John Deere 5030; 5cyl 3.0L
Results 1 to 2 of 2
Thread: John Deere 5030; 5cyl 3.0L
    Jan 2009
    Wisconsin
    14
    Default John Deere 5030; 5cyl 3.0L
    I came across this engine at the local John Deere dealer as I was interning there. I did some asking and got the engine for next to nothing. The reason I got it was the turbo had siezed. It was running on the oil that leaked past the seals so to shut it off the tech had to krimp the pressure line to the turbo. I will be taking the engine to tech school, taking it all apart,cleaning it and reassembling. It came out of a track skid steer, rated at 82hp @2800 rpm and 210-215lb-ft at 1500rpm. These engines use Stanadyne's IFS(Integrated Fuel System) which is pretty unique. I will post some pictures of it as I work on it but my biggest question right now is what turbo to use. I would like more power so would a turbo from a 3.9L Cummins or Deere work? I have a tech. man. for this engine and I think I can adjust the governor for more fuel. I am planning do an S-10 swap. Mostly city and highway @ 55-60 mph. Or will this engine not work for this app.? Any thoughts would be welcome.
    Jan 2009
    Wisconsin
    14
    I found a section on Garrett's site called turbo tech. They explain turbos and give formulas to calculate points on compressor maps. I used Excel to do the calculations and in the GT series I only found 1-3 turbos that might work but I'm not sure if the exhaust side is too small. That is why I am wondering if a 4bt turbo will work with a smaller turbine housing because it would be a lot cheaper.
    Turbo Tech
    http://www.turbobygarrett.com/turbob...ch_center.html
    Catalog for GT series
    http://www.turbobygarrett.com/turbob...s/catalog.html
