Registered User my96z's Avatar
    Jan 2007
    Northern Indiana
    390
    Here are some .pdf files that have a couple of options for the A/C Compressor mount. The alternator mounts just above it. It uses a 22si Delco for an alternator..
    http://files.me.com/my96z28ss/mjqqdc
    http://files.me.com/my96z28ss/043mkb
    http://files.me.com/my96z28ss/54054c
    1997 Jeep Wrangler 4bt Cummins
    http://www.youtube.com/watch?v=NwTF01PK1iE
  12. #10
    Sep 2007
    Greenville, SC
    70
    Quote Originally Posted by my96z View Post
    These are some great links, I need to know what compressor was used with these mounts. I know the dodge will work but only if you have the hanging oil filter. I still have the horiz. filter mount. almost all of the bases used that I know of use the SD7h15 but I need to know what the model number is.
  13. #11
    Jan 2007
    Northern Indiana
    390
    The dodge compressor won't work on the freightliner/KW bracket. The position it mounts will cause a belt misalignment. I have tried. If you go to napa and look for the compressor from a 95 F-800 w/cummins 6bt that compressor will bolt up very nicely..
  14. #12
    Sep 2007
    Greenville, SC
    70
    The guage line is different between the ford and dodge compressor. The pump is the same but the clutch is farther away from the front of the compressor than the dodge.
  15. #13
    Jan 2007
    near baton rouge, la
    805
    what is the cummins part number for the bracket?
    1942 wc-53
    4bt/4l80e/compushift/np241
    dana 60/14bolt 4.88 38.6"tires
    http://www.4btswaps.com/forum/showth...highlight=Wc53
  16. #14
    Vendor CrewCab59's Avatar
    Jan 2007
    Knoxville,TN
    4,087
    Quote Originally Posted by mcinfantry View Post
    3957364 is just the bracket
    Scott
  17. #15
    Nov 2009
    flatland
    2,103
    4
    I too am after an easy bolt on bracket for chevy a/c
  18. #16
    Jun 2009
    FL
    31
    Here is my alternator mounted on Dodge brackets, its CS-144, one of the best Delco alts
