GM Block 6.5 6.2 and Gas to SAE 3 bellhousing
Results 1 to 15 of 15
Thread: GM Block 6.5 6.2 and Gas to SAE 3 bellhousing
    Registered User KingNothing50's Avatar
    Mar 2009
    Westover, PA
    144
    Default GM Block 6.5 6.2 and Gas to SAE 3 bellhousing
    I have this adapter here and thought I would share some pictures of it. Was on a chevy engine (pattern: small block, big block, 6.2, 6.5) and gives you SAE #3 on your engine. Had allison auto behind it.
    Also I am looking for a bell housing to go from SAE 3 (on Detroit) to NV4500 Trans.
    Also does anyone know how much longer the dodge NV input shaft is compared to the GM?
    Mar 2009
    Westover, PA
    144
    heres another I have more photos if anyone is interested in seeing them
    Feb 2007
    Front Range Colorado
    618
    I've seen the same adapter factory fitted between a 366 tall deck, and an Allison 545.
    Thought about using it with my 4BT, but decided that it was just one adapter too many. Seemed pointless to use the GM adapter, and then adapt that to SAE, so I ditched the GM adapter and went straight to an SAE3.
  5. #4
    New Registered User
    May 2009
    minnesota
    1
    say iwas wondering where you found that gm adapter or are you are willing to part with it?
  6. #5
    New Registered User
    Nov 2009
    bozeman montana
    2
    Default chevy v8 to sae #2 adaptor bellhousing
    hi, i am looking for an adaptor bell housing that will fit the back of a chevy small block engine and adapt it to a sae #2 bellhousing. please advise and respond if you have seen one or know someone who would have one. thanks
  7. #6
    New Registered User
    Sep 2010
    michigan
    2
    turn this one around and get a chev pattern 4500 and crank hub spacer
  8. #7
    New Registered User
    May 2011
    Dayton, Ohio
    7
    Quote Originally Posted by skooterzkustoms View Post
    Not sure if this is the answer to the same question I'm asking but just to verify....I'm trying to pair a 6.2 GM diesel to a (what I was told )clark 5 speed transmission that mounts to a #2 SAE bellhousing. Can I get some direction on how to make it work? Thanks
  9. #8
    Apr 2010
    West Michigan
    1,616
    3
    Quote Originally Posted by DFD2010-A View Post
    There are adapters for putting an Allison behind a 366 Big Block Chevy....... but I'm not sure which SAE pattern they are. They would have been used in lots of school buses.
    Edit: Oops, I guess what I said was already discussed. Nevermind.
  10. #9
    Jul 2009
    longmont, CO
    989
    1
    Might want to verify what Clark? you have, before going any farther(OD, direct?) A stock GM bellhousing will go from 6.2 to Clark? w/o any special adapter, unless perhaps the bearing retainer OD is slightly different-lathe work. If you have a Clark? w/ SAE, factory, sounds odd?
  11. #10
    New Registered User
    Jan 2012
    ohio
    3
    I'm wanting to put my Allison at540 on my chevy small block; what adapter is needed, any part #'s pictures , or details are appreciated. Thank you
  12. #11
    Jul 2009
    longmont, CO
    989
    1
    Kingnothing,
    Dodge 4500 input is about 1" longer than Chevy, someone(Advance?) makes an adapter to go there.
  13. #12
    Jan 2009
    NE Ohio
    1,339
    1
    ICAN2----You need exactly what Ed Pruss showed in his 1st post . Allison aplication manuals from the 70s had the part #s needed for adapter,crank hub adapter,flex plates etc. but surely you can find somebody that junks medium duty trucks or school buses and get the stuff cheap .
    In fact ,since you're in Ohio,call Paul's Equipment @330-472-8204 ,address is 8111 Waterloo Rd ,A****er,Ohio,44201 .
    A****er is between Ravenna and Alliance ,west of Canfield,east of Akron. Clear as mud !
    Note : Site police will not let me print At water,but on the map,it's a small town .
  14. #13
    Jan 2007
    Paisley, Pa USA
    3,997
    11
    Quote Originally Posted by junkmandan View Post
    Strange on the name not working. Let me help. The website is: http://www.usedschoolbusses.com/
    Wendall Paul Owner
    8111 Waterloo Road
    A t w a t e r, Ohio 44201 Phone: (330)947-1147
    OK, I see the reason now.....
    BobS
  15. #14
    New Registered User
    Mar 2012
    venezuela
    1
    hola. I need an adapter gm allison trasnmission engine like the foto. please if I can provide a phone number or better yet an email and I am from another country. Venezuela. may be new or used too. thanks
  16. #15
    May 2010
    NE Texas
    110
    Not sure what housings they ran with the allison's, but they did put the RT610-RTO6613 roadrangers behind the 427 chevy's and as far as I know the little roadrangers only came with a SAE#2 housing, so they are out there.
    1993 2wd chevy crewcab dually, P-pumped 6BT, RTO-6610 Roadranger, rear 4-link air ride, 22.5" alcoa's machined down to 22"
