Please mention 4BTswaps.com when calling // Site Info & Advertise with Us
Go Back   Cummins 4BT & Diesel Conversions Forums > General Discussion Sections > WVO / SVO / Biodiesel
WVO / SVO / Biodiesel Place for discussion for use of alternative fuels (vegetable oil -- & biodiesel )
Reply
Thread Tools Display Modes
  #1
Old 07-04-2007, 02:48 PM
VillaUS VillaUS is offline
Default Straight Vegetable Oil
Anyone here run straight vegetable oil in their 4BT? How does it like it?
  #2
Old 07-04-2007, 03:28 PM
addicted56 addicted56 is offline
Send a message via AIM to addicted56
I don't see why not. I know someone who did a 1 tank system on his 12V and has about 20K miles logged.
__________________
97 F-250 4" Magna flow exhaust, VDO guages, Tymar Intake, 218K miles, Vormax filter, Vegtherm, 51 Gal
89 Land Cruiser FJ62 to be sold
06 Jetta TDI....55K...Racing TDI emblem
56 F-100...4.6L
  #3
Old 07-04-2007, 04:02 PM
66gaza 66gaza is offline
Quote:
There is a thread about this do a search. I would imagine a 4BT would run on a 1 tank SVO system but for how long?. I personally have too much respect and too much money in mine to put it at that sort of risk. I imagine the inline pumps more robust for this but the VE pumps are still very capable. I would run a 2 tank system that heated it and switched when warm them back to diesel to flush before switching off. The 6bt run fine on wvo, how well and for how long would depend on which system you go with. Heat & filtering are the key. I think you know this and I cannot answer your question from personal experience on a cummins. I have dabbled with bio but only ran 50/50 and blended svo with pump diesel 20/80. Someone with 1st hand experience will probably jump in. Cold wvo is hard on I/P's and cokes up injectors causing bad spray pattern damaging cylinder walls and unburnt WVO ends up diluting the lube oil. If you are gonna run wvo my advice would be to filter b4 putting in tank and then heat & filter again (finer the better) have 2 totally independent pump/filter/tank systems. I would also keep a closer eye on the lube aswell.here is a link to a svo thread http://www.4btswaps.com/forum/showth...ight=biodiesel
Gaza
__________________
Let your words be soft & sweet...lest you have to eat them later.
6BT into a Rover thread http://www.4btswaps.com/forum/showthread.php?t=19
  #4
Old 07-04-2007, 05:20 PM
Ohh I agree. I just finished my WVO conversion on My 300TD today. 2 Tank all the way. I've run my PSD on it for 3 years now. Also a 2 tank system. I'm not a big proponent of the 1 tank system either.
__________________
56 F-100...4.6L
  #5
Old 07-08-2007, 11:30 AM
Thanks for the link Gaza. I'll check it out. I'm hoping someone actually has first-hand experience.
There is a lot of info out there on 1 tank v. 2 tank systems. Elsbett (a German company) makes conversion kits and part of their kit is modified injectors which alter the spray pattern.
  #6
Old 07-08-2007, 03:40 PM
Go two tank and go cheap esp on these IDI's. I spent 1700 on my PSD with all that name brand crap and 250 on my WVO system and I feel safer and better about my homebrew than I do the expensive stuff. Save yourself 1500 and buy some new shoes
__________________
56 F-100...4.6L
  #7
Old 07-08-2007, 05:17 PM
CrewCab59's Avatar
CrewCab59 CrewCab59 is offline
Official 4BTSwaps.com Vendor
They run just fine,I have used new VO even when it cold out,just add a little diesel to thin it out .
CrewCab59
  #8
Old 07-09-2007, 09:59 AM
dieselcruiserhead's Avatar
dieselcruiserhead dieselcruiserhead is online now
'69 FJ55 Land Cruiser
I have been hearing from a shop that's done a few 4BT swaps that some grease comes out of the exhaust holes. Meaning that maybe its not combusting completely? Oil is properly heated, and it is on the 4BTs only. they are used Frito models, so a little confused personally. I don't see how the 6 cyl and 4 cyl could really have much difference.
__________________
Diesel Converion Web Site
Biodiesel Powered 1969 FJ55 Current Project in Buildup Stage
Old 1971 FJ55, Sold
M416 Military Trailer, Independent Suspension, Kitchen, Roof Top Tent
1999.5 Powerstroke, considering the future of...
89 & 91 Toyota Pickups
'81 & '83 Mercedes Benz 300Ds
4BTswaps.com Administrator
  #9
Old 07-12-2007, 02:45 AM
uglyoldbob uglyoldbob is offline
Quote:
It's so people can find the Frito Lay plant.
  #10
Old 07-12-2007, 11:10 PM
mljjones67 mljjones67 is offline
Send a message via MSN to mljjones67
  #11
Old 07-18-2007, 06:21 AM
Diesel Durango Diesel Durango is offline
Junky
in stead of bio diesel or SVO, what about a WVO/#2 mix
What kind of modifications would be needed to make this work? could i run a 1 tank system? Fitting a 2 tank system would be difficult unless i move the spare tire somewhere. I don't have a trunk or bed and you can't legally have a fuel tank in the passenger compartment.
  #12
Old 07-18-2007, 03:11 PM
Well in the summer you would have no problems. In the winter watch out though. Not necessarily from gelling of the fuel but of the Wax preciptating out and clogging filters and lining in your tank. Been there done that. Not fun. Went to a two tank a month later. But it worked fine all summer. This is in my Benz. Had a two tank in the PSD since the get go.
__________________
56 F-100...4.6L
  #13
Old 08-20-2007, 09:12 PM
Boarlard Boarlard is offline
My buddy has a 4bt in an old suburban and has approx 100,000 miles on WVO cut with approx 10% gasoline. He has a one tank system and a fuel line heater. He says that he can run this mixture to about the same outside air temperature as #2 diesel. He also runs it in his 6bt powered DODGE 3500 but doesn't have as many miles on WVO with that. I run a 50/50 mixture of WVO and diesel in my rabbit but I only have about 5000 miles doing that. Oh yes he filters down to 5 microns before it goes in his truck and he always carries extra fuel filters with him. He put an inline fuel pump so he can easily blead out the air when he changes filters.
  #14
Old 08-24-2007, 09:44 PM
villelobos villelobos is offline
Default filters
What filters do you run with veggie? Where do you buy them? Thanks Jack
  #15
Old 08-25-2007, 04:40 PM
Machman's Avatar
Machman Machman is offline
Helldesk Survivor
Most, if not all, the WVO conversions / adaptations I've seen involve adding filters to the system (usually a big ol' heated filter) as a pre-filter for the existing fuel filter. Also, there are filters that are used as part of the collecting / cleaning process before you pump it into your tank.
Here's Frybrid's filter page: http://www.frybrid.com/filters.htm
Here's Greasecar's page for collection filtering products: http://www.frybrid.com/filters.htm
And, Golden Fuel's filter page:
http://www.goldenfuelsystems.com/pro...el_filters.php
It's really a question of what filters you want to run, how much $$ you want to drop into it, or whose system you want to get..
  #16
Old 09-06-2007, 10:34 PM
veggiecummins veggiecummins is offline
I've owned Racor (Golden) and Frybrid filters and found this one to be the best all around cooking oil filter:
http://www.vegpower.com/order/catpag...at_selected=55
VC
  #17
Old 09-20-2007, 03:42 PM
studlybilly studlybilly is offline
So, say I can get 220gal of SVO for $220. That comes out to $1/gal. I know you simply need to heat SVO to 160-180*F in order for it to run in a diesel. My questions are:
Running an inline filter/heater deal just before the lift pump, wouldn't the oil primed after the lift pump still be cold and un-usable? Or do you rig this joker something further in the fueling system?
If I run WVO is the same heater needed?
__________________
Durango - Rockwells, 53's, 4 wheel steer
*Rebuild* - 2" shafts, 57" R2's, TT BBC power
  #18
Old 09-21-2007, 12:41 PM
roverhybrids roverhybrids is offline
"Simply' heating VO to 160 is not as easy as adding a heated filter. You'll need a heat exchanger or two or three..........
__________________
Straight Vegetable Oil Conversions and Components.
Diesel Engine swaps. Custom Vehicle Builds.
www.roverhybrids.com
  #19
Old 09-21-2007, 01:45 PM
Quote:
I intended to run a in tank heater and a inline heater/filter as well.
__________________
  #20
Old 09-21-2007, 04:26 PM
What I'm trying to say is that no heated filter on the market will heat the fuel to 160. Surely one could make a tank heater to heat the fuel(in the tank) to 160 , but the lines and filter would still be filled with "cold" oil. You will need a real heat exchanger like a brazed plate heat exchanger or similar.
I'm not sure if you are saying that you plan on an inline heater AND a heated filter or if you think that a heated filter is available that will do both.
__________________
  #21
Old 09-23-2007, 06:37 PM
I wouldn't think of it as an inline heater, I was saying the "Magnum heater" from greasekings.com and then run there injection line heaters as well. Should be ample in getting things heated for a one tank setup?
__________________
  #22
Old 10-24-2007, 09:26 PM
robmobile1970 robmobile1970 is offline
Before the fuel goes to the injection pump it circulates through the head. If the engine is warmed up this will help heat the fuel before the injection pump. If you can just get it to the head.
  #23
Old 11-11-2007, 10:32 PM
JBox_Johnny JBox_Johnny is offline
i run veg oil in my cj 4bta it dosen't flinch when i switch over...
no smoke or loss of power...
getting the oil to temp takes time with the 4bt in the winter it is a cold runing engine...
  #24
Old 11-11-2007, 11:16 PM
I started reading heavily including a study by Caterpillar with SVO where if it was not heated correctly it lead to coking in the engine and buildup of residue that eventually compromised engine performance... For what its worth. I personally wouldn't even think of running a 1 tank system. Two tank though, I'm sold
__________________
Old 1971 FJ55, Sold
  #25
Old 11-12-2007, 10:41 PM
beck beck is offline
I was wondering about the veg oil heat up time in the winter. My truck isn't on the road yet so I have not experienced the cool running 4bt. I had been playing with gas street rods. The problem with them was keeping them cool. How long does it take in the winter to get the veg oil up to usable temps?
I had really considered WVO with a 2 tank system for my truck. My trips are typically about 25 miles. With the slow heating of the 4bt I thought that by the time the WVO was heated enough to use I would be stopping. I decided that although bio is more expensive to make I would get more benifit because I would be using it all the time. I haven't started the bio production yet either. I do still keep thinking about running straight veg oil. Like others have said, it would have to be a 2 tank system for me. I have my tank installed and my standard (bio compatable) lines installed so I would have to do some re-engineering if I wanted to swap.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2006 - 2009 Shoumatoff Media, Inc.
