3 cylinder cummins
Page 1 of 2 12 LastLast
Results 1 to 30 of 39
Thread: 3 cylinder cummins
    Mar 2009
    Alabama
    191
    Default 3 cylinder cummins
    Hey guys,
    Just wondering if anyone has ever seen a 3bt. My father in law has one. We don't know much about it, so I wondered if you all had ever heard of one. What were they used in? How much power do they produce? Any other info is great. I'll try to get some pictures up.
    Jul 2008
    Okotoks Alberta
    182
    never heard of a 3B, interested to see it.
    Feb 2009
    Central California
    344
    Toyota built a 3B diesel but it is a 4 cylinder.
  5. Remove Advertisements
  6. #4
    Supporting Member
    Mar 2009
    Southeast
    1,761
    161
    Default 3bt
    The ones that I've heard about are 180 cid,2.9l case tractor engines.Hope this helps.
  7. #5
    Jul 2007
    TN
    1,107
    1
    tractor motor, but i've not actually seen one. I'd like to have one just cause its unusual.
    72 Scout d60/14blt, 4bta
  8. #6
    Jul 2009
    Colorado
    729
    1
    Case tractor is what I have seen one in. I to would like to have one, I think it could possibly use the same adapter as the 4bt's. Would be nice to put in my 70 CJ5,it already has a chevy sm420 4speed and over drive unit. Then all my vehicles would be oil burners!!!
    1963 Chevy extended cab K20 4x4 p/s p/b 4BT HX30w 1.8mm timing Ranger over drive sm420 4.10 gears PTO winch exaust brake
    1983 Ford Bronco 4BT H1C 16cm 1.5mm ZF5speed 3.55 gears first Gen intercooler fuel screw turned 3/8
    1942 WC26 Dodge Carryall 4BT NV4500 NP205 Dana 60&70 hydroboost brakes (project with Daughter)
  9. #7
    Aug 2009
    5,463
    i've never heard about it... whats the power and torque?
  10. #8
    Apr 2009
    Vancouver, WA
    65
    2012 Subaru Forester 2.5x Premium
    1999 Jeep TJ 4.0L, Manual, 1" lift, 33" tires (DOA due to a stupid driver)
    1991 Chevy Suburban V2500, 1991 Cummins 4bt CPL 858, Dodge HD NV4500, NP241c, Dana 60 Front, Detroit locked 14 Bolt FF Rear, 4.10 gears, 4" lift, 35" tires. 19-20mpg city, 23mpg hwy (Sold)
  11. #9
    Mar 2009
    Alabama
    191
    Hey guys,
    Finally got some pictures for you. It's rear gear train and rotary pumped. Case New Holland markings. 79 hp at 2300 rpm. 206 cubic inches is bigger per cylinder than the 3.9/5.9, and seems to be half of a 6.7L.
    Enjoy
  12. #10
    Isuzu reliability tester
    Jan 2008
    Burleson,Tx
    3,001
    Well isnt that a cute little thing. Thats similar to what I was planning originally with my ford truck, something like this with an electric motor at each wheel or one motor at each rear wheel to make my own hybrid vehicle.
  13. #11
    Isuzu Diesel Innkeeper
    Jan 2007
    New Zealand
    8,247
    629
    Just crunching some numbers off that EPA tag.
    Gives it a BSFC of 235g/kwh at rated power which is 34% efficiency (1 point higher than a 4BT).
    90% VE if it was running an A/F ratio of 18:1 at max power.
    243Nm torque
    Would use 16.1 litres/hour at full power.
    Isuzu 4BD1T Junkie.
  14. #12
    Aug 2009
    5,463
    this wouldn't be bad in a s10, or even in a c1500...
  15. #13
    Supporting Member
    Jun 2010
    Newton NC
    7,114
    10
    Several years ago Diesel Power Magazine did an article on the B series cummins and they mentioned the 3 cylinder. The 3, 4. and 6 all share common parts such as rods, pistons, valves, etc. This is literally half of a 5.9. It is the first one I have even seen though. Notice on the info tag the letters UK for United Kingdom. Those guys have all kinds of neat diesel stuff over there that we don't. Would make a neat install in a Ford Ranger. Would be fun trying to figure out a turbo for this puppy.
  16. #14
    Aug 2009
    5,463
    Quote Originally Posted by char1355 View Post
    this would really be a good option as there is not too much light diesels offering in the u.s., if cummins homologated it to automotive applications...
  17. #15
    Jun 2010
    Wi/Paris France
    58
    J'ai voient peu 3 cylindre verison de temps en temps sur Cummins B la série et les unités sur lesquelles je travaille ils sont utilisés pour l'unité de générateur.
    Si je me rappelle qu'il le corrige a été noté à 60 CV à 1800 TRS/MIN donc si vous fonctionnez au moins 2300 à 2500 vous devriez obtenir environ 70 à 75 CV à moins que vous n'ajoutiez un turbocompresseur alors il augmentera en haut un peu.
    I have see few 3 cylinder verison from time to time on Cummins B series and the units I work on they are used for generator unit.
    If I recall it correct it was rated at 60 HP at 1800 RPM so if you are running at least 2300 to 2500 you should get about 70 to 75 HP unless you add a turbocharger then it will boost up a bit.
    Merci.
    Marc
  18. #16
    Aug 2009
    5,463
    Quote Originally Posted by french277 View Post
    something around 120hp at 2000rpm seems to be doable and a good goal to a ranger or s10...
  19. #17
    Dec 2007
    Everett,Wa
    182
    1
    any closure on this? What did it turn out to be?
    From the marking its a unique engine family, and it was put into case new holland products and takes a standard non inter cooled turbo pedestal like the first gen cummins 6bt
    im not so sure this even is a cummins engine.....
  20. #18
    Mar 2009
    Alabama
    191
    Quote Originally Posted by res0wc18 View Post
    In my opinion, it is a rear gear train, mechanical injected, 3 cylinder version of the 6.7L B cummins.
  21. #19
    Supporting Member
    Nov 2007
    S. California
    654
    8
    From lookin` at the pictures, I`d say it is turbo `ed. check out the intake configuration. it`s just like a non intercooled 6 bt. and look at the exhaust manifold. the outlet is facing up to mount a turbo right in line with the intake. I think the turbo is missing in these pictures. and there`s an open oil line fitting on top of the oil filter housing. also the engine is epa and carb (california) certified for `04 reg`s
    71 vega w/ sd22 nissan diesel turbo, 5speed, 50 mpg. 70 chev suburban 4x4,60/14bolt ff,divorced 205,pto lu-4 winch,3.73 detroit locker rear, power loc front, 35s on 16.5"x12" weld wheels, 2400 allison 5speed,triple disc billet torque converter, tcm by Brayden Fleece, 8.2 Detroit fuel pincher turbo v8, 18 mpg. `94 suburban 1/2 ton 4x4, 3.42,`92 6bt, 47rh, Hx35/12cm, 4" exhaust,3200 spring.16/17mpg city, 22mpg freeway
  22. #20
    Oct 2009
    Poulsbo, WA
    287
    1
    That thing would have to be turboed to reach the advertised power ratings. I think the bigger giveaway is the boost boot on the intake, and the boost compensator valve on top of the IP.
  23. #21
    Aug 2009
    5,463
    this engine makes me think about a cj5 jeep.........
  24. #22
    Jan 2007
    New Zealand
    8,247
    629
    Quote Originally Posted by 4x4_Welder View Post
    Not to mention the turbo flange on the manifold.
    Isuzu 4BD1T Junkie.
  25. #23
    May 2007
    los angeles
    140
    I REALLY NEED one of these..... Who,s got them???
    Sergio..
  26. #24
    Aug 2009
    5,463
    Quote Originally Posted by 4bt Terra View Post
    you could search a new holland dealer, or maybe a case dealer
  27. #25
    New Registered User
    Jul 2010
    onalaska tx
    2
    lol thats not turbo flange tho them just had little pipe and muffler on it there good motors tho
  28. #26
    Apr 2008
    Cent Ca
    336
    1
    AFC housing pretty much garantees a turbo to me.....
  29. #27
    Supporting Member
    Jun 2010
    Newton NC
    7,114
    10
    Did some research on New Holland's web. I only found 1 application using a 3 cyl of this size. It is in the L185 skid steer loader. The engine is listed as 3.4L, 78hp @ 2300rpm and 228 lb ft of torque at 1400 rpm. Lost 1 hp but man has that sucker got torque. Manuufacturer is listed as New Holland for the engine. The engine model number is 334T/M2, the T is for turbo. They have the same engine non turbo with somewhat less power. This doesn't necessarily mean that cummins isn't making this engine for New Holland. They also have a 4.5L 4cyl which is exactly the size of the current cummins industrial 4. Must also remember that Case IH New Holland are part of the Fiat group with all kinds of engine manufacturing facilities.
  30. #28
    Aug 2009
    5,463
    seems that it's not too much boosted... but would be cool to use this engine in a late-type s10 or a chevy colorado...
  31. #29
    Jan 2007
    New Zealand
    8,247
    629
    Quote Originally Posted by cRiPpLe_rOoStEr View Post
    Comparing the torque levels seems like it runs on less than 10psi boost.
    Isuzu 4BD1T Junkie.
  32. #30
    Dec 2007
    Everett,Wa
    182
    1
    the problem would be mounting an automotive tranny to it for a reasonable cost. What is the bellhousing config? It looks to be a sweet possibility if you can solve that. And it's not a cummins. It's a case new holland engine. I've got a 71 cj5 that would be killer in. 4bt's are nice but call for more money than my entire rig is worth to me.
