bellhousing bolt pattern on dodge 5.9 adaptor?
Results 1 to 8 of 8
Thread: bellhousing bolt pattern on dodge 5.9 adaptor?
    Aug 2008
    michigan
    190
    Default bellhousing bolt pattern on dodge 5.9 adaptor?
    like every one i looking for the most inexpensive way to get a tranny behind my 4b.
    what is the bellhousing bolt pattern used on the dodge cummins adapter
    shared with is it the same as a 383/440? or 318/360 ect.
    or is it uniuqe to the diesel?
    Jan 2007
    Paisley, Pa USA
    4,043
    12
    Diesel only.
    BobS
    Aug 2008
    michigan
    190
    thanks,
    looks like I will have to fab something for the SAE adaptor i have or bite the bullit and search for a gm or ford manual adaptor and flywheel..
    with either of those i can get it mounted to the tranny i want to use or one's i have on hand.
  5. Remove Advertisements
  6. #4
    Jan 2007
    Paisley, Pa USA
    4,043
    12
    The Dodge or Ford setups are generally the cheapest. The SAE's are not cheap either. Shop around before you jump in and buy. Check out the classifieds section on here.
    BobS
  7. #5
    Supporting Member
    May 2008
    New Haven, CT
    459
    Quote Originally Posted by BobS View Post
    Diesel only.
    Also same as 8.0L V-10 Gas
    1967 Land Rover Series IIA 109 Hybrid, it is STILL just a pile of parts, someday I may finish......
    Custom Chassis, Air Suspension, Rear Double Triangulated 4-Link, Front 3-Link
    Drivetrain: Taurus Fan -> 4BTA3.9 CPL 0986 Twins? (DeVito/Schwarzenegger style) -> NV4500HD -> Dana 300 -> Dana 44 Front and Rear
    Build-up thread on Pirate4x4 (before I found here)
  8. #6
    Aug 2008
    michigan
    190
    thanks agian,
    so it is also the same as the truck/viper v-10 interesting.
  9. #7
    Supporting Member
    May 2008
    New Haven, CT
    459
    Quote Originally Posted by Kskfordfleet View Post
    thanks agian,
    Same as the truck V-10, I have not seen the bell housing on a Viper - but if you know it is the same bolt pattern, then yes.
    I got my NV4500HD out of a 1998 2500 V-10 4x4 and it bolted right up to the 1998 Adapter & Flywheel.
    But what BobS says is correct, and do shop around.
  10. #8
    Jan 2007
    Paisley, Pa USA
    4,043
    12
    Quote Originally Posted by cumminsrover View Post
    For some reason I always seem to forget about the V10 engine. Probably has something to do with only seeing diesels and V8's.
    BobS
