Grid Heater
Results 1 to 6 of 6
Thread: Grid Heater
    Registered User slsanders0007's Avatar
    Apr 2008
    Columbus, Indiana
    151
    Question Grid Heater
    Did anyone's 4bt come with a stock grid heater? I took the VP from Cummins off-road engineering for a ride the other week and he was looking at my engine. He said that the spacer on my intake is where a grid heater usually goes and he was surprised mine didn't have one. I do have the stock block heater.
    Anyone running a grid at all? Wondering if it's something I should invest in. Its getting colder and my Jeep doesn't fit in the garage. Will the block heater be enough?
    "yeah, it's cool now, but what if..."
    HellDesk Survivor Machman's Avatar
    Jun 2007
    Knoxville, TN
    1,434
    27
    Default Use the Search, Luke!
    I don't know about it coming on the 4BT, but here's info on those that have used one:
    http://www.4btswaps.com/forum/showthread.php?t=2469
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly.
    Specialization is for insects.
    - Lazarus Long, as written by Robert A. Heinlein.
    Quote Originally Posted by BobS View Post
    You need to first confirm the problem BEFORE you start buying and replacing parts.
    Vendor CrewCab59's Avatar
    Jan 2007
    Knoxville,TN
    4,087
    All 4bt air to air all came with the spacer , they use the block heater for a starting aid .The 5.9 heater will bolt right on but will have to be a 1st gen or from 98-2002 , because the 94-97 were 1 piece heater and intake plate.
    The 4bta water aftercooled could have a have a heater installed under the cooler or the newer 2 piece remove the spacer and install the heater .
    Scott
  5. Remove Advertisements
  6. #4
    Apr 2008
    Columbus, Indiana
    151
    Thanks... I'll see if I can't find one, and pick up a 15 second relay and go from there. Now that its cold out, it's not firing as quickly as it was when it was warmer. I haven't plugged in my block heater yet, but I did pick up a high-amp timer so that I don't have to run it all night long.. I'm thinking I'll have it turn on around 4 am for a start at 7am... that in combination with the grid heater should put me in good shape..
  7. #5
    Jan 2007
    Knoxville,TN
    4,087
    Quote Originally Posted by slsanders0007 View Post
    You won't need both ,when I was up there I just use the grid heater .
    Scott
  8. #6
    Oct 2007
    Douglas, Wyoming
    279
    Yea, but it surely won't hurt it to plug it in! It's a personal preference: I know guys that don't plug their 6BT's in unless it's -10. That, to me, is ignorant. A little on the power bill is worth a bunch...
    92 F150 4x4, 4BT, Mazda 5spd., 2 1/2" into 3" straight pipe exhaust
    96 F250 4x4, Powerstroke, 5 spd., 4" straight pipe dual exhaust
    "When all else fails, go to South America"
